2 channel amp for 7.2 receiver - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Russdawg1
post #1 of 7 Old 08-21-2019, 05:25 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 2
what 2 channel amp do you recommend for a 7.2 receiver (i.e. denon 4300) to power 9 channels (5.1.4)
Nstd is offline
post #2 of 7 Old 08-21-2019, 05:31 PM
Quoted: 1709 Post(s)
Liked: 1294
Anything cheap, doubtful you’ll hear a difference in a theater setup and being used to power Atmos channels.
Craigslist is a good place to look.
tinman143 likes this.
Leave it at 8 ohms and call it a day :)
Russdawg1 is online now
post #3 of 7 Old 08-21-2019, 05:44 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 2
do you have any examples? will these work?
https://www.amazon.com/Micca-OriGain...gateway&sr=8-5
https://www.amazon.com/Audio-Amplifi...NsaWNrPXRydWU=
Nstd is offline
post #4 of 7 Old 08-21-2019, 05:46 PM
Liked: 1294
Originally Posted by Nstd View Post
https://www.crutchfield.com/S-LqDFBA...SABEgJnC_D_BwE
post #5 of 7 Old 08-21-2019, 05:49 PM
FlyOnTheWall's Avatar
Quoted: 152 Post(s)
Liked: 35
FlyOnTheWall is offline
post #6 of 7 Old 08-21-2019, 08:51 PM
bobknavs's Avatar
Quoted: 2256 Post(s)
Liked: 1609
The Denon AVR-X4300H has 9 amps, and will do 5.1.4 without any external amplifiers.
It processes 11 channels, so if you want to do 7.1.4, you'd need the external stereo amp.
Examples: Audiosource AMP100VS, Audiosource AD1002, Dayton APA102BT. The AMP100VS is class A/B, the other two are class D. All three have the 12V switch that I'd recommend, which allows the AVR to turn on the external amp automatically.
All there would be adequate to drive the rear Atmos speakers. (The 4300 gives you two choices as to which speakers don't use its internal amps: the LR fronts, or the rear heights.)
There are more elegant choices, at higher cost. Example: Emotiva BasX A-100.
bobknavs is offline
post #7 of 7 Old 08-22-2019, 06:50 AM
Quoted: 534 Post(s)
Liked: 278
the class D amps work great, and don't generate much heat, for surround or atmos duty. they also have an "auto on" feature ( just like most sub woofers) turns itself on when it senses a signal. turns itself off after a period of in activity.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
