NAD C658 competition/alternatives - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-27-2020, 08:52 PM - Thread Starter
Quoted: 65 Post(s)
Liked: 24
I did a search and didn't find any applicable threads, sorry if this is a common topic. I've been fighting my NADS C658 for 6+ months as it is plagued by numerous bugs and tends to be a bit analytical while I prefer a more rich/luscious sound.
Assuming a budget of ~$2k USD or less, what are some good options for a pre-amp/streamer/DAC combo aside from the C658?
Options I've found so far:
- TEAC NT-505 - sounds like a unit focused on build and sound quality rather than extras like DIRAC or multiple analog/digital inputs
- Cambridge Azure 851N - this seems like a perfectly capable unit, but for some reason just doesn't jump out at me
Listening room is:
- 2-channel audio only
- Music only either streamed from Tidal or network share
- Towers - Monitor Audio Gold 300 5G
- Amp - Emotiva XPA3 DR2 (via XLR)
- Sub - Golden Ear Super Sub-X (via RCA with crossover set on the sub)
Hard requirements:
- Pre-amp / DAC / streamer combo
- Both balanced and unbalanced outputs
- Android app enabled for playback and volume control
All thoughts and feedback are welcome.
jb357 is offline
post #2 of 7 Old 01-27-2020, 09:01 PM
Quoted: 133 Post(s)
Liked: 73
If Dirac Live room correction is important, then consider the MiniDSP SHD. It is Roon compatible. I have no experience with the built in streamer (Volumio and it’s app), but you could get Bluesound Node 2i and still be well under 2K
thebrieze01 is online now
post #3 of 7 Old 01-27-2020, 09:07 PM - Thread Starter
Quoted: 65 Post(s)
Liked: 24
Originally Posted by thebrieze01 View Post
If Dirac Live room correction is important, then consider the MiniDSP SHD. It is Roon compatible. The inbuilt streamer is Volumio, which I have no experience with, or you could get Bluesound Node 2i
sorry, missed in my original post that it needs to be a pre-amp also - so the Node 2i is out of the running.
I forgot about the miniDSP SHD - will have to take a closer look at that one.
jb357 is offline
post #4 of 7 Old 01-28-2020, 06:01 AM
Quoted: 117 Post(s)
Liked: 48
NT-505 by TEAC is well reviewed and 1st on my list
wassup is offline
post #5 of 7 Old 02-01-2020, 04:34 PM
Liked: 0
The MiniDSP SHD Studio is compelling but doesn’t appear to have a built-in DAC, so you’d need to add one between the SHD and your amp.
AGLeS is offline
post #6 of 7 Old 02-01-2020, 05:07 PM
Quoted: 133 Post(s)
Liked: 73
The SHD does have a Dac, and a pretty good one judging by the ASR review. The SHD Studio is digital only version, which doesn’t have a Dac.
post #7 of 7 Old 02-21-2020, 02:41 PM
EB1000's Avatar
Quoted: 219 Post(s)
Liked: 42
I'm also looking for an alternative, but I doubt such a device exists. This is what I need
1. Preamp
2. Good Streamer/DAC with MQA/DSD support
3. HT Bypass or similar (fixed vol + analog bypass)
4. 2.2 room correction (2 independent subwoofer outputs)
The minidsp SHD is close, but it's lacking option #3
Right now I'll hang on to the terrible C658, hoping that the next FW update will resolve most of the subwoofer related bugs. I'm also curious about the upcoming NAD M33 amp. According to NAD support, it doesn't look very promising. No subwoofer level adjustment like with the C658, the buggy fixed volume is going to be removed, at least on the early firmware release, and no details regarding Dirac bass management support at this time...
EB1000 is offline
