Sub not working when upconverting stereo to 5.1 on an old receiver. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-20-2019, 11:02 AM - Thread Starter
tentaguasu's Avatar
Quoted: 18 Post(s)
Any ideas on why I can't get my sub to work when my older receiver is "upconverting" stereo to 5.1?
I have an old Pioneer VSX-D912 receiver which does not have any HDMI inputs. As a result, I've determined that it's pretty much impossible to get 5.1 sound out of a streaming device and into the receiver (all the HDMI to optical/digital options cannot handle Dolby Digital Plus). Therefore, I'm simply plugging my Roku streamer into my (also old) projector, and running the simple RCA red/white stereo cables out of the projector and into my receiver (I think in the VHS input).
I'm resigned to the fact that I won't actually get 5.1 surround sound, but it was my understanding that the receiver could take the stereo and simulate 5.1 to some degree. I turn on Dolby Pro Logic Movie option, and sure enough, the center channel starts pumping out sound.
The sub, however, is dead as a doornail. In reality, I'm 100% fine with only the R and L fronts working with no center or surrounds. My my concern is the subwooofer.
Any ideas about why the sub isn't working or how to get it working?
I'd prefer not to mess around with the speaker set up generally, as I'm happy with how the system performs with other inputs (e.g. blurays)
Any help is appreciated!
tentaguasu is offline
post #2 of 5 Old 11-20-2019, 11:17 AM
Quoted: 447 Post(s)
Liked: 240
Are center and main speakers set to large?
Leeliemix is offline
post #3 of 5 Old 11-20-2019, 11:20 AM
afrogt's Avatar
Quoted: 2261 Post(s)
Liked: 1490
As said above your speakers need to be set to SMALL in the speaker configuration setup menu. Then lower frequencies will be passed on to the subwoofer. even from stereo sources.
Afro GT
afrogt is offline
post #4 of 5 Old 11-20-2019, 11:20 AM - Thread Starter
tentaguasu's Avatar
Quoted: 18 Post(s)
Not sure, I'll have to check when I get home. I don't believe so.
If they are, would that prevent the sub from working? (I guess perhaps by sending all low frequency to the speakers?)
Also, if I change that, would it negatively affect my normal use of the system when I do have 5.1 input?
post #5 of 5 Old 11-20-2019, 11:25 AM
afrogt's Avatar
Liked: 1490
Nope, will only make things work better even for 5.1 material.
Afro GT
afrogt is offline
