Pioneer SR+ compatibility with either RC5 or RS232? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 10-20-2019, 11:47 AM - Thread Starter
Liked: 1
Hi - I have an older Pioneer Plasma PRO-FHD1 monitor and it has a SR+ In/Out 3.5MM connection. I believe that is a proprietary Pioneer interface...
Does anyone know if that is compatible with either RC-5 or RS232 protocol?
I am looking at home theatre hub (URC MX-10) and it has both RC-5 and RS232 outputs.
I am currently using a Harmony universal hub system, but it correctly turns the TV On/Off about 50% of the time, so I am thinking about moving to a direct wire/control setup instead of relying on IR.
Thanks to anyone who knows.
randy9999 is offline
