YPAO Fail? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-14-2020, 05:20 AM - Thread Starter
wrat's Avatar
Quoted: 22 Post(s)
Liked: 43
YPAO Fail?
using Martin Logan electrotats NOT the motion series, ypao fails it says speakers out of phase but they are not, what does the failure mean? are the other calibrations actually applied? all distances and crossover appear correct , size determination is good so why fail?
wrat is offline
post #2 of 3 Old 02-14-2020, 11:45 AM
Alan P's Avatar
Quoted: 6865 Post(s)
Liked: 6519
It is quite common for auto-setup programs (YPAO, Audyssey, MCACC, etc) to show an out-of-phase warning with electrostat (and bipolar) speakers. You can safely ignore it.
Alan P is offline
post #3 of 3 Old 02-16-2020, 10:43 AM
ChromeJob's Avatar
Quoted: 2199 Post(s)
Liked: 1153
Yep, my Yamaha consistently reported a surround speaker miswired when it was certifiably wired correctly. I even did continuity checks after putting on the banana/flextip terminations.
Depending on your model, you can post in one of the Yamaha owners' threads to compare with other Yamamaniacs.
“Ever heard of the Sullivan Act?” “Oh that's all right, Detective, we're married.”
Are you new to the forum? Please read forum FAQs and stickies. Like posts that help you. RTFM, always.
ChromeJob is offline
