What type of receiver for this room - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By solarrdadd
post #1 of 21 Old 05-01-2020, 09:34 AM - Thread Starter
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
For this size and listening position, what type of receiver should I get, 5.2 or 7.2 or 7.2 with Dolby DTS:X
I am choosing between the 3 receivers below
Amp Power is not an issue as Front speakers will be powered by a separate power amp
Name:	speaker setup.png
ID:	2719398   Click image for larger version
ID:	2719406   Click image for larger version
Name:	speaker setup 2.png
qguy is offline
post #2 of 21 Old 05-01-2020, 09:45 AM
JD23's Avatar
Quoted: 1067 Post(s)
Liked: 835
Only the SR5014 has full pre outs, so I would choose it for that reason alone.
JD23 is online now
post #3 of 21 Old 05-01-2020, 09:52 AM - Thread Starter
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
I only need pre-outs for the fronts, 50 watts from the AVR should be enough to power small rears and atmos speakers
qguy is offline
post #4 of 21 Old 05-01-2020, 09:59 AM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
NR1710, it will give you 5.2.2, pre-outs for connecting a 2 channel amp for your Front L & R and it both Dolby Atmos & DTS:X
qguy likes this.
TCL-65R615, 55P605 DV/HDR10 & 49S405 HDR10, Philips BDP7501, BPD7502 UHD Players
Oppo BDP-105D, 105, 93, Marantz AV7702MKII, NR1607. Xbox One S
Emotiva XSP-1, XPA5,UPA2, UPA200 & Mini X Amps, ATV4K 32gb
Speakers, Polk SDA-2, Monitor 10A & 5A, Axiom M80,
VP180, QS8, M2, QS4, ATMOS 7.1.4 & 5.1.2 NYGiants!
solarrdadd is online now
post #5 of 21 Old 05-01-2020, 10:02 AM - Thread Starter
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Given my room size and seating arrangement, can I properly setup a 5.2.2 system ?
qguy is offline
post #6 of 21 Old 05-01-2020, 10:02 AM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
you can't have both at the same time, it's either or it's a 7 channel amp and the primary 5 are not assignable. you must choose either rear surrounds (lower bed) OR heights (higher bed)
post #7 of 21 Old 05-01-2020, 10:03 AM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
of course.
post #8 of 21 Old 05-01-2020, 10:14 AM - Thread Starter
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Can you please dumb this down a bit, I am a 2.1 person, i have setup 5.1 for friends but nothing beyond 5.1
qguy is offline
post #9 of 21 Old 05-01-2020, 10:55 AM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
not sure how to make it any dumber JK, but seriously, you can only have either 7.2 or 5.2.2 a total of 7 amplified/processed channels (not including the sub(s) which you can have a maximum of two, hence the .2)
have you not looked at the rear layout of the receiver. notice the channel 6 & 7 (surround rear) have the word assignable at the bottom? well, that means that you can have a pair of speakers connected to them and they can be used as surround rear OR height. any dumber than that, someone else is gonna have to help you.
hope it helped.
again, bottom line, you can only have 7 amplified channels processed, period.
qguy likes this.
post #10 of 21 Old 05-01-2020, 11:08 AM
the7mcs's Avatar
Quoted: 553 Post(s)
Liked: 254
Let’s start with the very basic simple question first
What do you wanna do?
5.1 floor speakers with 2 height speakers
Or
7.1 floor speakers with 2 height speakers
the7mcs is offline
post #11 of 21 Old 05-01-2020, 11:16 AM - Thread Starter
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Got it !!! thanks, the 6 & 7 channels that can be assigned is all new to me
qguy is offline
post #12 of 21 Old 05-01-2020, 11:21 AM - Thread Starter
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Or
Honestly I do not know which would be best given the room layout.
I have fronts that would be floorstander
The rest rears/atmos/surrounds can only be placed anywhere at the ceiling which is 8 ft high.
MLP is 5ft from the backwall
qguy is offline
post #13 of 21 Old 05-01-2020, 11:43 AM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
Or
the receiver can't do that, it's a 7 channel ONLY receiver. what you just said is a 9 channel receiver.
NR1710
you can reassign two channels to be either surround back L&R or height L&R, a total of 7 channels, 7.2 or 5.2.2 since he wants ATMOS/DTS:X if he doesn't not want upper bed channels, then he can go either 5.2 or 7.2 but that's it
post #14 of 21 Old 05-01-2020, 11:46 AM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
you really need to do some youtube video watching on ATMOS/DTS:X layouts.
the only speakers that should be on the ceiling are heights, conventional surrounds (side or rear) should be down as close as possible to ear level when seated.
post #15 of 21 Old 05-01-2020, 12:02 PM - Thread Starter
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
There is no option for the rear / side speakers to be at floor level.
Unless they are this small
How would really small speakers for rears affect the experience when mated to larger fronts with 12 inch woofers. Subwoofers would be 12 and 18 inches located behind MLP
qguy is offline
post #16 of 21 Old 05-01-2020, 12:07 PM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
ok, then you won't get the proper effects at all for ATMOS/DTS:X if you were interested since you are saying your going to have to have surrounds/heights all mounted up on the ceiling. there will be no audio differential for you to hear. you might as well just go with conventional 5 or 7.x system and not do ATMOS/DTS:X
post #17 of 21 Old 05-01-2020, 12:09 PM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
Unless the are this small
well with that quick edit the size of speaker is up to you and your listening pleasure. i'll say it again, if surrounds and height speakers are all going to be mounted on the ceiling, it makes absolutely no sense to do ATMOS/DTS:X as it won't sound correct.
also, i said ear level when seated, not floor level.
post #18 of 21 Old 05-01-2020, 12:11 PM - Thread Starter
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Would it be better to have regular bookshelf for rears but up in the ceiling or really small speakers at ear level ?
qguy is offline
post #19 of 21 Old 05-01-2020, 12:13 PM
solarrdadd's Avatar
Quoted: 477 Post(s)
Liked: 334
those are personal preferences, you gotta decide something for yourself. how about first determining the setup you want then the nature and type of speakers you will go with to fit your layout.
post #20 of 21 Old 05-01-2020, 12:18 PM - Thread Starter
qguy's Avatar
Quoted: 404 Post(s)
Liked: 195
Since the 7.2 is configurable, I think I will go with that type of receiver, as for the rears, since I already have the "large" rear speakers, might as well install that on the ceiling and see how it goes. I can eventually try smaller rears at ear level
Thanks again
qguy is offline
post #21 of 21 Old 05-01-2020, 12:27 PM
the7mcs's Avatar
Quoted: 553 Post(s)
Liked: 254
NR1710
Ummm I know that
I asked it that way specifically to eliminate the fact that the guy is 100% that a 5.1 with 2 height is what he is going for
some times the naming configuration can be difficult for some people when first starting out. I've seen people think that a 7.1 ONLY receiver could allow them to do 7.1 floor speakers and they can add an external 2 channel amp to add height speakers
Of course the confusion part comes from the fact that there are some models that are 7.1 that can be expanded while there are some 7.1 that can't and can only strictly do 7.1 without ability to expand via any other way
And since my friend here wanted to add an amp for his front stage he could also be thinking that by doing that it can free up the 7 channels in the AVR
So that's why I broke it down in simple dumb terms first to get a basic understanding of what he is trying to accomplish with his set up
the7mcs is offline
