Marantz sr6014 vs Denon avr-x4500h - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 11-25-2019, 07:27 PM - Thread Starter
Liked: 0
I think I have it narrowed down to these two but I am open to other suggestions.
I’ll be pairing whichever receiver I get with two SVS ultra bookshelves, an ultra center, and four sonance 6 1/2” in ceilings (2 for Atmos and 2 for rear).
It will be in the living room and used for music and movies.
They look to be pretty close and are about the same price. Any thoughts? Thanks!
_carny is offline
post #2 of 11 Old 11-25-2019, 07:50 PM
eriksells916's Avatar
Quoted: 803 Post(s)
Liked: 294
@_carny both have xt32 and either would be a great choice. You might even be able to get away with last years x3500h, which is the 7 channel little brother of the x4500.
If you want the 9 channels, the x4500 has more power, auro3d and zone 2 and 3 preouts while the sr6014 is more musical with hdam circuits and 7 channel analog inputs.
Again, you can't go wrong either way!
eriksells916 is offline
post #3 of 11 Old 11-26-2019, 01:56 AM
jdsmoothie's Avatar
Quoted: 24608 Post(s)
Liked: 13833
The 2019 Marantz SR6014 is the sister model to the 2019 Denon X3600H while the 2018 Denon X4500H is a higher level model comparable to the Marantz SR7013. Review post 1 of each of the 2018 and 2019 Denon/Marantz AVR Owner's threads to determine if you want any of the additional features provided on the 2019 models vs. the additional features provided by the higher level (but older) X4500H.
As suggested above, if you don't plan on expanding beyond a 5.1.2 setup (noting your in-ceiling rear speakers won't provide for an ideal Atmos setup as they ideally should be on the floor and thus vertically separated from the middle in-ceiling speakers which will be configured as Top Middle), the 2018 Denon X3500H should also be a consideration for additional cost savings.
jdsmoothie is offline
post #4 of 11 Old 11-26-2019, 06:18 PM - Thread Starter
Liked: 0
Thank you! I hadn’t looked at the 3500 but it looks like it would satisfy my needs. The other two have a few more watts, would it be worth the extra cost?
_carny is offline
post #5 of 11 Old 11-26-2019, 08:14 PM
Quoted: 803 Post(s)
Liked: 294
@_carny No. the x3500 has full preouts, so you can always add amps down the road when you become deaf
post #6 of 11 Old 11-27-2019, 11:53 AM
Liked: 2
Marantz has 3-year warranty and Denon has only 2-year warranty. With the added complexity there is more to fail with current AVR's and an extra year of factory coverage would be appealing to me. I had a Denon 4300H and it failed twice in the 2.2 years I used it.
Reliability is important to me and so in the future I will be probably be buying a Yamaha or Marantz AVR. I always look at owners' reviews on multiple websites to get a good picture of the problems encountered and failure rates.
Difficult to get enough reviews to evaluate until a new product has been out on the market for more than a few months so a newly introduced product is a higher risk one to buy. Too early to say for the Marantz 6014 but the Denon 4500H has a less than favorable review profile on Amazon from people who have bought the receiver.
Calsun is offline
post #7 of 11 Old 11-27-2019, 02:23 PM
Quoted: 803 Post(s)
Liked: 294
@Calsun I believe both have 3 year warranty.
post #8 of 11 Old 11-27-2019, 03:45 PM
Darren Chan's Avatar
Quoted: 116 Post(s)
Liked: 34
A lot of failures are heat related. Is it housed in a cabinet?
Marantz SR7013, Polk Signature S60s/S30/S15s/HTS12s, Polk MC80 (x4), AC Infinity T9/S9, AAB4 HTPC, Panasonic DP-UB420K...still to come - 82"-85" 4K QLED or eqv.
Darren Chan is offline
post #9 of 11 Old 11-27-2019, 04:54 PM
jdsmoothie's Avatar
Liked: 13833
All Denon USA/CA "X" models (eg. X4500H) feature a 3 year warranty. I would consider the current 4.1/5 rating for the X4500H on Amazon USA as fairly favorable.
post #10 of 11 Old 06-03-2020, 03:38 AM
Soccerdude's Avatar
Quoted: 421 Post(s)
Liked: 187
I think Marantz has eARC if I am not mistaken
HT: JVC RS2000, S Studio Tek 130 1.3 Gain screen, , Panasonic UB820. Denon X6500. Def Tech X9080 series . BR: OnkyoTX696 , LG OLED 65 8 series , Def tech 9020 5.2 .
Soccerdude is offline
post #11 of 11 Old 06-03-2020, 03:27 PM
jdsmoothie's Avatar
Liked: 13833
As does the X4500H as well.
