The Official NAD T 778 Thread - Page 5 - AVS Forum | Home Theater Discussions And Reviews
 269Likes
post #121 of 668 Old 03-12-2020, 03:54 PM
mausse's Avatar
Quoted: 56 Post(s)
Liked: 50
[elknave said:
Not so good stuff:
The fan on mine is noisy. Every report I've read so far has said that the fan is silent, so I think I may have gotten a bum unit. I think what's happening is that the mesh fan cover is vibrating ever so slightly against something, because if I push on it with my finger the noise mostly goes away (but not entirely). This is with the unit reporting a 1000 rpm fan speed. I might unscrew the fan cover and mess with it to see if there's a quick 'n dirty fix.
In a rack it can’t dispose the heat from the top, that’s why you need the fans and others might not. So I think it’s not a bum unit.
Verzonden vanaf mijn iPhone met Tapatalk
mausse is offline
post #122 of 668 Old 03-12-2020, 04:04 PM
tebling's Avatar
Quoted: 200 Post(s)
Liked: 320
No, it made the same noise outside the rack. Also, there's no other equipment above the AVR (its vents are not obstructed), and the rack is open on the back. Also also the fan spins up to 1k rpm as soon as the unit powers on regardless of temperature. Also also also it shouldn't be the case that I can press on the fan cover and have the noise go away
tebling is offline
post #123 of 668 Old 03-13-2020, 09:20 AM
mausse's Avatar
Quoted: 56 Post(s)
Liked: 50
Well Exchange it quick, i have order one ETA August Holland
mausse is offline
post #124 of 668 Old 03-13-2020, 07:16 PM - Thread Starter
HTNUT1975's Avatar
Quoted: 238 Post(s)
Liked: 128
Woah. I’m assuming this is because of the virus?
HTNUT1975 is online now
post #125 of 668 Old 03-14-2020, 01:46 AM
mausse's Avatar
Quoted: 56 Post(s)
Liked: 50
Yes unfortunately
mausse is offline
post #126 of 668 Old 03-15-2020, 06:08 PM
tebling's Avatar
Quoted: 200 Post(s)
Liked: 320
Today I discovered a software bug on the T778. The bug is that saving and recalling the preset associated with the BluOS input does not work if it is set up from the front panel touchscreen. It DOES work fine when set up via the OSD.
I submitted a report to NAD support, but thought others should be aware.
tebling is offline
post #127 of 668 Old 03-17-2020, 04:28 AM - Thread Starter
HTNUT1975's Avatar
Quoted: 238 Post(s)
Liked: 128
Ok, I have good news. I had asked Dan who works with 'The Sound Counsel' in Edinburgh about whether the NAD T 778 included discrete sub outs. Here's what he said:
'They do not have details or time frames regarding DIRAC Bass Management they can share with me at this time. Their developers are working directly with DIRAC to provide this feature in a future update, as yet we are unsure if this will be paid or free. I suspect it will be a paid upgrade but it hasn't been confirmed.
Right now, the sub-woofer outputs are independent according to NAD, which makes sense if they hope to add the bass management module as this would most likely be a technical requirement at the hardware level.'
https://www.avforums.com/threads/new.../post-27853864
So, it is at least in principle possible for the NAD to make use of all tiers of Dirac Bass Control. It may cost a pretty penny for the software upgrade, but at least we wouldn't have to purchase an additional module for subwoofer outs (thereby making the AVR cost closer to the M17 or other processors). Very, very good news.
post #128 of 668 Old 03-17-2020, 01:53 PM
nucky's Avatar
Quoted: 269 Post(s)
Liked: 191
Originally Posted by nonametofame View Post
You've had the unique advantage of trying all of the flavors, and objectively determined which works best for you. I haven't seen that either, which is really cool.
In my room, going from an AVR to pre-pro made a bigger difference in SQ , moreso than room correction and even room treatment. Denon AVR to Marantz 7705 (audyssey), and the other big jump going from Arcam 390 to Maestro M5 (arcam rebadge) for Dirac.
Well so much for the marantz for films I really like it, but for music I definitely prefer the nad. I should have kept it and got it professionally calibrated.
