AVR specs question - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Leeliemix
  • 1 Post By ChromeJob
post #1 of 8 Old 10-13-2019, 02:56 PM - Thread Starter
Quoted: 63 Post(s)
AVR specs question
I was looking for something in the datasheet of my AVR and noticed this:
Does that mean it will/can never amplify anything < 20Hz and > 20Khz?
Also, the output power is listed as 130 Watt per channel, but 1 channel driven. How does that translate to effective power per channel when running a 5.1 setup? No idea how this should be interpreted..
Bnaan is offline
post #2 of 8 Old 10-13-2019, 03:05 PM
Quoted: 297 Post(s)
Liked: 146
It doesnt do only between it just shows that between those frequencies they are max +1 to -3dB off a perfectly flat response.
It would have been nice if they gave the powersupply spec.
Bnaan likes this.
Leeliemix is offline
post #3 of 8 Old 10-13-2019, 03:10 PM
Quoted: 297 Post(s)
Liked: 146
It doesnt say very much at all, 6ohm 1kHz tone is a very misleading way to measure. It should at least be 8ohm 20hz-20khz. But all channels running is not that accurate either because the front 3 do a lot more than the rest (the .1 sub is active) so thats where you want the power, the surrounds or atmos channels need very little compared.
post #4 of 8 Old 10-13-2019, 03:16 PM
Russ_64's Avatar
Quoted: 41 Post(s)
Liked: 32
These specifications are very misleading, go to YouTube and watch the video by Audioholics on AVR power ratings. They do independent testing and are now calling on all makers to quote All Channels Driven values. 1 channel @ 6 Ohms is far from the more usual 2 channels @ 8 Ohms values, but still not as useful as 5 or 7 channel numbers.
Panasonic TX-65GZ950B, Oppo UDP-203, Musical Fidelity M3i, Marantz SR7013, 5.1.2 - Dali Oberon 5, Oberon Vokal, Oberon 1, Alteco C-1, BK P12-300SB-PR, Apple TV 4K, Sky Q (UHD/Atmos), Sky Fiber Max (80/20).
Russ_64 is offline
post #5 of 8 Old 10-13-2019, 08:27 PM
ChromeJob's Avatar
Quoted: 2113 Post(s)
Liked: 1106
The spec says up to 50 kHz. If you can hear in that range, you're a marvel of evolution.
Hetfieldjames likes this.
"Exceedingly odd," said the butler.
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
A: Yamaha RX-V775; Chromecast Audio; iPod Classic, Touch. Bose 401 mains, 301 Series III surrounds, Yamaha NS-C444 center, Hsu VTF-2 Mk4.
V: Panasonic DMP-BDT215, Yamaha DVD-S550. Apple TV 4gen. Chromecast 1gen, Samsung UN40ES6150.
ChromeJob is offline
post #6 of 8 Old 10-14-2019, 10:55 AM - Thread Starter
Quoted: 63 Post(s)
Thanks for the replies!
Bnaan is offline
post #7 of 8 Old 10-14-2019, 11:19 AM
M Code's Avatar
Quoted: 1127 Post(s)
Liked: 733
1 spec is for power bandwidth, the other spec is for frequency response.
The frequency response spec is always wider, but is based on much lower levels not rated power output..
Just my $0.02...
M Code is offline
post #8 of 8 Old 10-14-2019, 12:34 PM
DonoMan's Avatar
Quoted: 246 Post(s)
Liked: 194
Frequency response will roll off, so aside from it actually saying 20Hz to 50kHz as already mentioned in a previous reply, it will actually amplify beyond that range (on both ends). Just that it will roll off so the response won't be flat. On the upper end a lot of the reason for that is capacitors (and inherent capacitance in transistors, and in cables and PCB traces and such) and may be intentional to prevent artifacts like ringing in some situations.
As for the x-channels-driven power, it really depends. The amplifier has a power supply that can supply only a certain amount of power, and each amp channel is rated separately. If the power supply can supply enough power for all of your amp channels, then you would have no difference in power regardless of how many channels driven. But in the real world, manufacturers save money, space, and weight by making the assumption that most people will never need to drive all of their channels to full power at any given time. But there is no specific formula for this, because it just depends on what the manufacturer does.
If they put a 500 watt power supply in, and you had 5 channels of 100 watt amplifiers, then you could do 100 watts per channel regardless of 1-5 channels. But if they put a 400 watt power supply in then you could do 100 watts into 4 channels, or 80 watts into 5 channels, etc. Actually it gets a bit more complex because we also have to discuss amplifier efficiency - the numbers above would apply to a 100% efficient amp (which doesn't exist). And an amp's efficiency varies.
(Don't use the power consumption rating on the back as the size of the power supply, either, because it's not an exact number.)
DonoMan is offline
