Useful Dolby Atmos Test file I Created 5.1.4 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By EB1000
  • 1 Post By EB1000
post #1 of 16 Old 10-25-2019, 07:19 AM - Thread Starter
EB1000's Avatar
Quoted: 199 Post(s)
Liked: 35
Thumbs up Useful Dolby Atmos Test file I Created 5.1.4
Hi
I edited the original 5.1.4 Atmos test tones from the Dolby demo BD. Made each pink noise burst shorter instead of the original 1 minute long bursts, then I looped the video 5 times and re-encoded it into HEVC MKV.
Download link:
http://bit.do/DA514
I will later create 5.1.2 and 5.1.6 as well as 7.1.6 test files. I'm also working on my own atmos test files.
Enjoy
asabrag and m0j0 like this.
EB1000 is online now
post #2 of 16 Old 10-25-2019, 07:20 AM - Thread Starter
EB1000's Avatar
Quoted: 199 Post(s)
Liked: 35
Reserved
post #3 of 16 Old 10-25-2019, 07:37 AM
skylarlove1999's Avatar
Quoted: 1464 Post(s)
Liked: 1147
Thank you for sharing
Sent from my SM-G965U using Tapatalk
skylarlove1999 is online now
post #4 of 16 Old 10-25-2019, 08:09 AM
tinman143's Avatar
Quoted: 84 Post(s)
Liked: 30
Stud. Thank you very much. Will try it out tonight.
tinman143 is offline
post #5 of 16 Old 10-25-2019, 08:18 AM
pbz06's Avatar
Quoted: 1341 Post(s)
Liked: 1074
Dumb question, but that Dolby test at 85dB or 75dB?
Sony XBR-77A9G / Panasonic DP-UB9000 / Marantz SR7011 / Def Tech 9060 Series
pbz06 is online now
post #6 of 16 Old 10-25-2019, 08:23 AM - Thread Starter
EB1000's Avatar
Quoted: 199 Post(s)
Liked: 35
I did not alter the original loudness in any way. So whatever was on the original Dolby demo disk, remains the same. It does not state the target SPL...
pbz06 likes this.
post #7 of 16 Old 10-28-2019, 10:03 AM
thepiecesfit's Avatar
Quoted: 258 Post(s)
Liked: 139
Is there any test tone you can share for just 5.1? I'm not there on Atmos yet but would love to verify my Audyssey calibration.
HT: LG C8 65" | Denon X4440H | Left/Right: Polk LSiM 705 (2) | Center: Polk LSiM 706c | Rears: Polk FXi A4 (2) | Sub: Rhytmik E15HP | Amp: Outlaw 2200 (3)
thepiecesfit is online now
post #8 of 16 Old 01-02-2020, 01:46 PM
Quoted: 51 Post(s)
Liked: 1
Originally Posted by EB1000 View Post
Hi
Download link:
http://bit.do/DA514
Enjoy
Hi! Thanks for the file! Great for adjusting the channels of my LG SL10YG soundbar, including the rear speakers. Do you have the 7.1 version of it? Either the original or one you created? Wasn't able to test the side firing surrounds of my soundbar with a 5.1.4 file, as only a 7.1 file seems to bring those into play.Thanks!
WkittySkittyLBoF is offline
post #9 of 16 Old 01-02-2020, 03:00 PM
noah katz's Avatar
Quoted: 2303 Post(s)
Liked: 849
Might you be able to create a 9.1.4 version?
Hi
Download link:
http://bit.do/DA514
Enjoy
Noah
noah katz is online now
post #10 of 16 Old 01-02-2020, 03:21 PM
Quoted: 51 Post(s)
Liked: 1
The file should work just as good for 5.1, only difference is when it's playing the overhead channels it will be silent on your system.
post #11 of 16 Old 01-07-2020, 05:46 PM
Quoted: 182 Post(s)
Liked: 37
Hi
Download link:
http://bit.do/DA514
Enjoy
I downloaded this & copied to my USB stick and tried playing it from my Bluray player but it says file corrupted or not supported.
Any idea please?
Newuser2018 is offline
post #12 of 16 Old 01-07-2020, 07:10 PM - Thread Starter
EB1000's Avatar
Quoted: 199 Post(s)
Liked: 35
Any idea please?
Old blu-ray players do not support hevc encoding. Only those that support 4k hdr blurays will work. Use any other media player with 4k support or use kodi on a desktop pc.
Sent from my Redmi Note 4 using Tapatalk
post #13 of 16 Old 01-09-2020, 10:27 AM
Quoted: 182 Post(s)
Liked: 37
Thanks. I think this explains all. My Bluray player is Sony BDP-S5200 & does not seem to support 4K.
Can i try playing this in my USB connected to my Receiver (Yamaha RX-A780) directly?
post #14 of 16 Old 01-09-2020, 11:57 AM - Thread Starter
EB1000's Avatar
Quoted: 199 Post(s)
Liked: 35
No. Receivers do not support playback of video files. I'll recommend getting either an Apple TV 4k or Nvidia shield TV. The later will play any 4k blueray via Kodi
post #15 of 16 Old 01-09-2020, 01:26 PM
Quoted: 51 Post(s)
Liked: 1
I just played it on my laptop and plugged the HDMI cable into my soundbar and it worked perfect. It also worked on a USB drive plugged directly into my LG 4K TV over ARC to my soundbar.
post #16 of 16 Old 02-15-2020, 12:07 AM
Liked: 0
Any progress on the 5.1.2 test file?
bigdog5656 is offline
