BUDGET Class D amplifier for Jamo A 102 HCS micro cube speakers - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By MRAYB
post #1 of 4 Old 10-21-2019, 01:53 AM - Thread Starter
super kermit's Avatar
Quoted: 71 Post(s)
https://www.jamo.com/products/a102
For PC use only
Youtube etc
As small amp as possible BUDGET up to $75 US aliexpress is ok
Weight (Kg/lb) 0.8/1.8
Frequency Response 150Hz-20,000Hz +/-3dB
Tweeter (mm/in) 19/.75
System Type 2-way, sealed
Impedance 6
Power Handling 60W (long term)/80W (short term)
Woofer (mm/in) 76/3
Sensitivity 86dB (2.8V/1m)
Product dimensions (mm/in, HxWxD) 91x91x92/3.6x3.6x3.7
Would like a small cheap amp to run two speakers for L and R stereo
Nobsound, etc from aliexpress will be fine
Headphones 90% of the time.
super kermit is offline
post #2 of 4 Old 10-21-2019, 03:41 AM
MRAYB's Avatar
Quoted: 280 Post(s)
Liked: 598
MRAYB is online now
post #3 of 4 Old 10-22-2019, 11:46 PM - Thread Starter
Quoted: 71 Post(s)
Originally Posted by MRAYB View Post
TDA7498E 2 Channel Stereo Audio Amplifier Receiver Mini Hi-Fi Class D Integrated Amp for Home Speakers 160W x 2 + 24V Power Supply
So I ordered it, thanks for the help
post #4 of 4 Old 10-23-2019, 01:23 AM
MRAYB's Avatar
Quoted: 280 Post(s)
Liked: 598
Good deal. At one point I used one for my Zone 3 on my Denon X4400H. It powered a pair of Polk T-50 towers just fine in my home office off my main room. I have recently bought a used Yamaha receiver that I put in the office, (did away with Zone 3), so the amp is currently not being used. They are nice little units. I put it up for now until I can find somewhere to put it back to work. Good luck
eriksells916 likes this.
MRAYB is online now
