Newbie need advise - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Noel25
post #1 of 12 Old 11-17-2019, 03:53 PM - Thread Starter
Noel25's Avatar
Liked: 1
Newbie need advise
Hi guys need advise please i have a bookshelf speakers and a denon 2 channel 100watts audio and av receiver attached to my 4k tv and 4k Blu-ray player. Ask please to add power and better sound quality what should i need? Amplifier or integrated amplifier? Thanks
Noel25 is offline
post #2 of 12 Old 11-17-2019, 03:53 PM - Thread Starter
Noel25's Avatar
Liked: 1
Any advice please!?
Noel25 is offline
post #3 of 12 Old 11-17-2019, 04:02 PM
nonstopdoc1's Avatar
Quoted: 681 Post(s)
Liked: 198
What's the model of Denon? and what speakers do you have?
If AVR has preouts than you can add an amplifier if you want to but not an integrated amplifier.
Sent from my SM-G975U using Tapatalk
My Build Thread
HT - Seymour Centerstage XD 2.39:1 133" W| JVC X790R | Denon AVR | Nord NC500 | ATI AT528NC | Procella P8/P5V | Revel C763L | Monolith 12" x4
Living Room - LG OLED 65" | Yamaha 2060 | Monolith 3x200 | KEF Q900 L/R | Paradigm Millenia 20 CC | Polk Surrounds | Rythmik FV15HP x2
nonstopdoc1 is online now
post #4 of 12 Old 11-17-2019, 04:04 PM
Darren Chan's Avatar
Quoted: 108 Post(s)
Liked: 34
You might want to be more detailed in what equipment you currently have, what you use it for, what you feel is lacking, as well as details in what you're room is like.
For example, if you're main use is HT, you're happy with volume and clarity of your mids and highs, and your receiver has a sub out, you may just need 1 or 2 subwoofers to round it out.
Marantz SR7013, Polk Signature S60s/S30/S15s/HTS12s, Polk MC80 (x4), AC Infinity T9/S9, AAB4 HTPC, Panasonic DP-UB420K...still to come - 82"-85" 4K QLED or eqv.
Darren Chan is offline
post #5 of 12 Old 11-17-2019, 04:09 PM
petew's Avatar
Quoted: 65 Post(s)
Liked: 126
Please describe your electronics, speakers and your listening space. Speaker placement is a zero cost option that can greatly increase sound quality. Listening room acoustic treatments can be very inexpensive with huge benefit. Inexpensive equipment in a good room will sound better than the most expensive equipment in a crap room. Adding a subwoofer could improve your sound quality a lot too. It'll take load off the bookshelf speakers and Denon amplifier. Please list model numbers of your equipment. Upload a photo or two too.
Adding amplification will not help sound quality unless you are driving your receiver into distortion, which is unlikely unless you're really cranking it. Pick the low hanging fruit first. Placement and room treatments.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #6 of 12 Old 11-17-2019, 04:38 PM - Thread Starter
Noel25's Avatar
Liked: 1
Thanks a lots guys
Noel25 is offline
post #7 of 12 Old 11-17-2019, 04:47 PM
eriksells916's Avatar
Quoted: 642 Post(s)
Liked: 243
@Noel25
What speakers do you have?
What Denon receiver do you have?
Do you like 2 channel music more, movies more or mix 50/50?
eriksells916 is offline
post #8 of 12 Old 11-17-2019, 04:50 PM - Thread Starter
Noel25's Avatar
Liked: 1
Thanks for the reply guys a denon dra 800h 2 channel and a bowers 606 in my living in my apartment i think its bcoz of my apartment settings which is open directly to my kitchen. Thanks again
Noel25 is offline
post #9 of 12 Old 11-17-2019, 05:32 PM - Thread Starter
Noel25's Avatar
Liked: 1
Noel25 is offline
post #10 of 12 Old 11-18-2019, 07:30 AM
Quoted: 681 Post(s)
Liked: 198
Your DRA-800H should have ample power to drive your B&W 606 bookshelf speakers. Your AVR doesnt have preouts so you wont be able to add an amplifier if you want to (unless you use Zone 2 out) but I dont think you need it either.
You should consider adding a subwoofer if you don't have one. That will make the most impact in your setup IMO
My Build Thread
post #11 of 12 Old 11-18-2019, 08:43 AM - Thread Starter
Noel25's Avatar
Liked: 1
Thanks a lot nonstopdoc1 for the advise i just ordered Klipsch Reference R 10SWi wireless subwoofer at Crutchfield
nonstopdoc1 likes this.
Noel25 is offline
post #12 of 12 Old 11-18-2019, 02:51 PM - Thread Starter
Noel25's Avatar
Liked: 1
Thank you all guys
Noel25 is offline
