Denon AVR-X1500H or Yamaha RX-V685 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By pase22
post #1 of 6 Old 11-15-2019, 09:23 AM - Thread Starter
Quoted: 195 Post(s)
Liked: 38
Hi,
What would you choose between these 2 if sound quality is preference?
As far as I see in review, only difference is in HDMI output of 2 in Yamaha Vs 1 in Denon unless i miss something.
thanks in advance
Newuser2018 is offline
post #2 of 6 Old 11-15-2019, 10:47 AM
eriksells916's Avatar
Quoted: 803 Post(s)
Liked: 293
@Newuser2018 What speakers do you have? Do you need more than 7 channels? Do you have a subwoofer?
both are good entry level receivers.
Yamaha has dual hdmi out, zone 2 preouts, LR preouts for adding an external amp and musiccast wireless ecosystem.
Denon has a little more advanced room correction in audyssey xt, detachable power cord and heos eco system.
eriksells916 is offline
post #3 of 6 Old 11-15-2019, 11:29 AM - Thread Starter
Quoted: 195 Post(s)
Liked: 38
I need to buy speakers anyway.
First i thought i can buy a Receiver and then speakers? Or first i should identify speakers and then receiver?
The reason is, somehow I wanted to buy Yamaha
post #4 of 6 Old 11-15-2019, 12:42 PM
M Code's Avatar
Quoted: 1179 Post(s)
Liked: 778
Check and compare closely the features of each...
But a couple of points are clear, Yamaha is #1 for reliability and the only AVR brand whose product is HDMI/HDCP certified..
Having HDMI/HDCP certification is crucial to assure the best interoperability between HDMI components...
Just my $0.02...
M Code is offline
post #5 of 6 Old 11-15-2019, 12:42 PM
Quoted: 803 Post(s)
Liked: 293
@Newuser2018 always get the best speakers you can afford, then get a good sub and then use whatever is left to get the best avr you can.
post #6 of 6 Old 11-16-2019, 03:54 AM
pase22's Avatar
Quoted: 3854 Post(s)
Liked: 3313
The better the speakers the better the sound. Speakers will have much more impact on sound quality than the AVR. In short, good speakers will sound good on a $200 AVR and cheap crap speakers will still sound like crap on a $2000 flagship AVR. Shop accordingly.
eriksells916 likes this.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Emotiva A-300, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
