Denon AVR-3805 - Optical Terminal Input Query - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-23-2019, 04:11 PM - Thread Starter
Liked: 0
Can you please help?
I have a Denon AVR-3805, and an TV LG 65SM8100PTA. I want to connect an Optical cable out from the TV into the Denon Receiver.
Which optical terminal do I input the optical cable into the Denon?
The manual is very ambiguous regarding the optical terminals.
Rear Panel Top section:
Terminal OPT-3 ?
Terminal OPT-4 is an Input
Rear Panel Below section:
Terminal OPT-1 is an Output
Terminal OPT-2 ?
Terminal OPT-3 ?
Terminal OPT-4 is an Output
Notes from manual
The OPTICAL 3 and 4 terminals on the AVR-3805’s rear panel
are equipped with an optical digital output terminal for
recording digital audio signals to a CD recorder, MD recorder, or
other digital audio recording deck. Use this for digital recording
between a digital audio source (stereo – 2 channel) and a digital
audio recorder.
Do not connect the output of the component connected to the OPTICAL 3, 4 OUT jack on the AVR’s 305’s rear panel to any other jack other than the OPTICAL 3, 4 IN Jack.
Which OPT terminal do I input the optical cable from the TV output?
Angel8888 is offline
post #2 of 7 Old 11-23-2019, 06:16 PM
M Code's Avatar
Quoted: 1132 Post(s)
Liked: 735
See page 14 of the Operation Manual...
1.Select TV as a SOURCE
2.Select OPT 1 as an Input
Connect the Optical cable from the TV OPT Out to the Denon OPT 1 Input.
Just my $0.02...
M Code is offline
post #3 of 7 Old 11-23-2019, 08:39 PM - Thread Starter
Liked: 0
Just my $0.02...
Just as I thought, the manual on page 7 diagram showed OPT-1 as an OUTPUT but in fact it should be an INPUT as stated in your post.
Thank you very much for your response M Code.
Further, any suggestion how to configure OPT-1 to work?
Thanks again
post #4 of 7 Old 11-23-2019, 09:55 PM
jdsmoothie's Avatar
Quoted: 23202 Post(s)
Liked: 12731
Thanks again
The page 7 diagram actually shows OPT-1 as an "input" with the "output" of an external device connected to it.
On that same page, for Digital input assignment it refers you to p. 39, where you can see the image which shows you can assign OPT-1 to the "TV" source on the remote.
jdsmoothie is offline
post #5 of 7 Old 11-23-2019, 11:36 PM - Thread Starter
Liked: 0
Thanks for the clarification. Now I understand what you mentioned above.
Yes. 3-1 Setting the Digital In Assignment.
In Step 2 Display the Digital Inputs screen:
Showing:
Digital In
CD : COAX1
So I change to
Digital In
TV :OPT1
Is this correct?
Thank you jdsmoothie
post #6 of 7 Old 11-23-2019, 11:51 PM
jdsmoothie's Avatar
Liked: 12731
Showing:
Digital In
CD : COAX1
So I change to
Digital In
TV :OPT1
Is this correct?
Yup.
post #7 of 7 Old 12-03-2019, 09:53 PM - Thread Starter
Liked: 0
Yup.
I received my Optical Audio Cable today, and followed the setup responses by jdsmoothie and M Code.
It work fine. Thank you both. It is greatly appreciated.
Closed Thread Receivers, Amps, and Processors
