AVR recommendation - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By skylarlove1999
post #1 of 10 Old 09-21-2019, 07:07 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
AVR recommendation
Looking to upgrade from my ten year old Denon receiver that powers my five 600 series B&W speakers in my 5.1 set up. Tower speakers in the front, bookshelves in the rear.I will also be using an SVS 2000 sub. Any recommendations? Thank you
[email protected] is offline
post #2 of 10 Old 09-21-2019, 07:17 PM
skylarlove1999's Avatar
Quoted: 1043 Post(s)
Liked: 724
I believe your speakers are 8 ohm with 88db for sensitivity so as you know you don't need immense power to drive them. What is your budget? Will you be adding any speakers? Do you want an AVR( my assumption) or separates? Do you like your sound a little brighter or more warm?
Sent from my SM-G965U using Tapatalk
skylarlove1999 is offline
post #3 of 10 Old 09-21-2019, 09:55 PM
pase22's Avatar
Quoted: 3423 Post(s)
Liked: 2890
your options range from $200 to $3000. What is your budget? Do you have plans to expand beyond 7.1?
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #4 of 10 Old 09-22-2019, 06:08 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
I would like to spend under $2000.00 and may be adding two ceiling speakers, not sure yet. Definitely like a brighter sound. Also, not losing voices in a movie is most important. Looking for an AVR, not separates.
post #5 of 10 Old 09-22-2019, 06:11 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
I would like to spend under $2000.00. A 7.1 AVR should do it as I may add two ceiling speakers.
post #6 of 10 Old 09-22-2019, 06:43 AM
MRAYB's Avatar
Quoted: 281 Post(s)
Liked: 599
MRAYB is offline
post #7 of 10 Old 09-22-2019, 08:20 AM
Liked: 724
Since you liked the Denon sound for ten years I would stay with a brand you enjoy and with which you are familiar . The 2019 Denon 3600 would more then meet your needs. 9 channels of amplification and Dolby Atmos and Dolby Vision. Really great reviews.
pase22 likes this.
post #8 of 10 Old 09-22-2019, 08:46 AM
pase22's Avatar
Liked: 2890
The Denon X3600 mentioned above is a great value/performance option. You get audyssey XT32, dual sub HT, decent power, plenty of features and room for future expansion.
pase22 is offline
post #9 of 10 Old 09-22-2019, 12:56 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
Thank you, I'll look into it.
post #10 of 10 Old 09-22-2019, 12:57 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
Thank you for your suggestion. I'll look into it.
