Yamaha RX-A820 and older sub - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-18-2019, 05:47 PM - Thread Starter
Liked: 0
I am unable to get an older PSB Alpha Subsonic 1 subwoofer to work on my RX-A820. I have two of these subs and they work fine on older Yamaha receivers. I have tried both without any luck. I believe I am probably missing something really simple. I have connected using the subwoofer 1 out on the RX-A820 and plugged into the R input on the Alpha Subsonic. When I run the manual speaker setup on the receiver I do not hear any test tone when it cycles through to the sub. I know these are older model units but I am hoping someone might offer some advice here. Thank you!
Gord MacDougall is offline
post #2 of 4 Old 11-18-2019, 11:34 PM
bobknavs's Avatar
Quoted: 2451 Post(s)
Liked: 1743
Stupid question: have you turned on the sub output in the RX-A820's settings? I don't know whether it defaults to "off". The AVR will not automatically detect whether a subwoofer is connected.
bobknavs is online now
post #3 of 4 Old 11-20-2019, 02:43 AM - Thread Starter
Liked: 0
Thanks Bob, not a stupid question. I did check and it is on. I have the subwoofer set to “use” in the configuration. I am wondering if there is any easy way to determine if there is output from the sub connections or if it may be an internal problem.
post #4 of 4 Old 11-20-2019, 09:45 AM
bobknavs's Avatar
Liked: 1743
I'm out of guesses.
Do the PSB subs have the standard power switch: off, on, and auto?
If yes, and you have it set to "auto", try "on".
