Time to upgrade receiver - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By Mike_w_j2003
  • 1 Post By Leeliemix
post #1 of 21 Old 02-14-2020, 08:13 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Ok, I have an old RCA 5.1 receiver I bought in 2002. I have upgraded to a 4k qled tv and have pioneer elite speaker setup for 11.2.4 now I need to power it. These are 4 ohm speakers. I obviously need atmos and dts, I do stream hd music from Amazon currently to the tv then optic line out to my receiver. The only internet I have is from my phones hot spot, so connectivity is not my major concern. I have an xbox1x I play offline. Not going to 8k not worried about it at all. I have $1I roughly I can throw at it. Can someone help me out with a recommendation?
Mike_w_j2003 is offline
post #2 of 21 Old 02-14-2020, 08:14 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
7.2.4, not 11.2.4 my mistake, new math kills me.
post #3 of 21 Old 02-14-2020, 08:23 AM
HTNUT1975's Avatar
Quoted: 130 Post(s)
Liked: 62
Hey Mike, I'm assuming you meant 1k?
HTNUT1975 is offline
post #4 of 21 Old 02-14-2020, 08:24 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Yes, my phone hates me.
hogues likes this.
post #5 of 21 Old 02-14-2020, 08:30 AM
HTNUT1975's Avatar
Quoted: 130 Post(s)
Liked: 62
As does mine! It'll be a bit more difficult to find one in your range with 11 channels. Have you considered used/refurbished?
post #6 of 21 Old 02-14-2020, 08:36 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Refurbished should be fine. I've been looking at things like pioneer 503 and 701, denon AVR-X4500H or 3600. My current setup is as advanced technologically as it will be for the next decade or so. Future proofing isnt a huge issue for me.
post #7 of 21 Old 02-14-2020, 08:36 AM
HTNUT1975's Avatar
Quoted: 130 Post(s)
Liked: 62
If you had to have all 11 channels, here's an option to consider (from a reputable source--I've bought a few AVR's from them):
https://www.accessories4less.com/mak...-w/heos/1.html
post #8 of 21 Old 02-14-2020, 08:44 AM
HTNUT1975's Avatar
Quoted: 130 Post(s)
Liked: 62
Ok, my dad has the 3600, I believe, but that and the 4500 doesn't have 11 channels unless you get additional power.
post #9 of 21 Old 02-14-2020, 08:49 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Right on, I'd have to wait until payday to pull the trigger on that one. Definitely worthy of consideration. Thank you.
post #10 of 21 Old 02-14-2020, 08:50 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Could I used my old receiver as the amp for the other 2 channels?
post #11 of 21 Old 02-14-2020, 09:05 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
I also looked at older models pioneer sc89 might do everything I need and is 600 refurb. Not sure it has dhcp 2.2, though I'm not sure how big an issue it actually is. Class d amps running cooler has a certain appeal. It may last longer than something that runs hot.
post #12 of 21 Old 02-14-2020, 09:12 AM
HTNUT1975's Avatar
Quoted: 130 Post(s)
Liked: 62
What model is your old receiver?
post #13 of 21 Old 02-14-2020, 09:22 AM
Quoted: 491 Post(s)
Liked: 250
Without HDCP 2.2 you wont get 4k from blu-ray and streaming services like netflix.
HTNUT1975 likes this.
Leeliemix is offline
post #14 of 21 Old 02-14-2020, 09:29 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
Rca stav 3970, ah I figured there was an issue with not having it.
post #15 of 21 Old 02-14-2020, 09:30 AM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
It way a model made by pioneer for radio shack, packaged as rca, which was the renamed realistic brand.
post #16 of 21 Old 02-14-2020, 10:03 AM
HTNUT1975's Avatar
Quoted: 130 Post(s)
Liked: 62
You know, I don't think it is feasible to do that with that model. Just quickly looking at some pics of the back of it, I don't see any inputs designed to use the amps like that. Is your TV a smart TV?
post #17 of 21 Old 02-14-2020, 10:29 AM
HTNUT1975's Avatar
Quoted: 130 Post(s)
Liked: 62
Never mind on the last question. I somehow bypassed that you're using an Xbox 1X.
post #18 of 21 Old 02-14-2020, 12:42 PM
eriksells916's Avatar
Quoted: 688 Post(s)
Liked: 252
Mike these are some of the newer 9 channel models (around $1k) that can expand to 11 with small amp like this https://www.amazon.com/Audio-Source-...1709130&sr=8-1
Pioneer lx503/504
Onkyo rz73/740/830/840
Denon x3600/4400/4500 (refurbed)
NAD 758 v3
eriksells916 is offline
post #19 of 21 Old 02-14-2020, 02:33 PM
bobknavs's Avatar
Quoted: 2568 Post(s)
Liked: 1829
I imagine that any receiver could be used as a 2 channel (stereo) amp. That'd be all you'd need with a Denon AVR-X3600H or a Pioneer VSX-LX504. Multichannel analog inputs would be rarer, but you don't need that.
That said, I'd prefer to spend a bit more on a small dedicated amp that includes a 12V trigger. The Audiosource AMP100VS is a common choice. There are others, like this one: https://www.amazon.com/OSD-Audio-XMP...1715913&sr=8-1
The least expensive (new) AVR that I know of that processes 11 channels (but has 9 onboard amps) is the Onkyo TX-RZ730. The low price is all that I know about it. (Seems to be a 2018 model.)
bobknavs is offline
post #20 of 21 Old 02-14-2020, 03:38 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
It can use the entire budget, I was looking at a pioneer 701 or 503, the 701 has d class amps. I know onkyo owns pioneer now, has there been a decline in quality? Denon is good stuff, so if pioneer doesn't stand up I think it would be the way to go. Theres 3600 for $750 or 4500 for 900, from here which of these would recommend? Thanks for the link to the amp, I might spend some cash and put it on my front speakers for listening to music. Seperate preamp and amp isnt out of the question either. I might get the best quality for my dollar that way.
post #21 of 21 Old 02-14-2020, 03:39 PM - Thread Starter
Quoted: 12 Post(s)
Liked: 1
I would imagine it would take a few more dollars if I went pre and amp but might be worth it in the long run.
