Do I need an amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 09-15-2019, 05:32 PM - Thread Starter
genaccmiller's Avatar
Quoted: 494 Post(s)
Liked: 57
Do I need an amp?
Folks - building out my theater room. I have three JBL studio 590s for LCR, two 580s for surrounds and a Denon 4400h receiver. It is a very small room with size about 12x13. I am also prewiring for two Atmos and two rear surrounds. Do I need an amp to take over the load from my Denon and if so what amp would you recommend around $500?
Sent from my Moto G (5) Plus using Tapatalk
genaccmiller is online now
post #2 of 28 Old 09-15-2019, 05:41 PM
m0j0's Avatar
Quoted: 600 Post(s)
Liked: 597
Originally Posted by genaccmiller View Post
Folks - building out my theater room. I have three JBL studio 590s for LCR, two 580s for rears and a Denon 4400h receiver. It is a very small room with size about 12x13. I am also prewiring for two Atmos and two rear surrounds. Do I need an amp to take over the load from my Denon and if so what amp would you recommend around $500?
Your receiver can probably handle that setup without an amp, but you may want to go easy on it and add a two or three channel amp for the front 3 speakers. I have a Denon 4400 as well and added a 5 channel Outlaw 5000, with three channels powering my LCR and the other two channels powering my two BOSS mini risers.
m0j0 is online now
post #3 of 28 Old 09-15-2019, 05:43 PM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
I don't think that particular model is available at the price range I am targeting. Any recommendations?
post #4 of 28 Old 09-15-2019, 05:47 PM
m0j0's Avatar
Quoted: 600 Post(s)
Liked: 597
I got mine as a B Stock under 600 I believe, so pretty close. No other recommendations as that’s the only one I have experience with but it runs cold and quiet and gives plenty of power so I can highly recommend it.
m0j0 is online now
post #5 of 28 Old 09-15-2019, 09:34 PM
afrogt's Avatar
Quoted: 2177 Post(s)
Liked: 1442
I think you should prewire for four Atmos speakers instead and two Atmos and two surrounds.
Afro GT
afrogt is offline
post #6 of 28 Old 09-16-2019, 08:13 AM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
I have two Atmos and 4 surrounds which is split between 2 surrounds and 2 rear surrounds. Are you saying to have 4 Atmos (i.e. 2 additional) plus the current 4 surrounds I have wired for?
post #7 of 28 Old 09-16-2019, 08:43 AM
afrogt's Avatar
Liked: 1442
what I'm saying is that's is better to have 5.1.4 than 7.1.2 especially in a room that size.
But since the x4400 can actually do 7.1.4 why not wire your room for 4 overhead Atmos speakers? then you can try multiple configurations and settle on whatever you like best.
Afro GT
afrogt is offline
post #8 of 28 Old 09-16-2019, 10:01 AM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
Yes I can try this. Do I still need an amp?
post #9 of 28 Old 09-16-2019, 12:16 PM
bobknavs's Avatar
Quoted: 2334 Post(s)
Liked: 1663
I may be answering the wrong question, but...
If you go to 7.1.4, you'd need to add an external stereo amp, because the 4400 only has 9 onboard amps. (It can process 11 channels, though.) If you use it for rear Atmos speakers, it might not have to be very powerful.
Audiosource AMP100VS or AD1002, and the Dayton APA102BT, are examples. (All 3 have 12V triggers, which I prefer as the means to power up the amp when the AVR is turned on.)
bobknavs is offline
post #10 of 28 Old 09-16-2019, 12:18 PM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
So if I don't want to invest in an amp at this time (perhaps a later expense), how many channels (and which ones) should I have my Denon drive for an optimal experience? It's a very small room. So I want to start small and expand later if needed. So looking for most optimal set up without an amp.
post #11 of 28 Old 09-16-2019, 12:35 PM
afrogt's Avatar
Liked: 1442
Let your Denon drive all 9 channels in a 5.1.4 or 7.1.2 setup. Your JBL 590's have a 92db sensitivity so they don't need much power to drive them to loud volumes.
If you decide you need a 7.1.4 setup then get the audiosource amp that was mentioned above. But you said it is a small room so 9 speakers should be enough.
Where are you placing the 580's for surrounds? Surround back should be 2 feet above and behind the main listening position but you have towers so I don't see you doing that unless they are on pedestals.
https://www.crutchfield.com/S-lWHcAj...placement.html
Afro GT
afrogt is offline
post #12 of 28 Old 09-16-2019, 02:11 PM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
Left and right surrounds would be exactly on left and right of the couch. This is what I am going to use the 580s for. In addition I have two Martin Logan's that I could wall mount behind my seating. As the attached picture shows I have already anchored a mount there to put up the two if I go with a 7.x configuration. This would mean I cannot use Atmos with JUST my Denon. I have prewired for two Atmos. It's highly unlikely I will use the Atmos though given the small room. Do I need to wire for another two Atmos or can I call it a day with the wiring done for 7.2.2?
Link to my build thread - https://r.tapatalk.com/shareLink/top...ink_source=app
post #13 of 28 Old 09-16-2019, 02:38 PM
afrogt's Avatar
Liked: 1442
It's your room, if you want to go with 7.2.2. instead of 5.2.4 so be it.