AV Nad T778, zidoo uhd2000, Panasonic UB420, Xbox one x , TV LG 55C6, 65 C8,OLED. HD projector 106 Jvc X7900 , Sub Paradigm signature sub1, Speakers monitor audio platinum PL200 PLC150, CP-CT380IDC In-ceiling Dali phantom ikon in wall & 2 phantom kompas 6m in ceiling speakers, 5.1.4 Atmos
nucky is offline
post #129 of 668 Old 03-18-2020, 12:55 PM
nonametofame's Avatar
Quoted: 84 Post(s)
Liked: 48
Dirac has a somewhat steep learning curve if you're really trying to dial it in. What did you prefer in the Marantz over the NAD for movies? How would you compare the pros/cons of each unit?
Audio: Audiocontrol Maestro M5 | Parasound A21 | Parasound A51 | Parasound 275
Video: Optoma P1 | LG 65E6P | Panasonic UB9000 | Oppo 203 |
Speakers: Martin Logan 60XT & 50XT| Motion 4| FX2s
| Dual SVS PB16 | Dual SVS SB3000
nonametofame is offline
post #130 of 668 Old 03-18-2020, 01:50 PM
nucky's Avatar
Quoted: 269 Post(s)
Liked: 191
For music the marantz is to bright and trebley, I could listen to the nad all day but my wife would say it could be boring. For films the marantz just fills the room with sound and it sounds good with plenty bass and impact. The nad sounded empty but the bass was quick and tight. That was me calibrating it but if I get Nick my dealer to do it he would take the full day to do it so i think it would sound a lot better.
nonametofame likes this.
nucky is offline
post #131 of 668 Old 03-18-2020, 05:45 PM - Thread Starter
HTNUT1975's Avatar
Quoted: 238 Post(s)
Liked: 128
You can match that with the NAD with the right target curve. It sounds like you like the multieq function of audyssey.
nucky likes this.
post #132 of 668 Old 03-21-2020, 01:49 PM
nucky's Avatar
Quoted: 269 Post(s)
Liked: 191
I have ordered one and getting Nick to do Dirac and he will do 3 profiles for me. As he has done lots of installs. I could do it myself but I know he will do a better job. Looking forward to getting it.
HTNUT1975 likes this.
nucky is offline
post #133 of 668 Old 03-22-2020, 01:44 PM
stainboy's Avatar
Quoted: 42 Post(s)
Liked: 24
Just ordered mine. Will use it with 3 emotiva amps for a 7.2.4 configuration. I'll put some pics once it gets here.
nucky and HTNUT1975 like this.
Sony 85XG950 | 2x Klipsch RP8000F | 2x Klipsch RP500M | 3x Klipsch RP640D | 2x Klipsch RP240D | 2x Klipsch RP500SA | 2x SVS PB1000 | Emotiva A-300 | Emotiva A-700 | Emotiva A-5175 | MiniDSP 2x4HD | Vero4K+ | Nvidia shield TV | PS4pro | Onkyo 9010 | 2x Magnat Shadow 207 | Sony HT-ZF9 | NAD T778
Never underestimate the power of denial.
stainboy is offline
post #134 of 668 Old 03-25-2020, 01:35 PM
mausse's Avatar
Quoted: 56 Post(s)
Liked: 50
It’s here! for those who like the unbox thing
mausse is offline
post #135 of 668 Old 03-25-2020, 02:18 PM
blackspider's Avatar
Quoted: 433 Post(s)
Liked: 54
Does the T778 have EARC ?
55" LG B6 - Nad T758 V3- Anthem MCA 225- B&W 600 s2 speaker series - Stereo Rel S2
blackspider is online now
post #136 of 668 Old 03-25-2020, 04:08 PM - Thread Starter
HTNUT1975's Avatar
Quoted: 238 Post(s)
Liked: 128
Yessir!!
post #137 of 668 Old 03-25-2020, 04:16 PM - Thread Starter
HTNUT1975's Avatar
Quoted: 238 Post(s)
Liked: 128
https://youtu.be/yhX1JxkWF_8
Being stuck inside for so long, I’m a little jealous I didn’t order this thing already.
post #138 of 668 Old 03-25-2020, 11:16 PM
Quoted: 433 Post(s)
Liked: 54
Yessir!!
Phew, my next avr upgrade then :-)
post #139 of 668 Old 03-26-2020, 12:19 AM
markus767's Avatar
Quoted: 6645 Post(s)
Liked: 3525
iOS app
Hi guys
Looks like the 778 communicates just like the older units, so my info/remote app should work. If anyone wants to test it please follow this link for a beta:
https://testflight.apple.com/join/63QG2E1v
Please let me know if you run into any problems – and also if you don't Thanks!
