Emotiva XPA-3 vs. Monolith 3 vs. 3 x Outlaw M2200 - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 11Likes
post #31 of 41 Old 02-04-2020, 01:01 PM
Quoted: 297 Post(s)
Liked: 362
Originally Posted by acribb View Post
Still contemplating DIY but may instead buy a couple of PSA TV3612s or a couple of Rythmik FV25s and some JBL A190s or a PSA 210 speaker system. Decisions decisions.
Yea I hear ya. There's some good stuff out there, and you definitely pay for DIY with your time. I'm sure it'll be nice whatever you decide!
Blister64 Full Basement Build Panasonic PT-AE8000U | Yamaha RX-A3070 | Emotiva XPA-DR3 Gen 3 | Emotiva XPA-7 Gen3 | DIY Sound Group Ported 1299 TMWW Front Stage | DIY SG Volt 10 Surrounds | Monoprice 8" Alpha In-ceiling Atmos | Three Stereo Integrity HS-24 mkIII's sealed | Sinbosen FP20000Q
YouTube Channel for builds and reviews Life Of Bliss YouTube
blister64 is offline
post #32 of 41 Old 02-11-2020, 07:57 AM
dkushner's Avatar
Quoted: 52 Post(s)
Liked: 46
Emotiva XPA-3 = $1200 shipped.
Monolith 3 = $1190 shipped.
Outlaw M2200 x 3 = $800 shipped.
Is it a no-brainer to go with the Outlaw mono-blocks?
ASR just published a review of the Outlaw 2200: https://www.audiosciencereview.com/f...-review.11403/
3.2, Ascend Acoustics Sierra RAAL Towers, Ascend Acoustics Duo LCR center, dual SVS SB-3000 subs, Outlaw 2200 LCR monoblocks, Denon X3500H
dkushner is offline
post #33 of 41 Old 02-11-2020, 08:59 AM
bub_star's Avatar
Quoted: 50 Post(s)
Just went through this process, comparing all three. Emotiva seemed like great folks to deal with, and I liked the modular approach; I liked the Monoprice because it's a solid amp at a great price. However, I went with the monoblocks - great reviews here and elsewhere, and superb deal, arriving Friday.
Now just need to decide on cables. I ordered these from Monoprice: https://www.monoprice.com/product?c_...seq=1&format=2, but many folks on Polk forums recommending the Blue Jeans LC-1: https://www.bluejeanscable.com/store/audio/index.htm
Not sure what to do here, but I'm very excited about the amps!
bub_star is offline
post #34 of 41 Old 02-11-2020, 09:51 AM - Thread Starter
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
I was just going to use some cheap thickish monoprice rca cables I have to connect my LCR to these Outlaw 2200s. Am I in trouble?
acribb is offline
post #35 of 41 Old 02-11-2020, 12:16 PM
madhuski's Avatar
Quoted: 1660 Post(s)
Liked: 1118
Proaudiola makes great, reasonably priced cables
https://www.proaudiola.com/
madhuski is offline
post #36 of 41 Old 02-11-2020, 12:19 PM - Thread Starter
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
I was actually being sarcastic about the cables. I personally believe there will be zero differences in sound quality between a cheap cable running 3 feet and one of these expensive cables.
Theheadsn likes this.
acribb is offline
post #37 of 41 Old 02-11-2020, 07:08 PM
dkushner's Avatar
Quoted: 52 Post(s)
Liked: 46
$11 and what I used between my Denon X3500H and Outlaw 2200 monoblocks. KabelDirekt RCA Stereo Cable, Cord (3 feet Short, Dual 2 x RCA Male to 2 x RCA Male Audio Cable, Digital & Analogue, Double-Shielded, Pro Series)
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
dkushner is offline
post #38 of 41 Old 03-13-2020, 07:03 AM
Theheadsn's Avatar
Quoted: 122 Post(s)
Liked: 62
Honestly as long as they are shielded and you dont have a ton of electrical interference, you're right on you be able to use almost anything. Is there a measurable difference from RCA to XLR in a 3 foot run? Probably, but I doubt it would be anything you would notice. I've heard some people get that low hum sound from their speakers when using external amps. Luckily I've never had that issue. I think a lot of that comes from dirty power more then anything
Theheadsn is online now
post #39 of 41 Old 03-13-2020, 07:11 AM - Thread Starter
acribb's Avatar
Quoted: 339 Post(s)
Liked: 103
I actually get a very slight extremely low volume hiss from the speakers driven by the outlaw monoblocks but that's normal from what I have read. Let me know if any Outlaw M2200 owners disagree and do not experience this. I only noticed when I put my ear right next to the speakers in a dead quiet room after reading it.
acribb is offline
post #40 of 41 Old 03-13-2020, 10:36 AM
bobknavs's Avatar
Quoted: 2892 Post(s)
Liked: 2093
I'm using Monoprice RG59/U (cheap coaxial) based RCA cables, 6 feet long, to connect my Denon AVR-X4300H to an Emotiva XPA3 Gen3. No trouble.
bobknavs is offline
post #41 of 41 Old 03-14-2020, 05:21 AM
Quoted: 184 Post(s)
Liked: 119
Assuming the cables are reasonably made and well shielded, the differentiating factor between the cables is going to be the capacitance. The monoprice cables have a capacitance of 21 pF, while the bluejeans cables have a capacitance of 12.2 pF/ft. Both good, and reflect the price differential. Most high end cables would be worse than BlueJeans. Only a very small minority of high end/exotic cables would actually be able to beat the BlueJeans number. (Based on comparing products from Tara Labs product line up)
The big difference between RCA (unbalanced) and XLR (balanced) is that the balanced outputs of your preamp typically has twice the output voltage (typically 2V) as the unbalanced (typically 1V). This will give you some additional gain from the amplifier. However the input and output sensitivities of the receiver/preamp and the amplifier need to be well matched.
If the sensitivities are not matched you will end up with either hiss/noise floor issues (input voltage too high for the amp) or low SPL (not utilizing the amps watts because input is too low for the amp)
The upshot is, XLR cables might give an extremely tiny (audible?) improvement in interference, but can sometimes introduce a much larger problem of hiss/noise levels by raising the nominal output sensitivity of the preamp
thebrieze01 is online now
