Amp for a large subwoofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-13-2019, 08:10 AM - Thread Starter
pavelbarchuk's Avatar
Been out of the game for a bit, but finally dug out the subwoofer that I built and hooked it up to the home theater system. 2 15 inch TC sounds drivers in a sealed box. I have a behringer ep4000 amp, but the amp makes too much noise. Want something that will power on when the reciever goes on (12v trigger). Anything out there that puts out enough power to drive 2 15s and is home theater friendly?
pavelbarchuk is offline
post #2 of 4 Old 09-13-2019, 08:32 AM
Quoted: 557 Post(s)
Liked: 293
here's a few:
12v trigger or auto-on : https://www.parts-express.com/dayton...table--300-811
https://www.crutchfield.com/p_893IWA...o-IWA-250.html
https://www.outdoorspeakerdepot.com/smp500.html
https://www.monoprice.com/product?p_id=31029
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #3 of 4 Old 09-13-2019, 08:44 AM
eriksells916's Avatar
Quoted: 507 Post(s)
Liked: 192
Lots of good stuff, some quiet some loud. This is off the top of my head since I do not have any external amps.
What is your budget?
Do you want a plate amp or external rack mount style?
External rack/shelf Mount
Crown xti
Crown xls 1002/1502/2502 (with mini dsp)
Behringer inuke nx1000/3000/6000 (with dsp)
Plate Amps
Dayton Audio SPA1200/2400 with dsp
Ice 250x2 (minidsp)
Rythmik
Speaker Power
eriksells916 is offline
post #4 of 4 Old 09-15-2019, 08:54 AM
Archaea's Avatar
Quoted: 3880 Post(s)
Liked: 3685
Do a fan mod on the EP4000 using a Noctua fan and just keep the current amp
Then buy a 12 volt switch and plug the behringer into that.
https://www.amazon.com/Niles-AC3-FG0...ateway&sr=8-13
Or a green power supply and plug the behringer into the green plug and the AVR into the master control plug
https://www.amazon.com/TrickleStar-O...gateway&sr=8-6
Or build your own (I did this and it worked well)
https://www.avsforum.com/forum/155-d...ics.html?amp=1
Archaea's 9.8.4 Home Theater Room
(13) JBL CBT 70j-1 | Denon x7200wa | Sherbourn PA 7-350 amplifier | (8) Ultimax 18" sealed subwoofers | (4) iNuke DSP 6000 amplifiers | (4) MB Quart 12" subwoofers mounted direct mounted to Berkline theater chairs BOSS style | Epson 5040UB Projector | Jamestown 144" acoustic transparent 2.35:1 screen w/ Seymour XD fabric
Archaea is online now
