2 Channel amp with sub out + bass management - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Mart34
post #1 of 17 Old 05-23-2020, 04:13 AM - Thread Starter
Liked: 5
Hi,
Does anyone know of a 2 channel hifi amplifier with sub out, that also includes bass management. I mainly need the ability to set crossover (low pass on sub out and high pass on the amps 2 speaker outputs), and as importantly a distance setting for phase alignment of the sub (where I'll delay the amps 2 speaker outputs), to compensate for the subwoofer hardware inherent delay.
Martin
Mart34 is offline
post #2 of 17 Old 05-23-2020, 06:09 AM
jrampoldi's Avatar
Liked: 3
Anthem STR Integrated Amplifier $3,600
https://www.anthemav.com/products-cu.../page=overview
jrampoldi is offline
post #3 of 17 Old 05-23-2020, 06:35 AM - Thread Starter
Liked: 5
Thanks. Interesting product, but doesnt quite fit my budget, 1000 dollars absolute max would be ideal. Good to know there are products out there though. Thanks
jrampoldi likes this.
Mart34 is offline
post #4 of 17 Old 05-23-2020, 06:46 AM
tjcinnamon's Avatar
Quoted: 2120 Post(s)
Liked: 633
Again out of budget. This one is 2000 but looks cool! https://nadelectronics.com/product/m...ing-amplifier/
I think they use a modified Hypex NCore amp.
NAD 758 v3 with Dirac 7.6.4 + Rotel 976 + Panamax M5300-PM + B6 OLED 65
Speakers: Paradigm Prestige 75F's + 55C; 8x Paradigm CI Pro P65-R's
Subs1: 2x LRK Build Thread + 2x Rotel 981 (bridged); retired: VRK Build thread
Subs2: 2x Rythmik LVX12; 2x Dayton HF 12's Ultra-NearField + Crown XLS 2002
MiniDSP HD & Non; DIY Room Treatments: Dutch Floral Prints
tjcinnamon is offline
post #5 of 17 Old 05-23-2020, 06:56 AM - Thread Starter
Liked: 5
Thanks. Interesting that one has an ncore amp. If I had the money, I'd buy two NC400 kits and a better minidsp unit for running full range. I currently have a minidsp 2x4 HD in between my av amp and subwoofer amp. Tried using it full range once like a pre-amp, but wasnt happy with sound quality - the high frequencues got trashed by it.
Martin
Mart34 is offline
post #6 of 17 Old 05-23-2020, 07:05 AM
tjcinnamon's Avatar
Liked: 633
Martin
Ha! I was going to tentatively suggest a MiniDSP HD as an active crossover but I agree, I don't trust the sound quality even on the HD. It changes the sound per my own REW measurements. I'm looking to DIY in the future. I'll say this, the NAD 758v3 AVR is still around and can be found on clearance. It's got a solid amp but it's got integrated Dirac Live which is a game-changer for sound. I'd highly recommend that and it would fall in your price point and meet your requirements.
Dang! https://www.safeandsoundhq.com/produ...ry-refurbished
you could probably find one somewhere.
post #7 of 17 Old 05-23-2020, 08:04 AM
Quoted: 697 Post(s)
Liked: 368
check out outlaw audio : https://outlawaudio.com/shop/index.p...oller=category
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Ascend Acoustics Duo,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #8 of 17 Old 05-23-2020, 09:11 AM - Thread Starter
Liked: 5
Thanks. Yeah, such a shame about the 2 x 4 HD on full range. Would definitely pay couple hundred extra for a minidsp 2 x 4 UHD, which addresses DAC quality and noise issues. But for sub duty, you cant get better, such a cool piece of kit.
Thanks for NAD and outlaw ideas, worth considering.
Another minidsp product I've found is the minidsp SHD power which has built in 2 ch amp.
Not sure about plugin capabilities though, and yet again DAC and amp quality. Have to wait for some reviews.
Mart34 is offline
post #9 of 17 Old 05-23-2020, 09:15 AM - Thread Starter
Liked: 5
Here's the link to the minidsp SHD power -
Mart34 is offline
post #10 of 17 Old 05-23-2020, 09:15 AM - Thread Starter
Liked: 5
https://www.minidsp.com/products/streaming-hd-series/shd-power
Mart34 is offline
post #11 of 17 Old 05-23-2020, 09:47 AM
grasshoppers's Avatar
Quoted: 975 Post(s)
Liked: 719
Outlaw Audio RR2160 stereo receiver-has the features you need at your price point
https://www.outlawaudio.com/products/rr2160_about.html
https://outlawaudio.com/shop/index.p...roller=product
I've been very pleased with my rr2150 for several years.
I purchased it because of the bass mgmt ability
(Main)-Marantz 6012*Outlaw Audio M2200*Rythmik F12 subs*Paradigm Signature S6,C1,S1
******Harman Kardon DMC1000 (music)-Assassin HTPC (movies).
(Bedroom)-Marantz SR5003*Paradigm Studio 40,SE Center,SE One*SVS SB-2000 subs*Sony S6200
(Music room)-Outlaw Audio RR2150*Sierra Two ribbon speakers*Rythmik L12 sub*Yamaha CDR-HD1500
grasshoppers is online now
post #12 of 17 Old 05-23-2020, 12:58 PM - Thread Starter
Liked: 5
Thanks. I'm starting to be won over by the outlaw if im honest. It has crazy retro looks and all the features I need. I'm in UK, and have added it to Ebay saved searches. Fingers crossed one turns up for sale. I'll maybe need to learn amp refurbishing, but that's right up my street. Rather do DIY, than outright purchasing consumer products. Think it's this, or go some sort of minidsp pre-amp route with hypex ncore amps.
Thanks for everyones advice, much appreciated. Martin
Mart34 is offline
post #13 of 17 Old 05-23-2020, 01:03 PM
rdgrimes's Avatar
Quoted: 4058 Post(s)
Liked: 3379
Yamaha has a few stereo receivers:
https://usa.yamaha.com/products/audi...x.html#d366107
rdgrimes is online now
post #14 of 17 Old 05-23-2020, 03:03 PM
Osamede's Avatar
Quoted: 76 Post(s)
Liked: 57
Hi,
Martin
Pioneer VSX-S510 or S520 or the Onkyo equivalents are a good backdoor way to do this. 5 channel but so, what - just use two channels only.
https://www.avsforum.com/forum/90-re...l#post57008670
Osamede is offline
post #15 of 17 Old 05-23-2020, 03:12 PM - Thread Starter
Liked: 5
Thanks, think you're right with the Yamaha, Pioneer and Onkyo products, easily obtainable in UK market. This is a no brainer, thank you ever so much
Can't figure out why my minidsp SHD power didn't link properly -https://www.minidsp.com/products/str...ries/shd-power
Mart34 is offline
post #16 of 17 Old 05-23-2020, 08:32 PM
Parasound's P5, 6 and 7 also have decent sub-outs and management...
But these are preamplifiers.
Daniel
Sent from my Mi MIX 3 using Tapatalk
lcheetec is online now
post #17 of 17 Old Yesterday, 09:17 AM
jrampoldi's Avatar
Liked: 3
Parasound NewClassic 200 Integrated $1,100 - $1,200
https://parasound.com/200_Integrated.php
