JBL Synthesis SDP-55 (16ch, 9.1.6 Atmos Surround Sound Processor) - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 1940Likes
post #91 of 2457 Old 10-03-2019, 06:53 PM
TAGmanz's Avatar
Quoted: 17 Post(s)
Liked: 8
I am following closely the development of the SDP-55 as it may well suit my needs for a new 16Ch processor early next year. I have a few questions that some of you here may know the answer to.
From what I understand the DAC chipset in this model will be 2x ESS9028 8Ch. This to me implies that output from each channel will be unbalanced? There are of course XLR connectors on the rear panel but do these carry a truly balanced signal or are they carrying a mirror of the unbalanced RCA connection? I recall reading somewhere that previous model Arcam processors were configured in this way but could be mistaken on that.
Also does anyone know how the volume control is being handled? Is it in the analog domain using a resistive ladder network or will it be digitally controlled within the DAC chip itself? It would make some sense for the volume to be digitally controlled prior to being sent out via Dante I guess?
TAGmanz is online now
post #92 of 2457 Old 10-04-2019, 02:22 AM
Mashie Saldana's Avatar
Quoted: 1478 Post(s)
Liked: 1358
Dante won't touch the DAC's in the processor at all and use whatever DAC is on the other end which would be inside a Dante enabled amplifier.
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is offline
post #93 of 2457 Old 10-04-2019, 07:52 AM
bigguyca's Avatar
Quoted: 1475 Post(s)
Liked: 1395
From what I understand the DAC chipset in this model will be 2x ESS9028 8Ch. (1) This to me implies that output from each channel will be unbalanced? There are of course (2) XLR connectors on the rear panel but do these carry a truly balanced signal or are they carrying a mirror of the unbalanced RCA connection? I recall reading somewhere that previous model Arcam processors were configured in this way but could be mistaken on that.
Also does anyone know (3) how the volume control is being handled? Is it in the analog domain using a resistive ladder network or will it be digitally controlled within the DAC chip itself? It would make some sense for the volume to be digitally controlled prior to being sent out via Dante I guess?
(1) Why does the use of two ESS9028 DAC IC's imply that the output is unbalanced. Please explain.
(2) The design you are describing is commonly used, and is a perfectly valid way to produce a balanced signal for transport over balanced cables from an XLR output. Balanced means equal impedance to ground from each conductor. The circuit you are describing will produce a balanced signal if designed correctly. Please explain in depth why the circuit you have described will not create a balanced signal.
(3) Based on your brief descriptions, either of these methods are the most commonly used volume control methods in the products normally discussed on this forum.
bigguyca is online now
post #94 of 2457 Old 10-04-2019, 07:23 PM
TAGmanz's Avatar
Quoted: 17 Post(s)
Liked: 8
Thanks for your response. My original post was perhaps not as clear as I had thought at the time.
What I am trying to determine is if the internal architecture is "fully", "truly" or by whatever other term takes your fancy, balanced from the output of the DAC to rear panel XLR connector.
1) It is my (quite possibly flawed) understanding that in order for the analog signal path to be balanced from source to output connection it requires the use of two DAC's per channel. One each for the positive and negative half of the waveform. In the case of a 16ch processor this would mean 32 independent DAC channels. Two 8ch ESS9028 DAC IC's clearly does not meet this criterior.
2) I was not proposing that a balanced output could not be derived via appropriate circuitry from a single DAC channel or indeed that it was in any way uncommon to do this.
As mentioned above I was trying to determine if the entire signal path was balanced. Please understand that I am not trying to argue for one implementation or the other I was simply seeking clarification of what the internal architecture is.
3) Again, not arguing for one method over the other. Just trying to determine whether the volume control is done in the digital or analog domain or possible even both?
post #95 of 2457 Old 10-04-2019, 08:42 PM
bigguyca's Avatar
Liked: 1395
1) Each channel of an ESS9028 has a + and - current output. At a minimum in a quality design the two outputs are converted to voltage outputs and filtered by I/V converters. This provides +/- outputs that can be used for a balanced/differential output, one balanced output per channel. Essentially all DAC IC's have a +/- output, either current or voltage. It isn't clear why you believe two DAC IC channels are required for a balanced output, please explain.
2) The SP-55 is not yet available. As such it is hard to know the internal design. You may want to contact someone at JBL with your question.