Enjoy
Afro GT
afrogt is offline
post #14 of 28 Old 09-16-2019, 02:45 PM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
Enjoy
Disregarding the sub, I assume I don't need to get an amp with this set up. Between 7.x.2 vs 5.x.4 or 5.x.2 is there a preference? If I go with 5.x.x setup will the speakers to the side be positioned correctly if they are exactly on left and right of seating location?
post #15 of 28 Old 09-16-2019, 02:52 PM
afrogt's Avatar
Liked: 1442
I wouldn't buy an amp until you're sure you need more power.
the preference is 5.x.4 You'll get full immersion with 4 overhead/Atmos speakers rather than 2 rear channels and 2 Atmos.
5.1 surrounds should be on each side of main listening position no matter if it is 7.x.2, 5.x.4 or 5.x.2
https://www.avsforum.com/forum/15-ge...4-7-2-2-a.html
Afro GT
afrogt is offline
post #16 of 28 Old 09-16-2019, 03:08 PM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
I can use the Dolby set up guide for 7.2.4 position and wire them up but can use the 5.2.4 to listen while starting since it can be accommodated by my receiver without a need for a new amp.
post #17 of 28 Old 09-16-2019, 03:20 PM
Liquid$team's Avatar
Quoted: 222 Post(s)
Liked: 111
Try it out with the AVR alone first. Then (If you so desire) add a 3 channel AMP for the LCR speakers and listen for a difference. You may be able to save yourself $500 if you don't hear a difference. Just make sure you buy an AMP you can return if you feel you don't need it. The Emotiva A-500 is around $500 and has 80 watts x5 all channels driven. Or the A-300 is 150 watts x2 around $400. Just as an example
My old set up had 2 Onkyo 2 channel amplifiers running my 4 surrounds and the Onkyo AVR running the LCR..... when I was upgrading everything I sold the 2 amplifiers first and besides turning up the volume a couple notches I didn't notice any change in the sound. My room is also small like yours so maybe you won't need the AMP at all?
Projector:Epson 6050ub Screen:Elite screens manual SRM Pro series 120" TV: Vizio P75f Pre/Pro:Marantz AV7705 Amplifier:Monolith 7x and Emotiva A-700 for ATMOSSpeakers:Klipsch THX8000-L (LCR) R5800 side surrounds, 5650-S rear surrounds Klipsch 5800-C for ATMOSSubwoofers:PSA v1811x2 Bluray Player:Panasonic ub820 Media Streamer:Fire TV cube
Liquid$team is offline
post #18 of 28 Old 09-16-2019, 03:57 PM
afrogt's Avatar
Liked: 1442
Yep, I suggested that in post #7 ...
Afro GT
afrogt is offline
post #19 of 28 Old 09-16-2019, 04:01 PM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
Thank you.
post #20 of 28 Old 09-16-2019, 04:01 PM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
Thank you.
post #21 of 28 Old 09-16-2019, 04:19 PM
torii's Avatar
Quoted: 3592 Post(s)
Liked: 2026
I upgraded my avr amp to nad amps bridged and gained around 6db spl....most would say that is not a worthy 2 grand upgrade.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS
Subs: Rythmik FV25HP, Rythmik FV15HP
torii is offline
post #22 of 28 Old 09-16-2019, 05:39 PM
m0j0's Avatar
Quoted: 600 Post(s)
Liked: 597
I would also recommend the 5.x.4 over the 7.x.2 setup if you don’t plan to add an amp right way, but you should pre-wire for the full 7.x.4 setup if possible to give yourself options down the road. I have the same size room and really enjoy the 7.x.4 setup, but I didn’t start out that way. I went 5.1, then 5.1.2, then 5.1.4 and eventually 7.1.4.
m0j0 is online now
post #23 of 28 Old 09-16-2019, 05:44 PM
Quoted: 222 Post(s)
Liked: 111
Agreed on the wiring aspect. I started with a 5.2 system 10 years ago and adding the wiring for the 6 speakers that brought me up to 7.2.4 was a little messy and annoying lol. I actually had a stop over at 6.2 for a few years... then when I decided to go with atmos and 4K I realized the 6.2 setup was a dinosaur
post #24 of 28 Old 09-16-2019, 10:40 PM
355F1's Avatar
Quoted: 176 Post(s)
Liked: 42
Notice a big difference with the OUtlaw?
😎It's just life, dude. We are all gonna die sometime--Might as well try and have a kickass time while we're still here.😜
355F1 is online now
post #25 of 28 Old 09-17-2019, 03:23 AM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
I have already wired for the 7. I had only wired for 2 Atmos. It looks like I need to wire for 4 based on what I am seeing here. My spacing is kind of limited. the front couple of ceiling joists are blocked with pipes etc preventing the wiring from ending there. So I used the next available joist for the 2 speakers but am now being told I need to measure my screen, seating distance etc. Not sure how much flexibility is there with the room constraint.
Some pictures attached to show room constraint.
post #26 of 28 Old 09-17-2019, 04:27 AM
m0j0's Avatar
Quoted: 600 Post(s)
Liked: 597
You could also run wiring on the front and back walls towards the top and go with a front height / rear height atmos setup if the ceiling locations don't work for you. That's how I have my setup and I am pretty happy with it.
m0j0 is online now
post #27 of 28 Old 09-17-2019, 04:29 AM
m0j0's Avatar
Quoted: 600 Post(s)
Liked: 597
I have Polk LSiM's all around and yes, the Outlaw makes quite a difference as these speakers need power and sound like different speakers with the Outlaw vs. just the Denon powering them.
m0j0 is online now
post #28 of 28 Old 09-17-2019, 04:36 AM - Thread Starter
Quoted: 494 Post(s)
Liked: 57
Attached some pics on previous post.
