Is Atmos worth it ? old used high-end vs newer low/mid - AVS Forum | Home Theater Discussions And Reviews
 8Likes
  • 1 Post By SinGA
  • 3 Post By rontalley
  • 1 Post By chrischavis5150
  • 2 Post By jdsmoothie
  • 1 Post By tinman143
post #1 of 14 Old 08-23-2019, 08:25 AM - Thread Starter
Liked: 0
I'm at a situation where I get to start all over with my home theater setup after a few years away.
The room I will place the equipment will force me to have the cough pretty much close to the rear wall
I am pondering about either get a preused highend reciever and use a standard 5.1 setup vs buying a lowerend modern reciever for example the sony 1080 and setup a 5.1.2 atmos using either upfire fronts or 2 ceiling speakers
I will only use streaming services and upmixing with Dolby Surround.
Is atmos really such an improvement or would a solid 5.1 setup with a highend older receiver be the way to go ?
Picture or upscaling is not as important, I don't even have a 4k tv at the moment.
Joker99 is offline
post #2 of 14 Old 08-23-2019, 08:27 AM
Quoted: 94 Post(s)
Liked: 60
Yes. it is worth it.
audiofan1 likes this.
SinGA is offline
post #3 of 14 Old 08-23-2019, 08:45 AM
patoberli's Avatar
Quoted: 170 Post(s)
Liked: 67
Send a message via Skype™ to patoberli
If you go for Atmos, get in/on ceiling speakers. The effect is so much better compared to up firing (which I currently own).
Please note, unless you use a lot of Netflix (and there also only just the Netflix productions, with some exceptions) or 4k Blu-rays, there isn't that much Atmos content. There are also some games supporting it, but the list is very short. Of course the AVR should be able to up mix to Atmos which sounds nice in most cases.
patoberli is online now
post #4 of 14 Old 08-23-2019, 08:46 AM
Liked: 4
Yes it's worth it. A 5.1.4 is a good solid atmos for a small room. I'd do front heights and overhead celing heights. I did this to start till I upgraded to 7.3.4.
Sent from my SM-N950U using Tapatalk
chrischavis5150 is offline
post #5 of 14 Old 08-23-2019, 08:58 AM
rontalley's Avatar
Quoted: 784 Post(s)
Liked: 395
Atmos/DTS-X is not a gimmick and even those sources that does not have an Atmos/DTS-X mix will sound better upmixed. I actually prefer DTS-X upmixing more the DSU. The difference is substantial but the effect is not as great when only doing 2 height speakers. 5.x.4 is the way to go. The couch on the back of the wall is kinda a bummer but you will still get good effect with 4 height speakers.
You will find alot of great affordable options by only needing 9 speakers vs. 11.
Good Luck!
tinman143, Zoland2020 and rhed like this.
My Media Room
AVR 1-Yamaha RX-A3050 (7.2.4), AVR 2 Pioneer VSX-815-K(Used for 4ch Amp TF+TR)
Mains-Polk Audio RTi8, Center-Polk Audio CSi5, Surrounds-Polk Audio RTi4, Ceilings-Micca M-8C, Sub 1- UM18-22 (4cu.ft DIY) - iNuke 6000DSP Sub 2-Klipsch RW12D,
Projector-Looking, Screen-Da-Lite 100" Model B, TV-Vizio P-65 4K
rontalley is offline
post #6 of 14 Old 08-23-2019, 09:43 AM
sdurani's Avatar
Quoted: 7153 Post(s)
Liked: 6163
The main improvement is turning a 2D ring of sound into a 3D bubble of sound. If you can tell the difference between sounds coming from around you versus sounds coming from above you, then Atmos will be worth it for you.
Sanjay
sdurani is offline
post #7 of 14 Old 08-23-2019, 10:13 AM - Thread Starter
Liked: 0
Thanks guys, I will be getting a newer receiver from the way you describe it.
Since I will be 100% watching movies and no 2 channel at all, going with a "weaker" new receiver will probably be the best option in regards of value.
Joker99 is offline
post #8 of 14 Old 08-23-2019, 11:34 AM
patoberli's Avatar
Quoted: 170 Post(s)
Liked: 67
I solved my 7.1.4 system with a Denon X4300H (which is an 11 channel but "only" 9 amplifier) AVR. I then added a second, cheap amp, with which I amplify the missing 2 channels. This is WAY cheaper than an 11 channel amplifier.
post #9 of 14 Old 08-23-2019, 11:41 AM
brazensol's Avatar
Quoted: 732 Post(s)
Liked: 548
On a well-mixed Atmos soundtrack it is a night and day difference! Well worth it in my opinion.
Denali Cinema
JVC-RS540, 124" Wide 2.40:1 DIY Screen, Denon 8500H, Denon 6200W, Panasonic UB820 UHD Player, (3) iNuke 6000DSP's; (3) HTM-12's; (14) RSL C34e surrounds; (2) 18" Dayton Audio RSS460HO-4 Subwoofers; (1) Dayton Audio UM18-22 18" Ultimax Subwoofer; (4) Dayton Audio RSS390HO-4 15" Reference HO Subwoofers
brazensol is offline
post #10 of 14 Old 08-23-2019, 11:42 AM
tinman143's Avatar
Quoted: 74 Post(s)
Something you should think about for the future is a receiver that has pre-outs. Unfortunately that tends to be offered in middle tier models. I still think it’s a good investment as you may want to get an external amp to offload the avr.
tinman143 is offline
post #11 of 14 Old 08-23-2019, 12:09 PM
Liked: 4
Agreed. I first got an onkyo but it had no preouts so I went with a pioneer elite vsx lx504 and I'm running amps on all my channels. I have a 6 channel and 3 2 channel amps!
tinman143 likes this.
post #12 of 14 Old 08-23-2019, 12:16 PM
jdsmoothie's Avatar
Quoted: 22373 Post(s)
Liked: 12178
The new 2019 Denon AVR X3600H is the lowest Denon AVR that can support 9CH processing on board (eg. 5.1.2 + Zone 2 or 5.1.4 or 7.1.2; and 11CH with 2CH external amp) with a full set of 11 main zone pre-outs. This is the first year that 9CH support has dropped down from the X4000 series to the X3000 series.
DavAbq and rontalley like this.
jdsmoothie is offline
post #13 of 14 Old 08-23-2019, 12:27 PM
tinman143's Avatar
Quoted: 74 Post(s)
And XT32 room EQ to boot
chrischavis5150 likes this.
post #14 of 14 Old 08-24-2019, 01:10 AM
audiofan1's Avatar
Quoted: 2314 Post(s)
Liked: 2872
Atmos worth it indeed
audiofan1 is online now
