Separates for my front channels - advice - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By Leeliemix
  • 1 Post By pase22
  • 1 Post By bobknavs
post #1 of 15 Old 09-11-2019, 08:32 AM - Thread Starter
Liked: 0
Hi all! I am currently running a HT/audio setup in my basement through an RX-V681. While I have been generally happy with the quality and functionality of that particular AVR, I'd like to move to dedicated power for my front channels as I usually listen to music on this setup. I would also like to bypass all of the additional adjustments being applied by the RX, but pure direct mode is a joke in my experience. I have been considering a Denon 3500 as it has pre-outs and an Emotiva A-500 or Outlaw 5000. My main question is whether the Denon is a good option for this or whether I should get the Denon, another music-oriented pre-amp, and run the fronts completely separately when listening to music. Any thoughts or suggestions are greatly appreciated!
Currently running:
RX-v681
Dali Oberon 7
Dali Oberon Vokal
Rega Planar 2
Sent from my Pixel 3 using Tapatalk
whistleface is offline
post #2 of 15 Old 09-11-2019, 08:37 AM
Quoted: 239 Post(s)
Liked: 122
Why do you feel the yamaha pure direct is a joke?
Leeliemix is online now
post #3 of 15 Old 09-11-2019, 08:45 AM - Thread Starter
Liked: 0
No subwoofer integration and it sounds incredibly hollow with a tiny soundstage. I have run the same speakers on Onkyo and Emotiva stereo Amos and they sound fantastic, but the pure direct/stereo mode on the 681 sounds deflated. I had the same issue on my previous 481 as well.
post #4 of 15 Old 09-11-2019, 09:20 AM
Quoted: 239 Post(s)
Liked: 122
You might like the denon but probably with audyssey enabled.
Im always a fan of powerful amps, it helps, but im not sure the 2 mentioned are that much better than the 3500 or if you put the money from separate amp into higher up denon/yamaha. A separate amp will be able to stay with you through a few AVRs though as the technology changes.
whistleface likes this.
post #5 of 15 Old 09-11-2019, 12:39 PM
bobknavs's Avatar
Quoted: 2274 Post(s)
Liked: 1615
I believe that in most AVRs "pure direct" means minimal digital processing.
As the crossover for the sub is performed digitally, "pure direct" probably isn't what you want to use if you wish to include a sub.
bobknavs is online now
post #6 of 15 Old 09-11-2019, 12:47 PM - Thread Starter
Liked: 0
Correct, that's why I'm searching for a way to use separates to get the most of of my fronts as well as integrate my sub. I'm not sure if/how that is possible. My sub does not have high level inputs so I can't just forward the signal outside of the amp/receiver. I'm thinking I'll be stuck with a receiver of some kind, but Im looking for recommendations or ideas on how to best put that together. I guess I could always just put a separate integrated amp, but I then I'd have to disconnect and reconnect the sub and speaker cable constantly.
post #7 of 15 Old 09-11-2019, 12:47 PM - Thread Starter
Liked: 0
Does Audyssey allow sub use with their direct mode, or would I be in the same boat?
post #8 of 15 Old 09-11-2019, 12:51 PM
Quoted: 239 Post(s)
Liked: 122
Direct bypasses audyssey and bass management, but stereo mode can use both.
post #9 of 15 Old 09-11-2019, 12:59 PM
pase22's Avatar
Quoted: 3297 Post(s)
Liked: 2739
I'm running a Denon X3400H with a NAD 216 (125W/channel) amp for my LS50's. The X3400 can run the speakers fine on their own, but the NAD gives them a nice boost. For most music stereo with audyssey, dynamic eq and all other processing turned off sounds can pretty nice too if you want the sub involved. Audyssey XT32 does a pretty good job so you may actually like having audyssey on.
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: JBL Loft 50 , Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #10 of 15 Old 09-11-2019, 01:02 PM - Thread Starter
Liked: 0
Originally Posted by pase22 View Post
I'm running a Denon X3400H with a NAD 216 (125W/channel) amp for my LS50's. The X3400 can run the speakers fine on their own, but the NAD gives them a nice boost. Direct mode is where the amp really makes a difference. Stereo with audyssey, dynamic eq and all other processing turned off sounds pretty nice too if you want the sub involved.
Thanks for the input! How have you liked the 3400?
post #11 of 15 Old 09-11-2019, 01:12 PM
pase22's Avatar
Liked: 2739
The X3400 was a big upgrade over the Denon S710W that's now being used in another setup. Audyssey XT32, sub eq, more power have all made a noticeable difference. The biggest improvement was getting better speakers.
pase22 is offline
post #12 of 15 Old 09-11-2019, 01:14 PM - Thread Starter
Liked: 0
Yeah the LS50s are a great, well rounded package. What did you have prior? I recently moved from Q500s to the Dalis and have been very satisfird.
post #13 of 15 Old 09-11-2019, 06:51 PM
bobknavs's Avatar
Liked: 1615
I employ the normal stereo mode for 2 channel sources. Such as audio CDs. (Most of which I acquired from 1984 to 1995.)
It can be calming to not be a perfectionist.
post #14 of 15 Old 09-11-2019, 07:17 PM - Thread Starter
Liked: 0
Agreed, but this is equally parts music enjoyment and the fun of building a unique, high quality setup. I reached satisfactory sound long ago tbh.
post #15 of 15 Old 09-12-2019, 10:17 AM
pase22's Avatar
Liked: 2739
I upgraded from Kef Q100's. The upgrade wasn't a giant leap, but a very noticeable step up in SQ.
pase22 is offline