ID:	2701862   Click image for larger version
tebling likes this.
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
post #140 of 668 Old 03-26-2020, 12:13 PM
pixelknave's Avatar
Quoted: 34 Post(s)
Liked: 42
I don't want to be the downer here, but it doesn't. It supports ARC, but not eARC (which is an HDMI 2.1 feature). ARC has the bandwidth to get you up to 5.1, but will choke on 7.1+ and won't support Atmos.
pixelknave is offline
post #141 of 668 Old 03-26-2020, 01:29 PM
nucky's Avatar
Quoted: 269 Post(s)
Liked: 191
Originally Posted by markus767 View Post
Hi guys
Do you have android version. Thanks
nucky is offline
post #142 of 668 Old 03-26-2020, 06:50 PM - Thread Starter
HTNUT1975's Avatar
Quoted: 238 Post(s)
Liked: 128
It does support eArc, which is a feature found on HDMI 2.0b. This is found through the NAD VM310 (as opposed to the VM300).
post #143 of 668 Old 03-26-2020, 07:49 PM
pixelknave's Avatar
Quoted: 34 Post(s)
Liked: 42
We're almost talking about the same thing…ARC is HDMI 2.0b, and is supported by both the VM300 and VM310. eARC is new in the HDMI 2.1 specification, but it looks like eARC can theoretically be added to 2.0b devices via software. None of NAD's T778 documentation mentions this yet, but it's mentioned in the M10 specs and I'd be thrilled if they snuck it in here, too. I'll just have to get an LG C9 to test it out
post #144 of 668 Old 03-26-2020, 10:34 PM
markus767's Avatar
Liked: 3525
https://www.hdmi.org/press/pressresources
RagtopFE likes this.
Markus
post #145 of 668 Old 03-26-2020, 10:39 PM
torii's Avatar
Quoted: 4416 Post(s)
Liked: 2596
how many old nad products are upgradeable? to hdmi 2.1?
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #146 of 668 Old 03-27-2020, 01:41 AM
Quoted: 12 Post(s)
Liked: 2
Well this is funny, as the new ARCAMs are 2.0b and support eARC. Hmm ?
Also another quick question to the 778. And sorry for my ignorance if it was mentioned somewhere else, but is it now possible to change the curves after Dirac ? Can we change loudness etc..
NangNang is offline
post #147 of 668 Old 03-27-2020, 02:18 AM
markus767's Avatar
Liked: 3525
This is what NAD support says about eARC support:
"Vishnu M. (NAD Electronics)
Mar 27, 5:14 AM EDT
Hello Markus,
Thank you for contacting the NAD Support Crew.
Regarding the T778, eARC is supported on T778 (and older AVRs upgraded to VM310).
I hope this information helps.
Kind Regards,
Vishnu M
NAD Electronics Support Crew Analyst"
torii and RagtopFE like this.
Markus
post #148 of 668 Old 03-27-2020, 08:02 AM
JD23's Avatar
Quoted: 1066 Post(s)
Liked: 834
Plenty of HDMI 2.0b AVRs from the past few years support eARC and even some TVs, such as those from Sony. LG TVs are essentially the only devices with that supposedly have a full set of HDMI features at this point.
JD23 is offline
post #149 of 668 Old 03-28-2020, 07:20 AM
stainboy's Avatar
Quoted: 42 Post(s)
Liked: 24
So.... how does it perform? What's your veredict so far?
stainboy is offline
post #150 of 668 Old 03-28-2020, 08:45 AM
markus767's Avatar
Liked: 3525
Fundamental design flaw
While the 778 looks like a competitively priced Dirac Live AVR it is still unknown whether it will get Dirac Live Bass Control or not.
Furthermore there is a fundamental design flaw in all NAD processors that is also present in the 778: Tone controls and channel volume is applied downstream of bass management. So if you are using a subwoofer, all the redirected bass from all channels (except LFE) is NOT affected by tone controls and channel volume whatsoever.
The solution for this misbehaviour would be to move tone controls and channel volume upstream of bass management. Unfortunately NAD does not consider to change their implementation – this is how NAD support responded:
"[...] We just received confirmation from Engineering that we are not going to change the audio chain to allow tone controls to affect the sub out. [...]"
"[...] The T778 uses a similar design and the same DSP board as the T758 V3. Hence the tone controls work the same. Ditto for the channel volume buttons via the HTR8. [...]"
Markus
