Yamaha TSR-7810 vs Denon 3500h - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 2 Post By eriksells916
  • 1 Post By bchandler02
post #1 of 10 Old 02-16-2020, 01:35 PM - Thread Starter
Liked: 0
In the process of upgrading to a 4k screen. I have an AVR-1910 now that works great, but doesn't support 4K. Speakers are nothing special but will be upgraded in the next year or two.
I can get a TSR-7810 for $330 or the 3500H scratch/dent from Crutchfield for $470
If I keep the 1910 and put all my sources into the TV and then optical back to the 1910, I could get 4K video but lose master audio. If I keep the 1910 as it, I keep master audio but don't get 4K. The 1910 has speaker inputs so I could use a preamp but 4k Emotiva and Outlaw start at 700 and up and don't have the latest features in general, so that doesn't make sense.
I've had Onkyos in the past that worked great, but when I upgraded to HDMI last time around I got a Denon 891 that had HDMI issues. Denon replaced it with the 1910. In all the reading I have done, Yamaha seems to have the benefit of being higher quality, but Denon has the much better Audssey setup.
What am I missing in the comparison of the 3500h vs the 7810? Both look to support 4k and have preouts that could be useful down the road.
bchandler is offline
post #2 of 10 Old 02-16-2020, 03:43 PM
eriksells916's Avatar
Quoted: 701 Post(s)
Liked: 255
The 7 channel receivers I often see recommended are the 7810, Onkyo rz820 and Denon x3500. You cannot go wrong with either one.
The Yamaha is known for reliability but limited hdcp 2.2 inputs, the rz820 is a beast and the x3500 has the ability to calibrate dual subs with level and delay down to 10hz.
Whichever one has the most feature you will use, for the least amount.
p.s. the newer Yamaha tsr7850 is on sale, has more hdmi inputs but only has LR preouts.
Makav3li and bchandler02 like this.
eriksells916 is offline
post #3 of 10 Old 02-17-2020, 07:19 AM
bchandler02's Avatar
Good info. I think I'm going to rule out the 7810. I will check out the 7850 but not sure it will be too far up the list due to limited preouts for future use. I hadn't seen the 820 so that is a good one, I will likely decide between 820 and 3500 unless I see something on the 7850 that grabs me. Right now, I am leaning towards the 3500.
eriksells916 likes this.
bchandler02 is offline
post #4 of 10 Old 02-18-2020, 01:06 PM
Looks like I can get a marantz sr5013 for around the same price. Is that worth considering or do I lose something major by going back too many generations?
post #5 of 10 Old 02-18-2020, 01:22 PM
pase22's Avatar
Quoted: 3685 Post(s)
Liked: 3120
The Denon X3500H has a higher version of audyssey (XT32), dual sub eq, pre-outs and all inputs support HDCP 2.2 and 4K. You can also get the remote app ($20) that lets you customize eq settings even further. All will have similar features like Spotify, multi-room audio, Alexa compatibility and so on.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is offline
post #6 of 10 Old 02-18-2020, 01:54 PM
XT32 would be a benefit - the question is does it outweigh the benefit of stepping up to a Marantz. I've heard the sound can be a little different with Marantz vs. Denon?
I do not see myself ever going to dual sub, so not worried about that part.
5013 has preouts as well, so that is equal, and all inputs support HDCP2.2 and 4k just like the X3500h. They look fairly equal, unless I am missing something. Both are within $20 of each other.
post #7 of 10 Old 02-18-2020, 02:08 PM
Quoted: 24 Post(s)
Liked: 6
Marantz vs Denon:
https://www.zkelectronics.com/compar...vr-x3500h/usa/
Onkyo Vs Denon:
I'd personally pick Denon and be done with it
yllanos is offline
post #8 of 10 Old 02-18-2020, 02:29 PM
afrogt's Avatar
Quoted: 2286 Post(s)
Liked: 1499
The three HDMI out on the Denon plus the Audyssey XT32 would put it over the top for me vs the 7810 which is a little older and only has 3 HDMI 2.0 / HDCP 2.2 inputs while the Denon has 8.
Denon can also play a separate HDMI source in Zone 2 which is a feature I use on my x3300.
Afro GT
afrogt is offline
post #9 of 10 Old 02-18-2020, 02:59 PM
pase22's Avatar
Liked: 3120
Marantz is said to have a warmer sound than Denon, but the Denon X3500H has better room eq.
pase22 is offline
post #10 of 10 Old 02-18-2020, 03:15 PM
Originally Posted by yllanos View Post
Marantz vs Denon:
Onkyo Vs Denon:
I did see this page. Neither had something that stood out as a MUST/DONT. I've ruled out the Yamaha, and agree the Denon is what I need. Just making sure I'm not an idiot for passing up a Marantz for the same price.
2 HDMI out is the most I'd ever need, just need 1 today. I know the XT32 is superior. I've ruled out the 7810. For the separate HDMI source for zone 2 - no need for that today, but it may be fun to play with in the future.
I have heard Marantz can be warmer, but either should be an upgrade from my 1910 that I have today. I know the room EQ is better.
