Audyssey - Integra DTC 9.8 and REW mesurements - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-20-2019, 10:55 AM - Thread Starter
thejck's Avatar
Quoted: 17 Post(s)
i have an old receiver that I am reluctant to upgrade cause there are a few other pieces of equipment I want to buy first. I have gotten around he 1080P limitation by using dual hdmi for video and audio.
I build a IB sub for my room and while trying to equalize it and adjust phase I decided to run Audyssey for the first time. (i know i was just lazy). Anyway I am listening to some music and adjusting the bass response gain and I am thinking to myself. these polk rti12 speakers sound really really good.
Comparatively I have some highly upgraded polk sda 1.2 tl's that sounded like crap. These are fed from a separate stereo preamp with no processing. This doesn't make sense to me.
I decided to get REW up and running and measure my left and right rti12 speaker frequency response using a behringer ecm 8000 mic and a usb mic preamp.
Here is the head scratcher that I cant get around. my REW graph with the mic in the same location look exactly the same with the integra receiver equalizer set to "OFF" "Audyssey" or "manual with all 0 values.
What am i missing here? is this expected. did REW not do anything for the equalizer perhaps?
Is what I am seeing in REW off?
or is my receiver BROKEN.
thejck is offline
post #2 of 3 Old 11-20-2019, 12:45 PM
Alan P's Avatar
Quoted: 6710 Post(s)
Liked: 6266
On some AVRs, you have to back out of the menu for the new setting to take effect. Could be the issue.
Do you hear a difference between the different Audyssey settings??
Alan P is offline
post #3 of 3 Old 11-20-2019, 12:49 PM - Thread Starter
thejck's Avatar
Quoted: 17 Post(s)
at first I thought I did. but now I am not so sure. I will have to do a blind test with some friends.
when you say back out of the menu.. i had to get out of the setup menu in order to start playing any audio again.
for kicks last night i went ahead and did a factory reset on my receiver. now audyssey is no longer an option in the equalizer. so i am going to do some rew tests for each speaker and then do audyssey setup and test again and test again with the eq set to off.
thejck is offline
