Cheap 2 channel amp for Patio - AVS Forum | Home Theater Discussions And Reviews
 3Likes
  • 1 Post By myhikingboots
  • 2 Post By myhikingboots
post #1 of 8 Old 05-29-2020, 03:45 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 35
I have a Marantz SR-6014 that until recently I was using the zone 2 capabilities to play Sonos on two patio speakers. But once I added rear surrounds to my living room setup, I've ran out of usable amplifiable channels. The receiver can only send a pre-amp signal out for zone 2 now, so I need a small amp, preferably under a $100 bucks, that outputs around 50 to 100 watts per channel. Doesn't need volume controls and doesn't need to be hifi, although I don't want it to sound like a P.A. system either. Trigger on/off capabilities would be nice, but I can work around that with my harmony hub. Other work around ideas are welcome.
Gear Front Stage: Polk LSiM 707s Ctr: LSiM 706c
Srd: LSiM 703s Ht: 700-LS Rears: Cheap Infinity book shelves
Amps: Marantz SR6014 and MM7055
Sony Ubp-X800M2, Xbox, Sony 75" X900F
myhikingboots is offline
post #2 of 8 Old 05-30-2020, 09:08 AM
philpoe's Avatar
Quoted: 254 Post(s)
Liked: 100
These don't quite hit your price point, but offer what you want. As you examine them, you'll see that it's likely that they use the same design, so I'd imagine that they perform similarly.
https://www.parts-express.com/dayton...ifier--300-593
https://www.russound.com/products/am...urce-amplifier
https://www.outdoorspeakerdepot.com/...er-xmp100.html
The Dayton has 60WPC, and has a potentially unneeded bluetooth feature, but costs a little less than the others. They use to have a model without bluetooth, but it was discontinued.
The other models have 75WPC.
Besides trigger capability, these models have auto on/off capability, so should wake up when music plays, then time out and turn off when it stops.
You may consider getting any of these on Amazon Prime or the Russound at Best Buy (with Amazon/Internet price match?) to use their return policies to test.
philpoe is online now
post #3 of 8 Old 05-30-2020, 09:14 AM
MRAYB's Avatar
Quoted: 549 Post(s)
Liked: 2266
@myhikingboots .....Work great. Use for Zone 2 and 3 here at different times with my Denon. Great value for the money. I recall several other members recommending these in the past. That's how I heard of them after all.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
MRAYB is online now
post #4 of 8 Old 05-30-2020, 10:06 AM
Quoted: 746 Post(s)
Liked: 398
three are plenty of these little class D amps via ebay/amazon and will work well. only thing is they don't have auto on feature.
this model for parts express does have auto on, but may be underpowered. https://www.parts-express.com/dayton...ifier--300-330
you can find plenty of audiosource amp100VS used on ebay at your price point (https://www.ebay.com/itm/AudioSource...8AAOSw~rxexaCm)
you may find a suitable open box at monoprice at your price point
right now, the best pricing is at outdoorspeakerdepot.com
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Ascend Acoustics Duo,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #5 of 8 Old 05-30-2020, 12:02 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 35
I think I'll try this one, seems about right.
Thanks everyone for the suggestions!
MRAYB likes this.
post #6 of 8 Old 05-30-2020, 12:44 PM
MRAYB's Avatar
Quoted: 549 Post(s)
Liked: 2266
Good deal. Currently using two of them. One for a pair of DCM 160S bookshelves RearHeight in the 11.4 main room and another for a couple Dayton AudioAir 6 1/2inch on the patio. They play very nicely with the Denon X4400H
MRAYB is online now
post #7 of 8 Old 06-06-2020, 06:26 PM - Thread Starter
Quoted: 36 Post(s)
Liked: 35
Got the amp today from Amazon and it works perfectly. Thanks again.
MRAYB and Peja like this.
post #8 of 8 Old 06-06-2020, 06:50 PM
MRAYB's Avatar
Quoted: 549 Post(s)
Liked: 2266
Cool. They are great for their intended purpose.
MRAYB is online now
