Noob Question - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By jdsmoothie
  • 1 Post By bobknavs
post #1 of 10 Old 09-13-2019, 08:58 PM - Thread Starter
Quoted: 25 Post(s)
Liked: 3
Noob Question
I hate my receiver. Time for an upgrade. How would one decide between Denon x6500h & Sony Elite vsx-lx504?
Want to replace my Cambridge Audio CXR 200 for basic operating issues like turning back on after I turn it off & input switching issues & codec, HDR limitations.
Powering 5 x Elac bookshelf speakers & 2 entry level SVS subs in a condo. Ballpark open concept living room dimensions - 12’ x 13’ x10’ (l x w x h).
The Denon would be a closer match to power. But if my basic understanding of things is correct... it’s crazy overkill.
Help?
neversummer604 is offline
post #2 of 10 Old 09-13-2019, 09:27 PM - Thread Starter
Quoted: 25 Post(s)
Liked: 3
Help?
4 ohm Elac speakers
post #3 of 10 Old 09-14-2019, 12:07 AM
jdsmoothie's Avatar
Quoted: 22557 Post(s)
Liked: 12278
That would be "Pioneer" not Sony. For moderate listening levels, there's no reason to step higher than the Denon X3500H (2018) or X3600H (2019) for a 5.2 setup.
jdsmoothie is offline
post #4 of 10 Old 09-14-2019, 08:19 AM - Thread Starter
Quoted: 25 Post(s)
Liked: 3
Oops. Brain fart. Good point, thx...
post #5 of 10 Old 09-14-2019, 08:21 AM - Thread Starter
Quoted: 25 Post(s)
Liked: 3
And if I want to turn it up? As I do for movies...
post #6 of 10 Old 09-14-2019, 09:30 AM
jdsmoothie's Avatar
Liked: 12278
You live in a condo. Doubt you're going to be able to raise the volume very loud.
post #7 of 10 Old 09-14-2019, 09:30 AM
bobknavs's Avatar
Quoted: 2328 Post(s)
Liked: 1657
Why do you compare those two?
The X6500H is a much more expensive AVR than a VSX-LX504.
Either seems excessive for a 5.2 system.
The X3500H that JD recommends seems like a reasonable choice. It's the lowest-end Denon model that includes the Audyssey XT32 room correction software. (That's the best retail version.)
The difference in power between an X3500H and an X6500H amounts to roughly 1dB. Barely audible.
If I wanted to inflict maximum annoyance on my condo neighbors, I might consider a Pioneer LX-SC model. They have Class D amplifiers, which implies the least tendency to overheat while driving 4 ohm speakers hard. There are a few models available as refurbs at accessories4less (and one available as new).
neversummer604 likes this.
bobknavs is offline
post #8 of 10 Old 09-14-2019, 12:41 PM - Thread Starter
Quoted: 25 Post(s)
Liked: 3
Denon - To match the CXR 200 & my concerns re driving 4 ohm speakers. Sony - considerably cheaper.
I have an Aircom exhaust fan sitting on top of the receiver. Think that’s enough to alleviate X3500 overheating concerns?
Regarding neighbour concerns, only had complaints from a unit 1 floor down & 1 unit over. My subs are against the wall we share. I’m ok w/turning them down/off.
post #9 of 10 Old 09-14-2019, 08:05 PM - Thread Starter
Quoted: 25 Post(s)
Liked: 3
The pioneer elite 504 & denon x3600h are the same price point. Considering 4 ohm speakers, same answer? Denon?
post #10 of 10 Old 09-14-2019, 10:28 PM
jdsmoothie's Avatar
Liked: 12278
Personal preference, although Denon comes with 3 year warranty and HDCP 2.3.
