Is it worth upgrading 5 year old receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-02-2020, 06:54 PM - Thread Starter
aaks38's Avatar
Quoted: 38 Post(s)
Liked: 27
Ive got a 5 year old denon avr x4200w which ive been happy with overall but have had the itch to upgrade but not sure if any of the current formats are worth upgrading to. The receiver supports atmos and has xt32 cal but ive been reading about the latest gen receivers with Dirac live and Imax processing and atmos height. I cant gauge if these are worth upgrading to or is best to wait for some format thats on the horizon. Thanks for the help.
aaks38 is offline
post #2 of 6 Old 06-03-2020, 12:24 AM
philpoe's Avatar
Quoted: 254 Post(s)
Liked: 100
What does the X4200W not do that you want it to?
It already supports Atmos, DTS:X on the audio side, and HDR10, Dolby Vision and HLG on the 4K HDR side.
For Imax, you'd have to see how much content is available, and if the difference is noticeable for the cost.
If it's room correction, at least one analysis shows data about performance of the system (which may help you decide if the other systems are worth it):
https://www.audiosciencereview.com/f...-review.12746/
The X4200W also allows for 5.2.4 Atmos setup with an external amplifier. Unless considering going to 7.2.4, adding an amplifier might be more economical than replacing the AVR with a newer one with 9 amplified channels (AVR-X4500H, AVR-X3600H).
If you can't install ceiling speakers, Atmos virtual height functionality could make a difference. You'd have to weigh the cost.
Probably the biggest thing that Denon added over the years was Heos capability and internet streaming apps. There's no inexpensive way to add it to the AVR.
Airplay 2 compatibility is pretty much the same thing. Newer Denon AVRs get Airplay 2 compatibility and it's not easy to add with an external device.
If you don't have any other ecosystem, Play-Fi is very inexpensive to add to any amp or receiver via RCA jacks with the Phorus PR5.
If playing 4K video, the X4200W can't overlay the GUI or info/volume over it.
There's no future-proofing with any current AVRs for 8K video, so you may consider holding out for that.
philpoe is online now
post #3 of 6 Old 06-03-2020, 02:56 AM
onesolo's Avatar
Quoted: 117 Post(s)
Liked: 51
If you don't need any HDMI 2.1 feature, I'd say, stick with it, because the current and future (from 2020 and 2021) AVRs are half baked, maybe in 2 or 3 yrs there's gonna be models with full HDMI 2.1 support
LG OLED55C9PLA; Onkyo TX-NR808; Xbox One S; Nvidia Shield TV (1st gen); PS3; Cambridge Audio Azur 640C; Logitech Harmony 650
Wharfedale Diamond 9.4 / 9 CS / 9.1; BK Gemini; Just Racks JRA120‑SW‑BG
2x3m e 2x10m Supra 2.5 Classic; 3m QED P-CV1; 1m QED P-75; 3m Ixos XFA02
onesolo is offline
post #4 of 6 Old 06-03-2020, 03:14 AM
torii's Avatar
Quoted: 4416 Post(s)
Liked: 2596
I wouldnt.
Power: Marantz sr7008, NAD C 275Bee x 2, Video: Oppo 103, Samsung 75un6300 LG oled c9 77
Speakers: Focal aria 948, Focal cc900, Klipsch synergy KSF 10.5, Magnepan LRS, Audioengine A2+
Subs: Rythmik FV25HP, Rythmik FV15HP, Velodyne HGS 12, Velodyne VA1512
torii is offline
post #5 of 6 Old 06-03-2020, 10:03 AM
Quoted: 746 Post(s)
Liked: 398
I'd say it's worth it for the HEOS capability. if streaming music does not interest you, then stick with it.
Main: Sony XBR75900E, Denon AVR-x4400, Denon POA-5200 (L/R(a) Goldenear supersat 60, (b)FW Boston acoustic Bravo 2. C Ascend Acoustics Duo,
SSR DIYSG Volt 6v2. RSS Volt 6, Atmos(.4) Boston acoustics soundware
HSU research ULS -15, Episode ES-IW-Dual 8 / Monitor audio IWA 250 amp 2nd Rm: Visio E55, Denon avr730H, Boston Acoustics CR8, cr400 sub.
smithsabom is offline
post #6 of 6 Old 06-03-2020, 09:44 PM - Thread Starter
aaks38's Avatar
Quoted: 38 Post(s)
Liked: 27
Thanks for the feedback, I guess my key interest was Dirac Live and the newer atmos height and Imax processing but now realize i probably won't be gaining much.
aaks38 is offline
