HELP WITH 11-Channels - XPA-11 / MX-A5200 / Monoprice.... - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By skylarlove1999
post #1 of 12 Old 09-10-2019, 03:47 PM - Thread Starter
Quoted: 32 Post(s)
Liked: 5
Looking for suggestions from those with experience on these 11-channel amps.
I was going to inherit an XPA-11 from my brother as he was upgrading, but he decided to sell it instead....oh well.
I will be running an Anthem AVM60 on a 7.2.4 setup.
Ascend Acoustics Sierra Towers and Horizon as LCR (with Raals), Revel S16's as surrounds and 4 x ATMOS in ceiling (TBD) and 2 x PSA v1812s.
I need 11 Channels of amplification...
My brother liked his XPA-11 besides having to switch +/- for polarity reasons. But he claims he cant hear the difference between his new HALO Parasounds and his XPA-11.
Choices are:
  1. Emotiva XPA-11
  2. Yamaha MX-a5200 (can get it at same price as XPA-11)
  3. Monolith 11-channel
  4. I can also get a used combo Parasound Halo a31 + Anthem PVA-8 for $3800 (this is a lot more than the other 3) or an used Anthem MCA 325 + PVA-8 for $3500.
Would rather not spend the extra $ on the used combos for $3500+ specially if it the incremental benefit is not there....I can spend those $1500+ elsewhere.
Any suggestions?
crg28 is offline
post #2 of 12 Old 09-10-2019, 05:34 PM
skylarlove1999's Avatar
Quoted: 636 Post(s)
Liked: 444
Choices are:
  1. Emotiva XPA-11
Any suggestions?
Go with the monolith. Made in America by ATI. Best bang for your buck IMHO.
Sent from my SM-G965U using Tapatalk
smithsabom and junior00027 like this.
skylarlove1999 is online now
post #3 of 12 Old 09-11-2019, 11:34 AM - Thread Starter
Quoted: 32 Post(s)
Liked: 5
Thanks! The Monolith is still ~$400 more than the XPA-11. Is it considered a better amp? If so, why?
crg28 is offline
post #4 of 12 Old 09-11-2019, 12:06 PM
Quoted: 636 Post(s)
Liked: 444
Personally I feel that 65 watts per channel is a little underpowered for your surrounds. That is what you get with the XPA 11. Honestly 65 is probably okay for everything but the left and right surrounds. Soundtracks these days do put some very dynamic sound effects into the surround channel. Think gunshots, explosions, glass breaking , punches and kicks environmental sounds that really set the mood for the scene. I would just like a little more power for the increased headroom when warranted. The Monolith provides 100 watts per channel for channels 4-11. I do really love the 300 watts per channel for LCR that the XPA-11 delivers.
It is really a personal preference. I think 200 watts per channel is enough for the LCR that you get from the monolith and you get some extra watts for all you other channels. It also depends on how capable your surround and Atmos speakers are of delivering the full sound bandwidth other than bass. I have some full sized speakers for my surrounds that would be underpowered IMO with 65 watts. I don't think you can go wrong with either choice.
post #5 of 12 Old 09-11-2019, 12:34 PM
bobknavs's Avatar
Quoted: 2274 Post(s)
Liked: 1615
I don't know whether the power difference for the effects channels (65W for the NAD, 100W for the Monolith) would be significant for most people.
The Monolith weighs 93.2 lbs (42.3 kg). The Emotiva, 53 lbs (24 kg).
If you care about power efficiency, the Emotiva may be superior. I have an XPA3 Gen3 used for LCR with a Denon AVR-X4300H. The XPA runs relatively cool.
bobknavs is online now
post #6 of 12 Old 09-11-2019, 04:14 PM - Thread Starter
Quoted: 32 Post(s)
Liked: 5
Did you have any issues with the Emotiva XLR Pin 2 (hot) configuration with your powered Subs?
crg28 is offline
post #7 of 12 Old 09-11-2019, 09:53 PM
bobknavs's Avatar
Liked: 1615
I'm using only RCA cabling. The AVR-X4300H does not have XLR pre-outs.
You could try PMing Ralph Potts, the official BluRay reviewer. His HT setup includes an XPA11 Gen3, if memory serves. Maybe he can provide some advice from experience.
post #8 of 12 Old 09-13-2019, 09:23 AM - Thread Starter
Quoted: 32 Post(s)
Liked: 5
Just realized Monoprice adds shipping costs, so the different from the XPA-11 is closer to $500....
crg28 is offline
post #9 of 12 Old 09-13-2019, 10:43 AM
Quoted: 636 Post(s)
Liked: 444
Sounds like the XPA-11 is your amp. Just do it.
post #10 of 12 Old 09-13-2019, 11:27 AM - Thread Starter
Quoted: 32 Post(s)
Liked: 5
I don't mind spending another $500 if the consensus is that the ATI built Monolith is a $500+ better option than the Emotiva amp. I was hoping to get some feefback from other (XLR) users of both amps and from others that could speak of the real world power difference between the LCR and the resto of the channels on both amps. 3 x 200 vs 3 x 300, 8 x 65, 8 x 100.....
crg28 is offline
post #11 of 12 Old 09-13-2019, 11:37 AM
Quoted: 636 Post(s)
Liked: 444
I think the 300 watts per front LCR will be more beneficial and noticeable than the 200 watts. 65 versus 100 for all the other channels will not really be noticeable by anyone other than people using full range speakers as surrounds. Which most people are not.
post #12 of 12 Old 09-14-2019, 03:52 PM - Thread Starter
Quoted: 32 Post(s)
Liked: 5
Fair enough. Thks
crg28 is offline
