The Official NAD T 778 Thread - Page 15 - AVS Forum | Home Theater Discussions And Reviews
 221Likes
post #421 of 469 Old 05-15-2020, 01:13 PM
Quoted: 22 Post(s)
Liked: 3
Originally Posted by markus767 View Post
Yep, that's it. Even worse on my 758v3. Is that similar to what you got with your Arcam?
I never tried the Rhye track when I had the Arcam so I can't say for sure, but the James Blake track distortion was the exact same as the NAD. The Arcam had identical results when troubleshooting the problem, so I'm inclined to say we're looking at the same signal processing issue from both manufacturers.
GigaChunk is online now
post #422 of 469 Old 05-17-2020, 12:31 PM
Balthazar2k4's Avatar
Quoted: 720 Post(s)
Liked: 834
Is it possible to do 5.1.4 without external amplification? The manual would seem to indicate 'no'.
EDIT: Nevermind, I just needed to keep reading... answer is 'yes'. Re-assign the surround back to height 2.
tebling likes this.
Sony 77A9G / Sony STR-ZA5000ES / Martin Logan Motion 40i w/AFX (Front), Motion 50XTi, Motion 40i w/AFX (Rear) / 2 x REL HT/1508 / Mytek Brooklyn DAC+ / Mac Mini (2020) with Roon Core / AppleTV 4K / ShieldTV Pro (2020) / 170TB Media Server
Balthazar2k4 is online now
post #423 of 469 Old 05-18-2020, 10:00 PM
Lonestar1027's Avatar
Any additional issues? Has any progress been made on Dirac Live bass management? I have one on order, just seeing if everyone is still in love with theirs.
Lonestar1027 is offline
post #424 of 469 Old 05-19-2020, 02:20 AM
nucky's Avatar
Quoted: 259 Post(s)
Liked: 179
Still very happy with mine. The only thing is DTS X is about 10db down from atmos and dts master audio.
AV Nad T778, Oppo 203, Panasonic UB420, Xbox one x , TV LG 55C6, 65 C8,OLED. HD projector 106 Jvc X7900 , Sub Paradigm signature sub1, Speakers monitor audio platinum PL200 PLC150, Dali phantom ikon in wall & 4 phantom kompas 6m in ceiling speakers, 5.1.4 Atmos
nucky is offline
post #425 of 469 Old 05-19-2020, 10:52 AM
Quoted: 121 Post(s)
Liked: 56
With my current Denon x4200w I can switch Surround Mode to Stereo (essential 2 channel + sub) pretty easy. I have my Denon powering a 5.1.2 system so the family watches movies, regular tv, and I love 2 channel music. I have all my devices (blu ray player, Sat box, XBox) plugged into Denon via HDMIs and then a single HDMI Out from Denon to LG Oled TV.
Is this an option with the 778? Would I have to 'wire' differently? I am looking forward to listening to 2 channel music via Apple Music Airplay. My 778 is expected end of May.
Thank you!
Name:	BWs 805 D3s.jpg
tigerljj1 is offline
post #426 of 469 Old 05-19-2020, 03:27 PM
Liked: 3
As I’m still waiting for my NAD 778, I’ve just got two questions. I see people saying you don’t need a UMIK-1, the standard is fine. But does the UMIK-1 give a better result? And, shouldn’t I buy full Dirac Live to get the most out of the 778 and my Dali Rubicon 6?
Think I’ll dig into a new sub to optimise my waiting, maybe the Arendal 1723 2 or 3...
iGudi is offline
post #427 of 469 Old 05-19-2020, 04:55 PM
Quoted: 121 Post(s)
Liked: 56
I previously asked if the UMIK-1 was necessary and several responded the mic that comes w 778 would suffice. As for buying full Dirac Live, not sure.
post #428 of 469 Old 05-19-2020, 05:04 PM
Quoted: 121 Post(s)
Liked: 56
Thank you!
I read the manual and there is an option for 2-channel stereo.
post #429 of 469 Old 05-20-2020, 02:08 AM
stainboy's Avatar
Quoted: 24 Post(s)
Thank you!
Hi. Yes you can. Either you have it setup in the Listening modes so that PCM coming from say Apple music for example, plays in Stereo (Fronts and sub) OR you can just do it through the app as well (NAD OSD) or the remote, just like in the Denon (Music or Pure Button). In the NAD display you can even select when PCM becomes stereo, Dolby or Neural...same as with the app.
