Marantz SR6011,SR5014 or Denon ARV-X3500H? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By afrogt
post #1 of 12 Old 03-28-2020, 11:37 AM - Thread Starter
jtenn's Avatar
Quoted: 98 Post(s)
So were moving and need a new Atmos receiver. We had a Sherwood Newcastle R-972 but that's staying with the old house since it won't do Atmos. The new setup is wired for 5.1.2. The L&R mains are B&W DM580's with a Emotiva C2 center. Looking at accessories4less they have the Marantz SR6011, SR5014 and the Denon AVR-X3500H which are in our price range. I chose these because I felt they would be closer sounding to the R-972 with a warmer sound.
jtenn is offline
post #2 of 12 Old 03-28-2020, 01:30 PM
spacecowboy's Avatar
Quoted: 219 Post(s)
Liked: 168
I'd go Denon if primarily used for home theater. I had the Marantz 6011 and didn't like the port hole. Both will run hot, it's the nature of D & M receivers. With your speakers though, you can't go wrong with either.
"Excuse me...What does God need with a Starship?" (Captain Kirk - Star Trek V: The Final Frontier)
spacecowboy is offline
post #3 of 12 Old 03-28-2020, 02:23 PM
afrogt's Avatar
Quoted: 2433 Post(s)
Liked: 1596
get the x3500 new so that you get the 3 year warranty.
https://www.safeandsoundhq.com/produ...SABEgIOv_D_BwE
accessories4lless is fine unless you have to deal with their return policy.
jtenn likes this.
Afro GT
afrogt is online now
post #4 of 12 Old 03-29-2020, 08:34 PM - Thread Starter
jtenn's Avatar
Quoted: 98 Post(s)
Thanks I'l look into this.
jtenn is offline
post #5 of 12 Old 03-30-2020, 11:08 AM
eriksells916's Avatar
Quoted: 802 Post(s)
Liked: 292
@jtenn the sr5014 has analog inputs and supposed to have that warmer sound, but only has audyssey xt, which cant do the dual sub calibration (semi-independently). The 6011 has those same inputs and warmer sound but it is older. So the x3500 which has xt32, is an excellent choice for HT as Afrogt said ^^^^^^^
Good backup plan here https://www.amazon.com/Onkyo-TX-RZ73.../dp/B07CVPLJZQ
eriksells916 is offline
post #6 of 12 Old 03-30-2020, 11:31 AM
jdsmoothie's Avatar
Quoted: 24221 Post(s)
Liked: 13445
To clarify,
(1) By "analog inputs" you most likely mean the "7.1 multi analog inputs", but although featured on the predecessor SR5013, were dropped on the SR5014.
(2) The feature that provides for the dual sub level/delay capability, is called Audyssey Sub EQ HT, which although currently only provided on XT32 models, does not require XT32.
jdsmoothie is online now
post #7 of 12 Old 03-30-2020, 03:29 PM - Thread Starter
jtenn's Avatar
Quoted: 98 Post(s)
I think I'm going to go with the Denon AVR-X3500H.
jtenn is offline
post #8 of 12 Old 03-30-2020, 10:48 PM
Quoted: 802 Post(s)
Liked: 292
To clarify,
So strange I was just looking at it online the other day, the site must have been using the sr5013 photo because it showed them. I just checked amazon and it shows a blank plate where the analog inputs used to be. Why would they drop those, that was the only reason to get a sr5014 over the x3500? Weird?
post #9 of 12 Old 04-15-2020, 10:52 PM - Thread Starter
jtenn's Avatar
Quoted: 98 Post(s)
So after doing a lot of reading I'm kind of leaning towards the Marantz SR5013. It seems like it will have a warmer/fuller sound.
jtenn is offline
post #10 of 12 Old 04-16-2020, 12:31 AM
jdsmoothie's Avatar
Liked: 13445
However, not as good of audio quality as the models featuring XT32.
post #11 of 12 Old 04-16-2020, 09:08 AM - Thread Starter
jtenn's Avatar
Quoted: 98 Post(s)
Are you referring to audio quality as better room correction software or the actual sound the receivers output?
jtenn is offline
post #12 of 12 Old 04-16-2020, 10:09 AM
jdsmoothie's Avatar
Liked: 13445
Better room correction resulting in better audio quality especially in lower frequency processing.
