Higher-End Receivers or Separates - Finding TV Stands they fit in... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 06-03-2020, 09:29 AM - Thread Starter
Zippy_Dan's Avatar
Anyone have any idea where one can buy a tv stand (under $500) that is 19"+ deep? I've looked some at:
- Wayfair
- Target
- City Furniture
- Ashley
- Rooms-to-go
- Haverty's
- Allmodern.com (owned by Wayfair)
and a few others with no luck.
I'm not paying to have something custom made - and I don't want to buy a Salamander Designs cabinet/tv stand for $1,000+. I don't care that much about the look. Just need it to fit the receiver. I currently have a Pioneer Elite SC-05, and am ironically going to upgrade (likely) to an Integra 50.6, but even the Integra is about 16" deep - then you need to fit the cables behind the receiver.
I will Cut extra holes (and add fans) to the back of the furniture as needed to provide proper airflow - so again - I'm NOT looking for something custom and fancy - that part I can do myself cheaply... just need it to fit the receiver.
I can't be the only one with this problem - AND wanting something my kids won't mess with all the time (or trash).
Zippy_Dan is offline
post #2 of 10 Old 06-03-2020, 09:33 AM
joxr's Avatar
Quoted: 122 Post(s)
Liked: 41
Usually people just get cabinets that have a back that can be cut out to fit the deeper AV gear.
5.2.4
joxr is offline
post #3 of 10 Old 06-03-2020, 09:33 AM
gimmepilotwings's Avatar
Quoted: 61 Post(s)
I know they are cheap, but Ikea?
gimmepilotwings is offline
post #4 of 10 Old 06-03-2020, 09:45 AM
Spidacat's Avatar
Quoted: 384 Post(s)
Liked: 525
Not sure how many shelves you need or height/width requirements, but BestBuy has a few to choose from. Like...
https://www.bestbuy.com/site/bello-a...?skuId=5606968
https://www.bestbuy.com/site/sanus-c...?skuId=4861415
Spidacat is online now
post #5 of 10 Old 06-03-2020, 02:09 PM
khcoach's Avatar
Quoted: 96 Post(s)
Liked: 74
Ikea Besta (build what you want/need) and cut out the back where the shelf for the AVR will go. That's what i have, it's aprox 15.75 deep, plus with the back cut out you can have access to everything on the back.
khcoach is offline
post #6 of 10 Old 06-03-2020, 04:23 PM
mlknez's Avatar
Quoted: 661 Post(s)
Liked: 221
Be careful. You say that you have "Higher End" equipment and that generally equates to a lot of weight. Many of the cheaper units are not rated for handling a lot of weight.
Perhaps this companies products?
https://www.bdiusa.com/
Media Room: LG oled65c7, Marantz AV8805, Sherbourn 7/2100, Emotiva A-300, Studer A80, Studer Revox b795, Nakamichi RX-202, HTPC, exaSound e38, Sweetvinyl Sugarcube SC-2, (2) Piega P10, Piega Coax Center, (6) Piega AP 1.2, Hsu VTF-15h mk2
Office: Emotiva mini-x A100, Geek Pulse, (2) KEF LS-50, Goldenear FF 4, PC, NAS 130TB
Bedroom: Panasonic TCP55vt35, Marantz NR1200, Dune 3 Prime, (2) Elac Uni-Fi UB5
mlknez is online now
post #7 of 10 Old 06-03-2020, 04:35 PM
phantom52's Avatar
Quoted: 341 Post(s)
Liked: 306
phantom52 is offline
post #8 of 10 Old 06-03-2020, 04:47 PM
afrogt's Avatar
Quoted: 2506 Post(s)
Liked: 1640
if its just for AV equipment check out Monoprice Monolith stands. 18.7 inches deep so maybe your equipment hangs slightly over the edge in the back.
https://www.monoprice.com/product?p_id=39167
Afro GT
afrogt is offline
post #9 of 10 Old 06-03-2020, 05:17 PM
PioManiac's Avatar
Quoted: 3499 Post(s)
Liked: 9014
I prefer that my highest powered components have wide open air to breath,
...also like my TV mounted as low as possible with eye level center screen so options are limited.
My unfinished basement man cave was done in record time on a tight budget almost exclusively with IKEA:
shelves/bookcases/TV stand/end tables/lamps/track lights/area rugs/media storage shelves and curtains....Dirt Cheap!
Saved a bunch of money that I spent on quality gear and powered recliners instead.
Spoiler!
The Unfinished Basement Theater & Whisky Guitar Lounge | Bass EQ for Filtered Movies
JVC DLA X750 4K Projector | 120" Powered Drop Screen | 65" LG 65B6P OLED | Panasonic DMP UB900 | Oppo UDP 203 | HDFury Vertex
Yamaha RX-A3070 | 7.4.4.4 | Mission M3i x11 | Funk Audio 18.0 x2 | Velodyne DLS 5000R x2 | Crowson LvL3 MA x4 | miniDSP 2x4HD
PioManiac is offline
post #10 of 10 Old 06-03-2020, 05:20 PM
sbarnhar's Avatar
Quoted: 20 Post(s)
Liked: 30
I recently needed something similar. This post (and the first post of the thread) shows what I got, and how I made it work.
Scott
sbarnhar is offline
home theater furniture , tv stand
