old receiver as power amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-12-2019, 10:16 AM - Thread Starter
Quoted: 25 Post(s)
Liked: 2
can I use an old receiver as a power amp to power my atmos speakers? I have a denon 4400 as my main.
Nstd is offline
post #2 of 5 Old 10-12-2019, 11:15 AM
bobknavs's Avatar
Quoted: 2414 Post(s)
Liked: 1713
Sure, people do it often. It just requires a pair of analog audio inputs. (Maybe auxiliary inputs.)
The main awkwardness is a lack of a function to automatically turn it on when the 4400 is turned on.
If you'd like a slightly more elegant option, https://www.parts-express.com/dayton...ifier--300-593
It accepts a 12V trigger. I believe that it alternately can be operated as an auto-on device (like a powered sub).
(A 12V trigger line is simply a cable with a 3.5 mm mono male plug at each end. Cheap.)
bobknavs is offline
post #3 of 5 Old 10-12-2019, 11:17 AM
Quoted: 569 Post(s)
Liked: 295
depends. as far as the denon 4400 goes, yes. The 4400 does 11 channel processing. SO all you need out of the old receiver is 2 channels - assuming you are going to a 7.x.4 set up... otherwise you are already set for a 7.x.2 with the on board amps.
since you only need 2 add'l outboard channels, you can use any analog input on the old receiver - make sure you set the old unit to "direct" mode so it doesn't apply an y processing. Turning it on may be a manual thing if it doesn't have any 12V trigger inputs...
good luck
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Goldenear supersat 60C,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware XS
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #4 of 5 Old 10-12-2019, 11:48 AM
David Ortiz's Avatar
Quoted: 53 Post(s)
Liked: 45
Lots of threads about this:
https://www.avsforum.com/forum/91-au...ernal-amp.html
https://www.avsforum.com/forum/90-re...-question.html
https://www.avsforum.com/forum/90-re...ernal-amp.html
https://www.avsforum.com/forum/90-re...d-pre-pro.html
https://www.avsforum.com/forum/90-re...-receiver.html
and there are more...
David Ortiz is online now
post #5 of 5 Old 10-13-2019, 02:15 PM
jdsmoothie's Avatar
Quoted: 22771 Post(s)
Liked: 12419
Yup. Lots of helpful information provided on the 2017 Denon AVR's in the first 8 posts of the Owner's thread to include how to expand the X4400H from 9CH --> 11CH.
https://www.avsforum.com/forum/90-re...l#post51748569
jdsmoothie is offline