Sony 85XG950 | Denon AVR-X4500H | 2x Klipsch RP8000F | 2x Klipsch RP500M | 3x Klipsch RP640D | 2x Klipsch RP240D | 2x Klipsch RP500SA | 2x SVS PB1000 | Emotiva A-300 | Emotiva A-700 | Emotiva A-5175 | MiniDSP 2x4HD | Vero4K+ | Nvidia shield TV | PS4pro | Onkyo 9010 | 2x Magnat Shadow 207 | Sony HT-ZF9 | NAD T778
never underestimate the power of denial.
stainboy is offline
post #430 of 469 Old 05-20-2020, 02:47 AM
Liked: 3
My Sony X900F only support ARC, and Sony support wont tell me anything in regards to a future eARC firmware update. I doubt it, but I keep crossing my fingers.
I’ve never used ARC before, but plan on this when I get my NAD 778.
Do I need to connect a HDMI cable from my ARC port in the Sony TV and connect it to HDMI IN 1, in the NAD? And another HDMI from the HDMI OUT 1 4K to my Sony TV.
Or can I simply have just one connected in the HDMI OUT 1, into my Sony ARC HDMI port.
iGudi is offline
post #431 of 469 Old 05-20-2020, 04:03 AM
stainboy's Avatar
Quoted: 24 Post(s)
It's one cable from NAD HDMI 1 into the Sony TV ARC HDMI. That's it. This enables:
Connect anything HDMI to the NAD
OR
Connect to the TV HDMI's and sound will come out from NAD (once selected BluOS in the NAD, it will show ARC).
ONLY "problem" of having devices connected to the TV is that anything lossless will not go through ARC due to bandwidth limitations. But you'll still get Atmos from Netflix since it is in the DD+. I recommend connecting devices (nvidia shield, Vero, PS, whatever) to the NAD directly and get all sound formats. I have it that way and in HDMI "standby" you can still access the devices with the NAD "off". Except you'll not get sound from it, rather from the TV so same limitations apply.
stainboy is offline
post #432 of 469 Old 05-20-2020, 04:28 AM
nucky's Avatar
Quoted: 259 Post(s)
Liked: 179
I used the mic you get with the nad and it was fine. Then got the UMIK-1 and for me gave better results.
I've not got full Dirac live yet as wanted to hear what it sounds like first. It sounds amazing. Will upgrade to full version at some point.
LiLAsN and iGudi like this.
nucky is offline
post #433 of 469 Old 05-20-2020, 05:32 AM
Liked: 3
OR
My plan is to have my ATV 4k, Shield TV Pro and HTPC connected to my NAD, and the from the NAD 4K HDMI OUT to my Sony TV. And I was worried if I also had to have an extra HDMI from the Sony ARC to the NAD HDMI IN.
I use the Netflix app on the Sony, so I need ARC to send sound to the NAD.
iGudi is offline
post #434 of 469 Old 05-20-2020, 05:36 AM
stainboy's Avatar
Quoted: 24 Post(s)
I have Apple TV, PS4, Shield TV all connected to the NAD and from the NAD only one cable to the ARC on my Sony (it's eARC but it doesn't matter here). Using Netflix app on the Sony works as expected, you'll get Atmos. Plex on the other hand, from TV to NAD doesn't do Atmos. So I use Plex from the shield to get full sound options.
iGudi likes this.
stainboy is offline
post #435 of 469 Old 05-20-2020, 10:03 AM
Quoted: 121 Post(s)
Liked: 56
Thank you, can’t wait!
post #436 of 469 Old 05-21-2020, 09:44 AM
Quoted: 121 Post(s)
Liked: 56
Just got call my 778 is in. Shipping by tomorrow!!!
MaxTemp likes this.
post #437 of 469 Old 05-21-2020, 11:10 AM
Quoted: 140 Post(s)
Liked: 89
Nice! Do you experience any silence at the start of any audio in PCM as a result of the HDMI handshake between the video player and the AVR? Or is this audio cut-off in beginning of track only present when streaming Dolby or DTS codec from a player to the AVR only?
LiLAsN is online now
post #438 of 469 Old 05-21-2020, 11:45 AM
stainboy's Avatar
Quoted: 24 Post(s)
From netflix, prime, disney, no. From Plex, sometimes the movie starts and a second after the sound starts. Usually is only when resuming a video, not from the very start. Haven't figured out if only on DTS or Dolby, but my guess is both when resuming a movie. On music it doesn't happen.
anthonymoody and LiLAsN like this.
stainboy is offline
post #439 of 469 Old 05-21-2020, 03:28 PM
Quoted: 140 Post(s)
Liked: 89
That was a very specific and detailed explanation. Exactly the answer I was looking for. Thank you so much!
post #440 of 469 Old 05-21-2020, 06:00 PM
Quoted: 121 Post(s)
Liked: 56
Dirac Live Setup
Hi fellas! My 778 ships tomorrow. Reading up on Dirac Live and how to set up. Is it pretty intuitive, easy? Only worked with Audessey which was pretty easy. Can’t find an easy to follow tutorial on YouTube. Any tips?
