Help with upgrade/downgrade - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 1 Post By Dargent0628
  • 1 Post By Leeliemix
  • 1 Post By Rich428
  • 1 Post By PlanetAVS
post #1 of 18 Old 08-24-2019, 06:43 AM - Thread Starter
blgentry's Avatar
I'm rebuilding my home theater system. My previous system hasn't been used in a good number of years. It was a somewhat expensive system back then: Paradigm Reference V2 speakers, Anthem AVM-20, and Anthem 5 channel power amp. I liked this system, but to be honest, it never really wowed me. I think I overspent on that system significantly. The Anthem AVM-20 is now terribly outdated and does not support HDMI in any way. Also, I recently hooked up the AVM-20 with a 2 channel system and was rather unimpressed with it. I think it's A/D, D/A, and processing are kind of weak from a sound quality perspective. An analog receiver without any DSP actually sounded quite a bit better.
So I now want something to replace the AVM-20, but I want to do this inexpensively. Nothing anywhere near the price class of the Anthem. I really would like to spend $400 or less. I'm ok with used equipment; in fact used is my first choice so I can get more performance for my money.
I think a good used AVR is probably the way to go. But I'm finding that most AVRs do not have a full 5.1 (or 7.1) set of preamp outputs. I would like to use my Anthem 5 channel power amp. But that might not happen with my current budget. I might be forced to use onboard amplification in my new AVR.
Any thoughts or ideas on this would be appreciated. Especially specific recommendations for good used AVRs. I'm no longer focused on trying to get "high end sound" from my home theater. But good sound quality would definitely be nice. I only have a 5.1 setup, so I don't necessarily need a 7.1 capable system, particularly if I can get something with good sound quality and stay in my budget.
Brian.
blgentry is offline
post #2 of 18 Old 08-24-2019, 07:15 AM
Quoted: 229 Post(s)
Liked: 112
Out of curiosity, what sub do you have and how is the room?
A mid range AVR with pre-outs would be a good step, sorry i cant help with any specifics.
Leeliemix is online now
post #3 of 18 Old 08-24-2019, 07:31 AM - Thread Starter
blgentry's Avatar
The sub is a Paradigm Servo 15. Room is a joined living room/dining room that's about 25 x 14. Seating position is around 8 feet from the main speakers and 5 feet from the back wall. Not in any way ideal; it's just a typical living room.
I'm not even sure where the surrounds are going to go, or even if I will hook them up. They are Studio ADPs, which are from back when Paradigm (and the whole industry) thought that dipole surrounds were the way to go. Frankly, I always hated my dipoles. They never produced a convincing surround effect. If/when I connect them this time, I think I will aim one side of them at the listening position and let the other side just aim at the wall or whatever. I might get into them and disconnect one side, making them a monopole. I have not decided yet. I haven't really decided on much at all, as you can see.
Brian.
blgentry is offline
post #4 of 18 Old 08-24-2019, 08:17 AM
Dargent0628's Avatar
Quoted: 227 Post(s)
Liked: 127
https://www.accessories4less.com/mak...-w/heos/1.html
Under $400 I don't think you'll find a full compliment of preouts. This Denon is a great value and has the most advanced audyssey.
Sent from my moto z3 using Tapatalk
PlanetAVS likes this.
Dargent0628 is offline
post #5 of 18 Old 08-24-2019, 08:29 AM
Quoted: 73 Post(s)
Liked: 8
Brian.
Brian - I am upgrading to more channels via a Denon X8500H. I have an X3500H in service since late March I’m replacing. I am asking $500 Shipped. It has the original Box, unopened Audyssey mic, stand and labels. (Everything it came with). Just a thought. It’s a superb AVR, I just needed more processing. PM me if interested.
Thanks - Rich
Rich428 is online now
post #6 of 18 Old 08-24-2019, 08:58 AM
pase22's Avatar
Quoted: 3292 Post(s)
Liked: 2736
Brian.
An AVR with full pre-outs, HDMI and modern features for $400 is a little unrealistic. The above mentioned Denon is likely your best option or an AVR. Pre-amp/processor options will be well above your budget.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #7 of 18 Old 08-24-2019, 11:17 AM - Thread Starter
blgentry's Avatar
If $400 is too little to get an AVR with 5.1 or 7.1 preouts, then I may increase my budget. Looks like $500 should cover it.
The question is, with an AVR in this category, am I going to find a benefit from my external amplifier? If it's questionable, maybe I'll just use the AVR's amplifiers and then I won't need to find an AVR with full preouts.
The idea that AVRs and AVPs become worthless after a few years, due to ever changing formats, is very difficult to swallow. I spent nearly $2000 for the AVM-20 and now it's worth ~$200 on a good day. I'm reluctant to spend big money on a component like this again since I know at some point it too will be nearly worthless. Home theater is almost as bad as home computers in this respect.
Brian.
blgentry is offline
post #8 of 18 Old 08-24-2019, 11:21 AM
Quoted: 229 Post(s)
Liked: 112
The power amp if working well is by no means obsolete.
Adamg (Ret-Navy) likes this.
post #9 of 18 Old 08-24-2019, 11:30 AM
Quoted: 73 Post(s)
Liked: 8
Brian.
