Can anyone recommend an AVR or amp for me? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-13-2019, 04:47 PM - Thread Starter
Liked: 1
Hey everyone,
I have a pair of JBL 530 - and a 520 center - I was wondering if anyone knew a budget amp or AVR I could buy that won't break the bank but is powerful enough to drive these speakers???
Thank you all,
Icy
IcyMJ is offline
post #2 of 10 Old 08-13-2019, 05:51 PM
m0j0's Avatar
Quoted: 511 Post(s)
Liked: 456
I have a Denon x4400h and can recommend as a good budget 9 channel AVR with a good mix of features and performance. If you don’t need 9 channels, there are tons of good options from a budget perspective.
m0j0 is online now
post #3 of 10 Old 08-13-2019, 06:28 PM
Quoted: 487 Post(s)
Liked: 259
what is your budget? something like a Denon S740 for ~200 from A4L would work... or stepping up to the x4400 would do very well, too.
but if the difference between those 2 is a sub or not, go with the smaller/cheaper unit and get the sub. The 530's are great sounding speakers. But you will benefit from adding a sub.
lots of people here will advise you to spend 400 - 500 for a hsu, rythmik, PSA sub... can't go wrong, but even a 130 polk ( not in the same league as the others) will add to your overall enjoyment.
here's a 149 Amazon refurb on a ML dynamo: https://www.amazon.com/MartinLogan-D...ateway&sr=8-16
BIC, Klipsch, yamaha in the 200 -250 range...
rock on...
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #4 of 10 Old 08-13-2019, 09:22 PM - Thread Starter
Liked: 1
rock on...
Thank you very much for your replies!!
are there no 3.1 channel receivers? or only 5.1 , 7.1 ect
IcyMJ is offline
post #5 of 10 Old 08-13-2019, 09:26 PM
Quoted: 487 Post(s)
Liked: 259
there are not any 3.1 receivers as far as I know. AVRs can be 2.1, 5.1, 7.1 etc... jsut get a 5.x and don't worry about not using the other channels - you can grow into them!
post #6 of 10 Old 08-14-2019, 07:13 AM
KidHorn's Avatar
Quoted: 1807 Post(s)
Liked: 1237
Any receiver can drive any set of speakers at a reasonable volume.
KidHorn is offline
post #7 of 10 Old 08-14-2019, 07:50 AM
pase22's Avatar
Quoted: 3211 Post(s)
Liked: 2670
Hey everyone,
Thank you all,
Icy
How loud does it need to get?
How much can you spend?
Do you have a sub?
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #8 of 10 Old 08-14-2019, 01:13 PM - Thread Starter
Liked: 1
Do you have a sub?
Thinking $300 - What do you think of a used Denon x1500H for $250??? - no sub yet, but may get one soon
IcyMJ is offline
post #9 of 10 Old 08-15-2019, 08:32 AM
Liked: 6
TBH you might be better off looking at a used AVR through classified here or other sites. You can probably pick up a Marantz SR5013 for $400 or so if you are willing to wait. A little more wattage than the Denon and it also has pre-outs in case you ever want to get an amp.
ck100380 is online now
post #10 of 10 Old 08-15-2019, 08:42 AM
pase22's Avatar
Liked: 2670
A Denon X1500 would be a very good option. You get good room correction, decent power and lots of features.
pase22 is offline