Appreciate it!
post #441 of 469 Old 05-22-2020, 10:26 AM
stainboy's Avatar
Quoted: 24 Post(s)
Appreciate it!
Markus767 went through the effort of putting it together in one place.
https://www.avsforum.com/forum/90-re...ve-thread.html
have fun!
stainboy is offline
post #442 of 469 Old 05-23-2020, 05:40 AM
Quoted: 22 Post(s)
Liked: 3
So here's a perplexing update regarding the "Rhye" distortion issue. I purchased a Denon AVR-X3600H to compare to the NAD and see if it suffered from fewer issues.
First thing I did after setup was try the Rhye track. Guess what? Exactly the same distortion issue as the NAD and the Arcam.
What on earth is going on here???? Am I taking crazy pills??? It behaves the same way with the crossovers and stereo vs. surround input.
What's the likelihood of three manufacturers having the same issue? Especially the Denon, as it's regarded as pretty bug-free and stable compared to the NAD or Arcam, and doesn't really share much in common with them.
I'm starting to feel like there's an external factor at play here. Clearly it's not just me who suffers from this issue, but the vast majority of people don't report hearing any distortion problems.
I tried switching off basically everything else connected to the Denon, but it doesn't remove the issue.
post #443 of 469 Old 05-23-2020, 05:54 AM
markus767's Avatar
Quoted: 6393 Post(s)
Liked: 3353
Now that's interesting. Thanks for reporting. All 3 manufacturers use the same buggy (?) chip?
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #444 of 469 Old 05-23-2020, 06:15 AM
Quoted: 22 Post(s)
Liked: 3
If that's the case though, wouldn't you expect far more people to be reporting this problem as it would span three different manufacturers?
Bob from NAD replied to me today with (I think) pretty much the same thing they told you several months ago:
"After speaking with our engineering team regarding the PCM distortion 'Small' Speaker Configuration issue, they have been able to replicate it. Our engineering team will be looking into this further and be providing a fix for this issue in a future firmware update.
Unfortunately, we here in technical support are not provided a timeline on future development and releases so I can not say for certain when this update will become available. However, rest assured that our engineering team will be doing everything they can to resolve this issue as soon as possible.
I'm sorry I do not have a more immediate solution for you but in the meantime, if you have any further questions for me, please feel free to let me know.
Best Regards,
Bob Moran"
At this point I'm not even sure if they have replicated the issue, as you can't talk to engineering directly...
post #445 of 469 Old 05-25-2020, 11:41 AM
mausse's Avatar
Quoted: 55 Post(s)
Liked: 48
Distortion? I had it before with this track
Johann Johannsson - Orphée
I heard it in my satellite speakers I thought first my speakers couldn’t handle it or maybe it’s in the track..
I don’t have the unit anymore but maybe you can check it with this track?
Verzonden vanaf mijn iPad met Tapatalk
mausse is offline
post #446 of 469 Old 05-25-2020, 12:24 PM
markus767's Avatar
Liked: 3353
Specific track? "Orphée" is the album title.
Markus
post #447 of 469 Old 05-26-2020, 06:04 AM
Quoted: 22 Post(s)
Liked: 3
Just had a BluOS update to 3.8.13 but no change to the distortion issue.
Not surprising, as I imagine it would be part of a DSP update if it ever does get fixed...
post #448 of 469 Old 05-26-2020, 06:19 AM
Quoted: 22 Post(s)
Liked: 8
Considering this or the T758 v3. Really care about the 2-channel music sound quality. How satisfied are owners with the sound quality? Anyone with both T778 and T758 v3 listening experience?
Samsung UN82RU8000 | Marantz SR6009 | Monitor Audio SoundFrame 2 front speakers | NHT Super Zero rear speakers |
NHT Sub Two i subwoofer | Dish Hopper w/Sling | Roku Premiere+ | Samsung BD-H6500 Blu-Ray |
Mac mini/iFi Audio nano iUSB3.0/iFi Audio micro iDAC2 | Xbox One | Furman Elite-15 PFI
jtconte is online now
post #449 of 469 Old 05-26-2020, 08:14 AM
anthonymoody's Avatar
Quoted: 922 Post(s)
Liked: 682
Seems like there must be some commonality of internal components across mfrs. Maybe even something that's so base-layer it isn't even spelled out on the typical BOM stuff they usually spell out e.g. DACs.
Stuck up, half witted, scruffy looking, nerf herder.
Double True!
anthonymoody is offline
post #450 of 469 Old 05-26-2020, 10:14 AM
Quoted: 22 Post(s)
Liked: 8
The T777 v3 which has just 2 less channels than the T778 weighs 45.2 lbs while the T778 weighs 26.7 lbs. Possibly more than just power supply and amplifier differences? Where can a BOM be found by a non-service person?