3) Certainly the volume control can be done in a variety of ways. Again, the SP-55 isn't available.
post #96 of 2457 Old 10-04-2019, 09:45 PM
TAGmanz's Avatar
Quoted: 17 Post(s)
Liked: 8
Your answer was very educational. Thank you.
post #97 of 2457 Old 10-06-2019, 03:13 PM - Thread Starter
Spizz's Avatar
Quoted: 535 Post(s)
Liked: 386
Don't know if this was on the site before but the spec sheet has been added-
https://www.jblsynthesis.com/on/dema...t_EN_V2_LR.pdf
Spizz is offline
post #98 of 2457 Old 10-09-2019, 03:55 PM
Gooddoc's Avatar
Quoted: 3922 Post(s)
Liked: 3603
I just found interfaces to go from Dante to AES EBU and Blu-link, which covers all of my amps. "Relatively" inexpensive (less than $1500 for both units). This just put this unit at the top of my list.
Going all digital to my amps will be awesome and something I've wanted to do for a long time. It will be nice to get rid of the 50 foot XLR runs and all the other XLR's in the back of the rack
Frohlich and Lynkage like this.
Gooddoc is offline
post #99 of 2457 Old 10-09-2019, 04:06 PM
enricoclaudio's Avatar
Quoted: 4348 Post(s)
Liked: 5755
Just make sure the Dante receiver (amp or AES EBU/Blu-Link) have good DACs as the DA conversion will be done on the receiver and not on the SDP-55. On live/PA audio application that does not matter too much as signal to noise ratio are elevated compared to home audio applications so a not high end DAC on the Dante pre amp is OK.
Enrico Castagnetti @ Rythmik Audio - Dialing In Rythmik Audio Subwoofers - REW for macOS
Media Room: Sierra Towers w/RAAL, Horizon w/RAAL, Sierra 2s & Lunas | Rythmik G22 (x2) + FV25HP | Denon X6500H | Panny 820 + ATV 4K | Bluesound Node 2 | Sony 77A9G OLED |
Desktop: Dynaudio BM5 mkIII | Rythmik L22 | Apogee Quartet | 27" iMac| Bedroom: B&W 685 S2 | Rythmik LVX12 | Marantz SR6013 | Sony X700 + ATV 4K | Sony XBR-65Z9D |
enricoclaudio is offline
post #100 of 2457 Old 10-09-2019, 04:10 PM
Gooddoc's Avatar
Liked: 3603
It's done on my amps regardless since my speakers are active. It will simply eliminate an unnecessary DA conversion in the SDP-55 and an AD conversion in my amp.
Mashie Saldana and flax like this.
Gooddoc is offline
post #101 of 2457 Old 10-11-2019, 05:13 PM - Thread Starter
Spizz's Avatar
Quoted: 535 Post(s)
Liked: 386
Spizz is offline
post #102 of 2457 Old 10-11-2019, 06:12 PM
Liked: 5755
A curious thing he mentioned at the end of the video is that the SDP-65 offers "independent crossover" for each speaker. So looks like the SDP-55 still will offer a single crossover for the bed speakers.
post #103 of 2457 Old 10-11-2019, 10:18 PM
Quoted: 43 Post(s)
Originally Posted by sdurani View Post
You continue thinking of DTS:X Pro as an upmixer: Pro simply lifts the current 11-speaker limit. It is not an upmixer like Logic16. To upmix legacy 5.1/7.1 sources to your speaker layout, DTS already has an upmixer called Neural:X. Pro simply lifts the current 11-speaker limit. Pro is not something you apply to legacy sources.
Well, DTS:X Pro includes the new DTS Neural: XTM up-mixer. Maybe thats a bit confusing.
To Logic 16: The new Lexicon RV-9 comes with "Logic 7 immersion". This failed in a multichannel test of a german magazine. Thats not a good sign...
I hope DTS:X Pro will be available from day 1, because I don't won't silent loudspeakers in my cinema…
rolfu is offline
post #104 of 2457 Old 10-11-2019, 11:00 PM
sdurani's Avatar
Quoted: 7882 Post(s)
Liked: 7075
Less confusing if you type it out as DTS Neural:X™ (™ is the trade mark logo). There is no "new DTS Neural: XTM up-mixer".
Mashie Saldana likes this.
Sanjay
sdurani is offline
post #105 of 2457 Old 10-12-2019, 11:14 AM
mmiles's Avatar
Quoted: 1237 Post(s)
Liked: 643
Good catch. PREVIOUS model Arcam units offered a single crossover.
Mike Miles
[email protected]
mmiles is offline
post #106 of 2457 Old 10-12-2019, 05:59 PM
Gooddoc's Avatar
Liked: 3603
Ugh. What can we expect for a measly 6K? I can only imagine the hardware upgrades necessary to implement individual crossovers, lol .
