Reccomendations for a budget 2 channel amp for use with pre-outs - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By afrogt
  • 2 Post By bobknavs
post #1 of 13 Old 08-10-2019, 02:44 PM - Thread Starter
syvmn's Avatar
Quoted: 26 Post(s)
I bought an Onkyo TX-RZ730 and I would like to use the extra two channels via pre-out for a 7.2.4 system. I am not having much luck searching the forums for recommendations for something inexpensive. Maybe $100 plus or minus. Thanks for any help.
syvmn is offline
post #2 of 13 Old 08-10-2019, 07:25 PM
afrogt's Avatar
Quoted: 2099 Post(s)
Liked: 1399
Most often recommended amp to expand to 7.2.4 are the Audiosource and Dayton stereo amps
https://www.parts-express.com/dayton...ifier--300-593
https://www.crutchfield.com/S-o5aZ5r...SABEgLOMfD_BwE
smithsabom likes this.
Afro GT
afrogt is offline
post #3 of 13 Old 08-12-2019, 04:09 PM
eriksells916's Avatar
Quoted: 421 Post(s)
Liked: 159
yup ^^^^^^^^^^^^^^^^^ what he said
eriksells916 is offline
post #4 of 13 Old 08-12-2019, 07:35 PM
Quoted: 108 Post(s)
Liked: 5
If i use the main in, i cant use the analog inputs of that amp?
Trunksleo is online now
post #5 of 13 Old 08-12-2019, 07:45 PM
bobknavs's Avatar
Quoted: 2217 Post(s)
Liked: 1577
Sorry, I don't understand. Can you clarify?
bobknavs is offline
post #6 of 13 Old 08-12-2019, 07:59 PM
Quoted: 108 Post(s)
Liked: 5
sorry i dont see the back of the amps.
post #7 of 13 Old 08-13-2019, 11:57 AM
afrogt's Avatar
Liked: 1399
the Main In on the amp is analog. I don't understand what you're trying to say.
Name:	Dayton amp back side.PNG
ID:	2602498   Click image for larger version
Name:	Audiosource Amp back.PNG
Afro GT
afrogt is offline
post #8 of 13 Old 08-13-2019, 12:20 PM
pase22's Avatar
Quoted: 3219 Post(s)
Liked: 2672
The recommended amps are compatible with your AVR. You should have no trouble integrating it into your system.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #9 of 13 Old 08-13-2019, 03:40 PM
RayGuy's Avatar
Quoted: 2729 Post(s)
Liked: 2498
This is a steal (on close-out?):
https://www.amazon.com/Cambridge-Aud...SIN=B078H7ZP8T
You won't find better quality at that price point.
It's a VIRTUAL channel unless stated otherwise.
RayGuy is online now
post #10 of 13 Old 08-13-2019, 04:27 PM
Quoted: 108 Post(s)
Liked: 5
My question is if i can turn on/off the yamaha rs700 and the marantz 5012 with the same control.
post #11 of 13 Old 08-13-2019, 09:35 PM
bobknavs's Avatar
Liked: 1577
That would be best done with a 12V trigger. It appears that neither receiver has a 12V trigger input.
Short answer: not directly. You could resort to something like a smart power strip (where one outlet controls the others) or a power switch that takes a 12V control.
Is there any reason that you didn't mention the RS700 nd the SR5012 in your first post? No telepaths here, as far as I know.
tinman143 and Trunksleo like this.
bobknavs is offline
post #12 of 13 Old 08-14-2019, 03:43 AM
Quoted: 108 Post(s)
Liked: 5
Thanks. I just answered that i dont see the back of the amps. I dont saw that amp dont have any inputs
post #13 of 13 Old 08-14-2019, 07:44 AM
pase22's Avatar
Liked: 2672
Unless you're using these for a different setup, You don't need anything else
