AV receiver choices - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-09-2020, 09:25 PM - Thread Starter
Liked: 0
AV receiver choices
Doing a 5.1.2 system in a non dedicated room approx 18 x 14. Tv centered on the 18’ wall with Klipsch speakers RP 8060 fronts.
I’ve basically narrowed it down to 3 receivers
Pioneer Marantz Yamaha
Model Number
SCLX704 SR6014/U1B RX-A2080BL
And pros and cons of the 3 Or should I look at something else
Thanks in advance
Tkcookers is offline
post #2 of 11 Old 04-10-2020, 06:52 AM
badtlc's Avatar
Quoted: 651 Post(s)
Liked: 291
IMO the only real differentiator is that the Marants will have audyssey with subEQ if ever run dual subs. If that doesn't apply to you, pick whatever you like best.
Front: Polk S55
Center: Polk S30
Rear: Polk S10
Sub: P̶L̶-̶2̶0̶0̶I̶I̶ | (̶2̶)̶ ̶F̶V̶X̶1̶2̶ | V1812
badtlc is online now
post #3 of 11 Old 04-10-2020, 07:03 AM
spacecowboy's Avatar
Quoted: 219 Post(s)
Liked: 168
This
"Excuse me...What does God need with a Starship?" (Captain Kirk - Star Trek V: The Final Frontier)
spacecowboy is offline
post #4 of 11 Old 04-10-2020, 07:05 AM
johnson636's Avatar
Quoted: 1731 Post(s)
Liked: 1239
To add to the previous post, the sr6014 will have the option to run calibration and adjust your eq curve with the Audessey app
Automation: Alexa- Harmony Hub- Wemo Dimmer Switch- Wemo Smart Plug BatCave: SY Triple Black
Video Image: JVC RS500- Sony UBP-800X- Chromecast- 125" wide 16x9 white over black spandex screen
Audio: 5.2.4 Marantz SR7011- (LCR) QSC 2180 - (Surrounds) (4) BIC FH6-LCR- (Atmos) (4) Dayton Audio B652 6-1/2-Inch- (Subs)2 23ishcuft ported HS24s 14-15Hz tune - 2 Devastator Minis B&C21ds115 - 4 PA460 in ported cabs 40Hz tune- FP20000Q- 2 Sanway FP10000Q- Crown XLS1500- . To be continued...
johnson636 is online now
post #5 of 11 Old 04-10-2020, 08:34 AM - Thread Starter
Liked: 0
The Marantz was my first choice but I’ve been out of it so long that the input truly helps
post #6 of 11 Old 04-10-2020, 10:17 AM
bobknavs's Avatar
Quoted: 2854 Post(s)
Liked: 2064
If you were running 4 ohm speakers, I'd suggest a closer look at the Pioneer, as it's the only Class D system among your choices.
But you aren't, so it doesn't matter.
Have you considered the Denon AVR-X3600H? It has a very similar feature set to the Marantz SR6014, at a lower price. I can't speak to the value of the Marantz "HDAM" circuitry; some swear that it's great, others that it produces no audible advantage. I am not fond of the Marantz "porthole" display.
bobknavs is offline
post #7 of 11 Old 04-10-2020, 10:37 AM
Quoted: 714 Post(s)
Liked: 375
As most current receivers are now network enabled, check out the apps for each system -each are a closed ecosystem (with the exception of the Pioneer (play-fi)). HEOS is solid. Play-fi is decent. I haven't tried the yamaha musicast.
The whole house audio doesn't get much love or consideration in this particular forum. But I have found at least the app control (which is different than the whole house) is a feature you never knew you needed until you have it.
good luck.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Ascend Acoustics Duo,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is online now
post #8 of 11 Old 04-10-2020, 11:46 AM
spyboy's Avatar
Quoted: 360 Post(s)
Liked: 294
This
spyboy is offline
post #9 of 11 Old 04-14-2020, 11:45 PM
philpoe's Avatar
Quoted: 174 Post(s)
Liked: 64
The Marantz SR6013 is from the previous model year, and has almost identical features of the SR6014 (and Denon AVR-X3600H) for less money, and can be found as an open-box clearance item.
The Denon AVR-X3500H satisfies the 5.1.2 requirement and still has the Audyssey MultiEQ XT32 of the Marantz for even less money, and can be found as an open-box clearance item.
... Or should I look at something else
Thanks in advance
philpoe is offline
post #10 of 11 Old 04-20-2020, 02:27 PM
iserum's Avatar
Quoted: 336 Post(s)
Liked: 141
I have Pioneer Sc95 and Marantz 6013,i would pick Marantz over Pioneer, it is so easy to setup, calibration is breeze, overall the whole package is better, sound is very good both in music and HT. you can calibrate two sub individually, each cross over can be set individually. if one can get 6013 it is well priced due to discounts.
SONY 75X900F: Oppo UDP-203: DirecTv 4K: ATV4K
Marantz SR6013: Parasound 2250 V2: Aircom T8: Dolby Atmos 5.2.4
Definitive Tech. BP9060, CS 9060 HD: Mythos GEMS
Subwoofer Paradigm X12: Belkin PF30: Panamax M8-AV Pro
Harmony Elite Remote: Philips Hue Ambient Lights: 6500K Bias LED Lights
iserum is online now
post #11 of 11 Old 04-20-2020, 08:24 PM
Quoted: 714 Post(s)
Liked: 375
I would suggest to pull down the apps for each one. you have 3 different ecosystems for music-over-wifi as well
Marantz(denon): HEOS
Yamaha: Musicast
Pioneer: playfi and Chromecast (IIRC)