Not sure we can make the leap that the SDP-55 won't have individual crossovers based on that alone, but likely not a deal breaker for me regardless.
dwaleke likes this.
Gooddoc is offline
post #107 of 2457 Old 10-13-2019, 03:27 AM
Jon AA's Avatar
Quoted: 186 Post(s)
Liked: 217
I wouldn't jump to that conclusion either. To me it sounded more like the SDP-65 will offer some of the much more complex bass management options that the SDP-75 allows that go well beyond a simple crossover frequency for each speaker--I would fully expect the SDP-55 to have that capability.
Gooddoc likes this.
Jon AA is offline
post #108 of 2457 Old 10-13-2019, 03:34 AM
Liked: 1358
Considering a D&M under 1k can set individual crossovers it isn't much of an excuse to not do it on everything.
Also isn't the SDP-65 just a rebranded Altitude 16 while the SDP-75 is the Altitude 32?
Gooddoc and LydMekk like this.
post #109 of 2457 Old 10-13-2019, 03:54 AM
OsoSolitario's Avatar
Quoted: 113 Post(s)
Liked: 69
That's it (as said before)
OsoSolitario is offline
post #110 of 2457 Old 10-13-2019, 06:55 AM
mmiles's Avatar
Liked: 643
Yes, but the JBL models do not have PEQ or remapping.
JBL models will have some of the JBL and Revel speaker curves preloaded which is nice if you own or plan to buy those speakers.
Note the SDP65 and Alt16 do not have digital out.
Mike Miles
[email protected]
mmiles is offline
post #111 of 2457 Old 10-13-2019, 08:47 AM
Gooddoc's Avatar
Liked: 3603
Inclusion of Dante on the SDP-55 is a big deal IMO. Digital outs are typically expensive upgrades on already very expensive prepros. Compared to other solutions, Dante is a particularly easy to implement, about as simple as wiring can get, and the availability of interface bridges to other formats (AES/EBU and Blu-link) make it possible to use existing amps.
I'm surprised they used it on their "budget" prepro given its not available on much pricier options.
Gooddoc is offline
post #112 of 2457 Old 10-13-2019, 08:51 AM
nonstopdoc1's Avatar
Quoted: 921 Post(s)
Liked: 393
Can Dante be used on some channels and XLR on others? I mean can you mix Dante amps with regular amps or it all or none thing?
Sent from my SM-G975U using Tapatalk
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | JBL SDP-55 | Nord NC500 | ATI AT528NC | Procella P8/P5V | Revel C763L | Monolith 12" x4
Living Room - LG OLED 65" | Denon X4400H | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia 20 CC | Polk Surrounds | Rythmik FV15HP x2
nonstopdoc1 is online now
post #113 of 2457 Old 10-13-2019, 08:59 AM
Liked: 1358
Both the Altitude 16 and 32 have Audio Network ports, they just aren't enabled yet. I read somewhere that they will be enabled next year so Dante may be available there too in the near future.
post #114 of 2457 Old 10-13-2019, 10:25 AM
mmiles's Avatar
Liked: 643
Digital is hot on the Altitude 32.
While at Genelec in March they got a unit in to test.
Mike Miles
[email protected]
mmiles is offline
post #115 of 2457 Old 10-13-2019, 10:28 AM
mmiles's Avatar
Liked: 643
I would think so.
IIRC Dante (depending on the version implemented) AES67 is good to go as well.
AES3 and Blulink will need converters as Mr. Gooddoc had previously mentioned.
Mike Miles
[email protected]
mmiles is offline
post #116 of 2457 Old 10-13-2019, 11:13 AM
madhuski's Avatar
Quoted: 1661 Post(s)
Liked: 1118
I would think so.
Mike - do you know of any other (JBL 7120 aside) consumer amps that will be Dante enabled coming down the pike?
madhuski is online now
post #117 of 2457 Old 10-13-2019, 11:17 AM
mmiles's Avatar
Liked: 643
Dunno. Will poke around.
Mike Miles
[email protected]
mmiles is offline
post #118 of 2457 Old 10-13-2019, 11:20 AM
mmiles's Avatar
Liked: 643
Try Crown or QSC.
Mike Miles
[email protected]
mmiles is offline
post #119 of 2457 Old 10-13-2019, 11:37 AM
Liked: 5755
Most likely yes. On Dante audio network any Input can be routed to multiple Outputs. I'm pretty sure you would need to use Dante Editor to patch the Dante channels, though.
post #120 of 2457 Old 10-13-2019, 11:54 AM
Liked: 5755
BTW, Dante amps from Crown aren't cheap. A 8 channels Crown Dante amp is around $5500.