Brian - that’s why I offered my X3500H. It’s current with pretty much everything you’re looking for and is a lot of good technology for $500. I have plenty of people that will buy it, so I wasn’t trying to push it on you. I just think it’s a great solution for $500. It will be relevant for at least 5 years, or at least until 8k becomes a standard. eARC is already there. I had my last Denon AVR for 11 years. Only upgraded because of its 1080p limits. Audiowise, I didn’t even have any reason to upgrade.
I almost feel like I spammed your post. I didn’t mean to, was just trying to give you a potential solution.
post #10 of 18 Old 08-24-2019, 11:37 AM - Thread Starter
blgentry's Avatar
Rich,
I actually meant to say thank you for your offer. I will consider that deal as one of my options. Though I realize that it might be sold 2 hours from now, so I won't try to hold you to anything.
Brian.
blgentry is offline
post #11 of 18 Old 08-24-2019, 11:38 AM
PlanetAVS's Avatar
Quoted: 1987 Post(s)
Liked: 1864
Brian.
The two main reasons that people add external amps are to 1) increase the number of channels being used 2) add headroom via additional power capacity. Since you have no desire for anything over 5.1, the headroom is your advantage. The value of this will depend on your listening levels, speaker efficiency, size of room. Your call.
Rich428 likes this.
PlanetAVS is online now
post #12 of 18 Old 08-24-2019, 11:40 AM
Quoted: 73 Post(s)
Liked: 8
No worries Brian. Let’s just get you to achieve your goal. If it’s adding the x3500, then great. If not, it’s all about helping each other problem solve.
post #13 of 18 Old 08-24-2019, 12:05 PM
Quoted: 534 Post(s)
Liked: 278
check out the outlaw 975...at 549... only a little over budget new, and I have seen used ones go for under budget recently. supports the audio requirements. I didn't see any video req's that would disqualify it.
although a used denon 3xxx / 4xxx could be found for the desired budget
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #14 of 18 Old 08-24-2019, 12:24 PM
Quoted: 73 Post(s)
Liked: 8
This is on point. In your case headroom is the benefit. That said, you will find a number of 5.1 Channel AVRs very reasonable, since you’ll be pushing the fronts with the external amp, the rears or surrounds won’t require much in terms of wattage. What ohm load are your surrounds?
At this point you’ll need to make sure the AVR has front preouts & 4K HDMI capability. You don’t need to worry about HDMI 2.1 for your use, it’s not even close to a standard yet. Point is, you need features, but not a ton of power. Audyssey would be nice.
Can you think of any further requirements? The Denon X3500H has it all at this point, but there are definitely lesser expensive options with less features if you’re only needing 5.1 dsp.
post #15 of 18 Old 09-09-2019, 12:42 PM - Thread Starter
blgentry's Avatar
I've increased my budget and am considering a refurb Marantz SR5013. Or perhaps a Denon AVR-X3400H . I think they are extremely similar.
Any comments on them? I was briefly considering a Yamaha A860, but Yamaha's "Operating System" and remotes have always confused me. Their engineers apparently think about things differently than I do. Denon was usually much better in this respect, but I haven't touched a Denon setup menu since about 2003. I'm guessing they are different now. :P
Both of the above receivers seem to have 4k HDR 60Hz switching, which should be good for me for a while. I just bought a new TV a few weeks ago that does 4k/60 HDR.
Brian.
blgentry is offline
post #16 of 18 Old 09-09-2019, 12:55 PM
eriksells916's Avatar
Quoted: 440 Post(s)
Liked: 169
Brian.
The x3400 should be a step up from the sr5013 and more similar to the sr6012, with less channels, no hdam and no 7 channel pre-ins. They both have audyssey xt32 with subeqht, which is their top of the line room correction solution. The sr5013 uses audyssey xt.
Some love the yamaha sound, they have excellent dsp options and an excellent phone app, but they are rarely on sale.
other considerations are the Pioneer vsx-lx503, Onkyo rz730/830 (9 channels) and the denon x3500 and yammy rx-a870/880 (7 channels) all refurbs for under $550
eriksells916 is offline
post #17 of 18 Old 09-09-2019, 01:31 PM - Thread Starter
blgentry's Avatar
Interesting. I thought the Denon X3400 and Marantz SR5013 were from the same year with similar feature sets. I guess not?
Pretending that I don't care about Audyssey is there any other difference? I'm more concerned about sound quality (from the preouts) and ease of user interface. I'm guessing they are rather similar in interface. Also guessing the Marantz has slightly better sound quality. But those are both guesses!
Brian.
blgentry is offline
post #18 of 18 Old 09-09-2019, 08:07 PM
bobknavs's Avatar
Quoted: 2250 Post(s)
Liked: 1606
Brian.
The X3400 comes with Audyssey XT32 (and SubEq). The SR5013, the lesser Audyssey XT. The Denon and Marantz product lines don't align precisely.
Marantz claims better sound quality due to their "HDAM" circuitry. Some claim that it's mostly marketing nonsense. I know nothing about that.
bobknavs is online now
