Marantz SR7012 and H/K Signature 2.1 power amp (Good idé?) - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By pbz06
  • 2 Post By Leeliemix
post #1 of 9 Old 04-08-2020, 08:44 AM - Thread Starter
OrdinaryClown's Avatar
Quoted: 33 Post(s)
Liked: 4
Hi,
Do you guys think this is a hit?
Can i get better sound if i buy this old H/K power amp and connect it to my Marantz.
A friend of is going to sell it and im intressting in what u guys think. Can i ger more power/clarity to my speaker if i hook it up.
Thankful for tips and thought
Sorry for my English.
OrdinaryClown is offline
post #2 of 9 Old 04-08-2020, 08:56 AM
rocky1's Avatar
Quoted: 610 Post(s)
Liked: 206
Originally Posted by OrdinaryClown View Post
Hi,
What speakers you driving? Why do u think u need an amp?
Sony XBR65A1E,(Pioneer 500m relocated), AppleTv 4K,Marantz sr7012, System Audio Loudspeakers( sa1750 mains), ML Grotto.
Eastern Electric Minimax cd, Oppo UDP-203, Toshiba HD, Pro Ject 1expression Carbon TT.
rocky1 is online now
post #3 of 9 Old 04-08-2020, 09:15 AM - Thread Starter
Quoted: 33 Post(s)
Liked: 4
Hi ,
I have sonus Faber venere 1.5 front and center.
You know how this hobby is, you always Whant to test new things to see if it sounds better. What do you think.
Can i get more ”umph ” in the speakers?
post #4 of 9 Old 04-08-2020, 02:39 PM
pbz06's Avatar
Quoted: 1525 Post(s)
Liked: 1312
It would depend how loud you listen and the sensitivity of your speakers. More power means you have more in the reserve to drive them distortion free and cleanly, but hard to tell if you will need that power and if you will tell a difference. One way to find out
johnson636 likes this.
Sony XBR-77A9G / Panasonic DP-UB9000 / Marantz SR7011 / SVS PB-4000 / Def Tech 9060 Series
pbz06 is online now
post #5 of 9 Old 04-08-2020, 03:00 PM
johnson636's Avatar
Quoted: 1716 Post(s)
Liked: 1211
^^^This
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is offline
post #6 of 9 Old 04-08-2020, 03:08 PM
Quoted: 577 Post(s)
Liked: 291
If its a friend of yours selling you can probably get to try it at your home before deciding anything.
johnson636 and rocky1 like this.
Leeliemix is online now
post #7 of 9 Old 04-08-2020, 04:37 PM
rocky1's Avatar
Quoted: 610 Post(s)
Liked: 206
This was a great point.. and doubt you would need it though. My .02
post #8 of 9 Old 04-09-2020, 12:36 AM
jdsmoothie's Avatar
Quoted: 24133 Post(s)
Liked: 13342
Hi,
Hi ,
The SR7012 provides 125W into 2CH whereas the H/K amp is only 100W so adding it to a 3 speaker setup is not likely to make any difference unless you are currently hearing distortion at your desired listening volume and then only to take a load off the SR7012 or use it to expand to an 11 speaker Atmos setup.
jdsmoothie is offline
post #9 of 9 Old 04-11-2020, 08:38 AM - Thread Starter
Quoted: 33 Post(s)
Liked: 4
I have up and running now, and didnt expect much.
But i was wrong, the Marantz is an awesome machine but the HK did something to the sound. Its hard to explain, my Wife even notice 🙂
The sound its a little deeper a little clearer and as a friend said. Its like someone took alway a drape from the speakers.
Its a new sound that i like.
