choosing an amp for Dali Oberon 5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-09-2019, 11:33 AM - Thread Starter
Liked: 0
Hu guys, any ideas what amp to choose for Dali Oberon 5 ?
Mostly for listening all kinds of music except classics.
abam is offline
post #2 of 5 Old 11-09-2019, 01:47 PM
pase22's Avatar
Quoted: 3426 Post(s)
Liked: 2890
Depends on
1) Budget?
2) Availability? Where are you located?
3) Do you already have a pre-amp/processor/AVR?
4) Exclusive 2 channel setup or part of a multi purpose multi channel setup?
5) How loud do you listen?
5) How many channels do you need?
6) Will there be a subwoofer(s)?
Kef LS50,Q200C, Q100, SVS SB-2000, Denon AVR-X3400H, NAD 216, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, Bic F-12, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #3 of 5 Old 11-10-2019, 01:14 AM
GIEGAR's Avatar
Quoted: 1003 Post(s)
Liked: 1697
In your other post, you mention you've got an Onkyo TX-NR737. There's nothing wrong with that.
GIEGAR is offline
post #4 of 5 Old 11-10-2019, 04:34 AM - Thread Starter
Liked: 0
Originally Posted by pase22 View Post
Depends on
1) Budget?
Thanks for your reply, adding the details below:
1) up to $1000
2) Russia, Msocow
3) No, just onkyo 737 as GIEGAR mentioned below. I also have rotel 1592 but it's in my other room with other set up.
4) I actually have Dali Oberon 5 5.1 package but for tv I'm going to use onkyo 737, amp needed for stereo 2.0 only. Or do you also think Onkyo 737 is good enough for the acoustic for stereo also?
5) answered in 4). If not, then not sure I got you correctly.
6) Yes, but don't think will be using it in stereo mode.
Forgot to mention the room is small, just 12 square meters 130ft²
Thanks GIEGAR,
do you think Onkyo 737 is good enough for stereo only? I heard AV receiver isn't the best option in stereo and even budget amps are much better then more expensive AV receiver when it comes to stereo mode.
abam is offline
post #5 of 5 Old 11-10-2019, 05:58 AM
pase22's Avatar
Liked: 2890
1) up to $1000
2) Russia, Msocow
Thanks GIEGAR,
Your Onkyo will drive them easily, but being 6ohm speakers they likely dip below 4ohms. A good robust amp would certainly help, but your Onkyo doesn't have pre-outs so you would need to upgrade your receiver if you want an external amp. Adding a sub would certainly take the strain off both the speakers and AVR.
pase22 is offline
