Talk to me about Denon and Audyssey - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By ClawAndTalon
post #1 of 5 Old 02-26-2020, 07:37 PM - Thread Starter
jnick1's Avatar
Quoted: 71 Post(s)
So I just finished configuring a 5.1.4 setup at my parents using an X3600H. I’m very confused about how audyssey works and have some questions:
1. After running Audyssey, if I use the “Direct” audio profile (NOT Pure Direct) does that still use Audyssey’s settings?
2. If after running Audyssey I adjust speaker levels manually, does it still utilize the Audyssey correction or does that override and cancel any Audyssey adjustments?
3. Should I be running an separate speaker dB test with my sound meter to ensure all speakers are dialing in at/near 75dB? Or just run Audyssey and call it a day?
4. When it comes to Dolby Atmos, should they be dialed in to 75dB as well or should they be a bit higher due to the subtlety of what they do?
Thank you!
Yamaha RX-V675 | Primus 363s fronts | Primus 163 rears | Primus 351 Center | Rythmik LV12R Sub
jnick1 is offline
post #2 of 5 Old 02-26-2020, 07:41 PM
ClawAndTalon's Avatar
Quoted: 653 Post(s)
Liked: 491
Thank you!
Direct turns off Audyssey eq
You can adjust speaker levels to taste and Audyssey otherwise stays the same.
Run Audyssey and call it a day
Turn up atmos speaker +2 from Audyssey.
Squirrel! likes this.
"Most theories on audio and audio reproduction will be proven wrong only when the laws of physics change."
ClawAndTalon is offline
post #3 of 5 Old 02-27-2020, 03:29 AM
jdsmoothie's Avatar
Quoted: 23672 Post(s)
Liked: 13032
jdsmoothie is offline
post #4 of 5 Old 02-27-2020, 04:14 AM - Thread Starter
jnick1's Avatar
Quoted: 71 Post(s)
Ugh, well that’s unfortunate since I’ve had them using “Direct” since I setup the receiver! Is there anyway to make it “auto” so it automatically adjusts the sound mode based on the source signal?
My dad is 70...The last thing I want is for him to have to mess with sound modes every time he watches something or changes the source!
jnick1 is offline
post #5 of 5 Old 02-27-2020, 04:58 AM
Moderator
rboster's Avatar
Quoted: 1722 Post(s)
Liked: 2515
Thank you!
Please don't start individual threads for questions on your Denon receiver or audyssey:
We have an master Audyssey thread that's a sticky:
https://www.avsforum.com/forum/90-re...d-part-ii.html
We have an owner's thread for your make/model of receiver:
https://www.avsforum.com/forum/90-re...sts-1-8-a.html
Please post your questions or follow up questions in the appropriate thread.
rboster is online now
Closed Thread Receivers, Amps, and Processors
