Which AVR would be best for my situation? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Alfred Andersson
post #1 of 4 Old 02-19-2020, 02:51 AM - Thread Starter
Liked: 1
I'll be getting a used pair of Monitor Audio Silver RX2s and a matching RX Centre and will need a receiver. Usage will be about 80% HT and 20% music. I will probably stay at 3.0 for a while but eventually buy a sub and surround speakers when my budget allows it. These are the models I'm looking at currently:
Sony STR-DH790 (3290 SEK) - only very slightly more expensive than the DH590 and I might decide that I want atmos in the future.
Yamaha RX-V385 (3279 SEK) - looks good as well
Denon AVR-X550BT (3296 SEK) - no eARC which I might want in the future but if it's better in other ways I might consider it.
Pioneer VSX-534 (3490 SEK) - no eARC again like the Denon.
I don't really have any experience with AV so I'll need your help here. I might consider increasing my budget but only if it makes a significant difference to sound quality. The only real requirement I have is that 4k/HDR passthrough at 60Hz is supported.
Alfred Andersson is online now
post #2 of 4 Old 02-19-2020, 03:34 AM - Thread Starter
Liked: 1
I want to add as well (can't seem to edit my post) that I will be listening in a pretty small room (about 11m²/120ft²) about 1.5-2m away from the speakers, and nowhere near reference level. Maybe the receiver choice matters less at lower volume levels?
post #3 of 4 Old 02-19-2020, 06:14 AM
pase22's Avatar
Quoted: 3710 Post(s)
Liked: 3153
Those entry level AVR's will get the job done, but they have very little eq and weak power supplies. If you can step up to the Denon X1400/1500 that would be a huge improvement. If budget is tight, aim for at least the Denon S740/750 models.
Kef LS50,Q200C, Q100, Kef Kube 10B (X2) , Denon AVR-X3400H, Panasonic 50" Plasma, Xbox One.
Bedroom: Kef Q100 ,JBL Loft 20, SVS SB-2000, Denon AVR-S710W, PS3, 32" Insigna LED.
pase22 is online now
post #4 of 4 Old 02-19-2020, 06:53 AM - Thread Starter
Liked: 1
Just managed to find a good deal on a Denon X1600 from amazon.de for 366 euros. I was only looking at Swedish sites before and they had way higher prices on most receivers. If that's still there in a few weeks when I get some money I think I'll buy it.
pase22 likes this.
