Complete newbie - need advice - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By owcraftsman
  • 1 Post By eriksells916
post #1 of 8 Old 08-13-2019, 10:11 PM - Thread Starter
goodry's Avatar
I just started renting a home that has whole house wiring, terminating in my living room. There are speakers in the living room front L/R, back LR, Spare room, L/R and then L/R outdoor speakers
I would ideally like to play separate sources to the 3 areas, with the outdoor one being wireless so we can control the music to the outside from outside.
Im very much clueless as to how to accomplish this.. I have a spotify subscription and am not opposed to using wireless bluetooth transceivers or whatever is necessary I am just unsure of what equipment I would need to accomplish what I am wanting.
Summary - whole house wiring, living room, spare room, outdoor speakers. Want to play seperate sources to all 3 areas, outdoor speakers would like to be wireless.
Thank you in advance for forgiving my ignorance and I look forward to your suggestions.
goodry is offline
post #2 of 8 Old 08-14-2019, 08:19 AM
Quoted: 487 Post(s)
Liked: 259
what is your budget? a 3 zone capable receiver ( denon 4400/4500, pioneer 703) will run you ~700 - 1500 (depending on new or refurb) there are many other systems/solutions.
you could get by with as little as ~100 - 150 / zone (dayton audio from parts express) or Sonos amps ( 600/zone)
overall, I suggest you consider a music of wifi soltion ( Sonos, HEOS, musicast, playfi, etc) on top of some cost effective amplification.
that is if music is your only application.
example: https://www.parts-express.com/dayton...o-re--300-5700
alternative: 3 x ( https://www.parts-express.com/dayton...ontr--300-3821) you will be suprised at what a 20 wpc class d amp can do!. (<100/zone!)
alternative: 3 x ( parts-express.com/dayton-audio-apa102bt-class-d-stereo-60-wpc-bluetooth-amplifier--300-593) + 3 x (https://www.amazon.com/Phorus-PR5-Re...gateway&sr=8-1) = ~150/zone
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #3 of 8 Old 08-14-2019, 11:13 AM - Thread Starter
goodry's Avatar
Thank you for your reply ... I am not opposed to buying 1 unit that will do all 3. I had an old Harmon Kardon that just stopped working on me recently, AVR-525. So my application would mainly be, zone 1, living room .. would be for sports, music and movies, zone 2, spare room would be music only, zone 3, outdoor wired speakers, i would just want to wirelessly control music so we had music while we were on the patio. $700 - $1000 is not outside my budget. I am just new to the world and need to know what to look for when looking into receivers. If I could get a receiver that had wifi and supported spotify \ pandora .. and designate that zone 3 play the spotify \ pandora then wire the outdoor speakers to zone 3, that would be fine because I could control spotify from my phone outside.
another newbie question, could I designate zone 2 and 3 to play from spotify ? obviously not at the same time, I just didnt know how that would work .. would this work better to get multiple cheaper receivers ? 2 cheap ones for side room \ outside that have just basic spotify function then one main one for the living room that powers the fronts and rears ?
I know there are a lot of options and im thankful for the help in figuring out what configurations are possible.
goodry is offline
post #4 of 8 Old 08-14-2019, 03:31 PM
eriksells916's Avatar
Quoted: 421 Post(s)
Liked: 159
@goodry I am in a similar situation and here is what I have been looking at.
1. get a 9 channel amp that has zone 2/3 preouts or speaker terminal outs for 3 zone playback. That setup will allow 5.1 in the main room and then 2 speakers each zone 2 and 3. Onkyo tx-rz630/730/830 and Pioneer vsx-lx303/503, denon x4300/4400/4500 and sister marantz sr6012/6013, yamaha 2070/2080
2. Pioneer/Onkyo use Flareconnect while Yamaha uses Musiccast and Denon uses Heos. Look those up and see if that will solution might work for you?
3. Get two cheaper receivers with the above mentioned wireless eco system and use one in the living room and then the other one near the outdoor speakers so you don't have to run 1 mile of speaker cable.
eriksells916 is offline
post #5 of 8 Old 08-14-2019, 03:46 PM
owcraftsman's Avatar
Liked: 2
Most of the AVRs mentioned above have a mobile apps so you would be good for control on the patio.
If it's prewired I would get some outdoor speakers and use the wiring instead of the wifi speakers.
Probably get better sound and one app for control.
eriksells916 likes this.
TCL 65R617TBBA w/ MediaLight 6500k | Denon AVR X4400H set 7.2.4 | Outlaw 5000 (LCR & SR) | RSL CG3 5.2 system 5-NXG NX-Pro 103C (1- SB 4-Height FL, FR, RL, & RR) | Roku Ultra | Nvidia Shield (Plex Server) | Sony UBP-X800 | Panisonic DP-UB820 | Tripplite Isobar HTS10DBS | Octane XL700 seating | Makers Mark for attitude adjustments.
owcraftsman is offline
post #6 of 8 Old 08-14-2019, 03:49 PM
Quoted: 487 Post(s)
Liked: 259
the denon 4400/4500 will do everything you want. This is basically my set up. although I use outboard amps to drive zones 2 and 3. Denon/HEOS has native pandora and spotify is premium only. But you control from your phone/tablet.
post #7 of 8 Old 08-15-2019, 01:04 PM - Thread Starter
goodry's Avatar
Yes - Pre-wired
Yes, all the wires are pre-run .. The outdoor speakers, living room rear left and right, living room front, left and right and spare left and right are all pre-wired and they terminate in my living rooom. It sounds like the denon with heos might solve all my needs with 1 receiver.
goodry is offline
post #8 of 8 Old 08-15-2019, 01:11 PM
Quoted: 421 Post(s)
Liked: 159
thanks @smithsabom , this setup is exactly what I have so maybe I hold out for the x4400 now.
smithsabom likes this.
