Budget 7.1.4 receiver lineup - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 05-26-2020, 09:13 AM - Thread Starter
dauber65's Avatar
Quoted: 76 Post(s)
Liked: 36
Guys, I've been making a short list of receivers that can do 7.1.4 processing with the use of a 2 channel external amp.
It is a confusing area to search for since most are "9 channel" receivers. You have to hunt around to tell if they process 11 channels or not.
Did I make any mistakes on this list? Can you help me add anymore to this list?
I do not want to put any receivers on my list that will cost over 1K used. I am trying to spend as little as possible to get a nice 7.1.4
My initial though is to wait awhile and see if I can find a X3600H, but wanted to see what else might be out there.
Receiver Processing Amplified [email protected] Ohms
Denon AVR-X3600H 11 9 105
Denon AVR-X4500H 11 9 125
Onkyo TX-RZ730 11 9 100
Onkyo TX-RZ740 11 9 100
Pioneer SC-LX701 11 9 135
Denon AVR-X6500H 11 11 140
Marantz SR6014 11 9 110
dauber65 is offline
post #2 of 12 Old 05-26-2020, 09:25 AM
electronics craz's Avatar
Quoted: 107 Post(s)
i have pioneer 503 with amp its awesome
electronics craz is offline
post #3 of 12 Old 05-26-2020, 09:45 AM
Liked: 3
Onkyo RZ-830 / 840
bballjames is offline
post #4 of 12 Old 05-26-2020, 10:45 AM
Quoted: 160 Post(s)
Liked: 110
Receiver [email protected] Ohms
Denon AVR-X3600H11 9 105
Denon AVR-X4500H11 9 125
Onkyo TX-RZ73011 9 100
Onkyo TX-RZ74011 9 100
Pioneer SC-LX70111 9 135
Denon AVR-X6500H11 11 140
Marantz SR601411 9 110
I'd like to suggest Yamaha A3080. 150wpc
However, if I may add some words of wisdom, I'd not go purely on WPC since most (I think your entire list) depicts these numbers are "2 channel driven" as in only when 2 out of the 9/11 inbuilt amps are used. When you divide it into 11 amplifiers, it is a lot lesser.
Sent from my HD1911 using Tapatalk
MOVIE TIME STAMPS FOR REFERENCE QUALITY MOVIES
HOME THEATER Epson 8300/5040UB|Black Diamond 133” 2.35:1|KefT301 x3|KefT101 x4| 2 x Atmos|Rythmik FVX12x2|Nvidia Shield Pro 2019|FreeNAS|Yamaha A3070
LIVING ROOM Harman Kardon SB26 Sony 49” 4K Android
BEDROOM Sony EX700 40”|Nvidia Shield 2019
BhootZ is offline
post #5 of 12 Old 05-26-2020, 10:49 AM - Thread Starter
dauber65's Avatar
Quoted: 76 Post(s)
Liked: 36
Added to my list. This is a good choice as I've seen several sell for a very reasonable prince on e-bay used.
dauber65 is offline
post #6 of 12 Old 05-26-2020, 10:51 AM - Thread Starter
dauber65's Avatar
Quoted: 76 Post(s)
Liked: 36
Good point, but honestly the wattage has very little impact to my choice. I'm basically looking for the processing power. I hardly ever listen with that much power.
I currently have an Onkyo TX-SR606 that is rated at 90 watts and its more than enough power for me.
However, it is interestingly rated at 90 watts on all 7 channels, unlike the 2 channels I see most listed these days. So maybe they are similar?
90 watts x 7 into 8 ohms (20-20,000 Hz) at 0.08% THD
dauber65 is offline
post #7 of 12 Old 05-26-2020, 01:52 PM
Quoted: 160 Post(s)
Liked: 110
Yeah. A lot of corners being cut in equipments and with a few play of words, it becomes 'legal to sell'. I've been on Yamaha A3070 for the last 2 years. I have found it to be super awesome except the ypao being really bad with bass I can't complain about the amp. Knowing this I picked it over the denon 4400h and marantz 6012 (I think) back in the day.
BhootZ is offline
post #8 of 12 Old 05-26-2020, 02:55 PM
Mashie Saldana's Avatar
Quoted: 1481 Post(s)
Liked: 1359
You can add Marantz SR7010, SR6011, SR6012 and SR6013 to that list.
Tower Cinema - 9.1.6 in a 12'x12' room
Input : Nvidia Shield TV, Panasonic DMP-UB400
Magic : Marantz SR7010, Marantz SR6010, 2x NAD T743
Output : Panasonic TX65EZ952B, SVS PB13 Ultra, Monitor Audio GSLCR 2xGS20 2xGS10 4xGSFX 6xBX1
Mashie Saldana is offline
post #9 of 12 Old 05-26-2020, 07:02 PM
hdtv00's Avatar
Quoted: 295 Post(s)
Liked: 160
NO WAY those specs are accurate. NO way.
... but in our Tech Labs, we measured the receiver's real world output at 122W in two-channel mode, dropping to just 38W with five channels driven (at 8 Ohms).
This is what they claim it is, above is actual bench testing. It's why I left receiver world and will NEvER return. It's turned into lie after lie to cut corners and still make money. See they list 7 channels but its 6 ohm load so boost watts. Then rates each other channel ALONE but in 8 ohm to make those numbers look better than reality of the above actual numbers.
  • Amplifier Output Details
    110 Watt - 6 Ohm - at 1 kHz - THD 0.1% - 7 channels (surround)
    90 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08% - 2 channels (front)
    90 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08% - 1 channels (center)
    90 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08% - 2 channels (surround)
    90 Watt - 8 Ohm - 20 - 20000 Hz - THD 0.08% - 2 channels (surround back)
Marantz 7702MKII/Outlaw 7140 65" 4k LG C9
i7 4770K/16 gig 2133/970's SLI 840 PRO SSD
Paradigm Studio v3 100/570/20's/470's/2200 Sub
hdtv00 is offline
post #10 of 12 Old 05-26-2020, 08:53 PM
bobknavs's Avatar
Quoted: 2899 Post(s)
Liked: 2094
Are you referring to the TX-SR606 (from 2008), or a more current model?
A review, with measurements: https://www.soundandvision.com/conte...-labs-measures
Sound and Vision claims 73.2W/channel for 7 channels into 8 ohms with 0.1% distortion. 87.4W at 1% distortion. I can't claim any knowledge of the validity of their tests, but they are one of the few sources I know of that do multichannel testing. The main argument against their claims is that the AVR is a 25 lb unit; no massive power supply.
bobknavs is offline
post #11 of 12 Old 05-27-2020, 11:06 AM - Thread Starter
dauber65's Avatar
Quoted: 76 Post(s)
Liked: 36
It likely is that year.
dauber65 is offline
post #12 of 12 Old 06-03-2020, 08:24 AM - Thread Starter
dauber65's Avatar
Quoted: 76 Post(s)
Liked: 36
So I have updated my list. It is now rather large.
Now I just need to find one an external amp for a reasonable price. I finished my wiring for 7.1.4 today and have all the speakers ready.
Denon AVR-X3600H
Denon AVR-X4500H
Denon AVR-X6500H
Onkyo TX-RZ730
Onkyo TX-RZ740
Onkyo RZ-830
Onky0 RZ-840
Pioneer SC-LX701
Pioneer VSX-LX503
Pioneer VSX-LX504
Marantz SR7010
Marantz SR6012
Marantz SR6014
Sony STRZA5000ES
Yamaha RX-A2020
Yamaha RX-A2030
Yamaha A3080
dauber65 is offline
