Monoprice Unity 100 to add 2 channels to X4400 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-23-2020, 07:24 AM - Thread Starter
ed3120's Avatar
Quoted: 212 Post(s)
Liked: 24
I have a Denon x4400, which has 9 amps. I want to buy a small amp to power the top rears. Does the Monoprice Unity 100 have enough power with 50 w per channel to keep up with the other channels in the x4400 or do I have to step up to the Unity 200?
ed3120 is offline
post #2 of 3 Old 05-23-2020, 07:47 AM
Quoted: 715 Post(s)
Liked: 375
if you are using for rear heights, then it should be fine. While I do not have direct experience with the monoprice unit, I was using an Audiosource 1002D (50 wpc) at one point with my 4400 and there was no issue.
If you want a little more power at better price point (as wellas form factor) check out this unit from outdoor speaker depot: https://www.outdoorspeakerdepot.com/...er-xmp100.html
good luck
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Ascend Acoustics Duo,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #3 of 3 Old 05-23-2020, 11:36 AM
jdsmoothie's Avatar
Quoted: 24247 Post(s)
Liked: 13479
The X4400H is discussed in the 2017 Denon AVR Owner's thread --> https://www.avsforum.com/forum/90-re...sts-1-8-a.html
Review posts 1-8 for general helpful information. Post 8 specifically discusses expanding the X4400H from 9CH --> 11CH.
jdsmoothie is online now
