"OFFICIAL" 2020 Denon AVR Owner's Thread + FAQ (Posts 1-8) - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 1869Likes
post #61 of 1671 Old 06-04-2020, 11:10 AM
NY Giants's Avatar
PASS!
Hopefully another brand will offer more than one HDMI 2.1 input.
NY Giants is offline
post #62 of 1671 Old 06-04-2020, 11:13 AM
the7mcs's Avatar
Quoted: 553 Post(s)
Liked: 254
Hey my main man JD
I wonder if a speaker config of 5ch+FW and 6 height channels can be configured
In that scenario the surround back speakers won’t be used since it’s at 13 max
the7mcs is offline
post #63 of 1671 Old 06-04-2020, 11:21 AM
avernar's Avatar
Quoted: 1267 Post(s)
Liked: 1542
Read my response in post 35 to you again.
Whoops. Missed the first couple of words of that post.
avernar is offline
post #64 of 1671 Old 06-04-2020, 11:25 AM - Thread Starter
jdsmoothie's Avatar
Quoted: 24612 Post(s)
Liked: 13841
Originally Posted by the7mcs View Post
Hey my main man JD
Nope. As noted in the pic in post 15, the Height 3 and Front Wide share the same speaker posts.
This is one of the additional features of the X8500H with its 4 sets of additional speaker posts instead of only 3 sets.
jdsmoothie is online now
post #65 of 1671 Old 06-04-2020, 11:31 AM
dj7675's Avatar
Quoted: 180 Post(s)
Liked: 114
Originally Posted by JediFonger View Post
re: preamp mode. totally agreed. this is super exciting!
quick question though... do you guys know if this is an all or nothing mode?
i only have 1 stereo amp for L&R. not sure if i will ever get amps for everything else. could i disable just the front L&R mode or will it disable everything and you must have amps for all the channels?
i poked around the 'manual' and only saw these 2 relevant pages but it's not super clear:
http://manuals.denon.com/AVRX3700H/N...SYhylpohod.php
http://manuals.denon.com/AVRX3700H/N...DRDZMLwkekzqtf
i imagine it's a all or nothing proposition and that the higher models might allow for this type of granular adjustment no?
I have an x8500, and in custom amp assign you can pick and choose what channels you want disconnected. So for example you can choose to set L/R/C channels to none and the amps will be disconnected. The manual doesn’t do a very good job at explaining this but I have used it and this can be done.
raistlin65 likes this.
dj7675 is online now
post #66 of 1671 Old 06-04-2020, 11:36 AM
JediFonger's Avatar
Quoted: 226 Post(s)
Liked: 57
that's way out of my price range. plus i'd rather have a 3700/4700 + $ on external amps >P
Dootinn likes this.
i host a silent film podcast here:
https://anchor.fm/watchingsilentfilms
^that or everywhere podcasts are found. or find out where else here:
https://watchingsilentfilms.wordpress.com/
JediFonger is offline
post #67 of 1671 Old 06-04-2020, 11:49 AM
mnc
mnc's Avatar
Quoted: 1023 Post(s)
Liked: 808
I just bought a 4500, I wonder if I should exchange for a 4700? Or if BB does a price drop on the 4500 I could get the difference refunded.
NHT speakers, Denon x4500h, Stacked PSA XS30SE's, ATV4K, 75X940E, UBPX700
mnc is offline
post #68 of 1671 Old 06-04-2020, 11:53 AM
whiteboy714's Avatar
Quoted: 1908 Post(s)
Liked: 826
Interesting so no x1x00 model this year. I wonder why? Maybe the baseline feature set was considered too premium for the base model?
whiteboy714 is online now
post #69 of 1671 Old 06-04-2020, 11:58 AM
Kurtz9's Avatar
Quoted: 224 Post(s)
Liked: 102
Originally Posted by LtroyalShrimp View Post
SO just so I understand correctly - The entire series of 2020 AVRs only has one HDMI 2.1 40Gbps input port? Thats seems odd. By end of the year with the new consoles and a PC ill have at least three sources that I want to connect to HDMI 2.1 ports.
Yeah- which makes it pretty garbage honestly.... if LG ever fixes their eArc problem on their OLEDs there'd be no point in buying this thing at all- just run video direct to the TV and ignore the AVR entirely except for one eARC connection back to it anything as old as an x3400 for audio only (and no benefit in getting a "new" one to do that- anything that does eARC'd be sufficient)
My luck of course I'm currently running an X3300, the last one BEFORE eArc... still highly disappointed I held out just for this to not get me anything worthwhile over what 3 models ago'll do with a working eARC TV.
iatacs19 and AaronMK like this.
Kurtz9 is offline
post #70 of 1671 Old 06-04-2020, 12:15 PM
dj7675's Avatar
Quoted: 180 Post(s)
Liked: 114
Originally Posted by JD23 View Post
IMO, this is actually the most significant feature (more important than a single 40 Gbps HDMI input):
"- Pre-amp mode (formerly only featured on the flagship models) - physically disconnects all on board amps when only external amps are being used (X3700H and higher)"
This will allow these AVRs to function as true pre/pros when an external amplifier is used and increase the effective clean output range of the preouts. As shown in the ASR review of the X3600H, use of the preamp mode available for the two front channels enables the X3600H to measure better than many far more expensive pre/pros, such as the new Arcam units. Without this mode, the preamp output falls apart when the amp is driven to clipping.
This is the feature that could tempt me to sell my X4500H and upgrade to an X4700H. The X3700H may be the best value, but the lack of a front HDMI input disqualifies it for me.
The manuals of the new models are different as the new 3700/4700/6700 models do have a preamp mode which disables all amps for improved performance. The 8500 has the custom assign mode and from there you can select "none" on any given channel and disconnect the amp. So without having units in hand to go through the menu, it does appear than you can't pick and choose which channel you want to disconnect. This could be a bit of a bummer for those that want to use some of the onboard amps but not all. Looks like they retained this just for the 8500.
post #71 of 1671 Old 06-04-2020, 12:21 PM
Quoted: 29 Post(s)
Dumb question but someone asked if these only had (1) HDMI 2.1 port. It should be 1 port + the eARC monitor port, yes? So ability to plug in 1 HDMI 2.1 item and plug others straight into an LG OLED? With the eARC able to handle the HDMI 2.1 items plugged in?
William Nope is offline
post #72 of 1671 Old 06-04-2020, 12:32 PM
avernar's Avatar
Liked: 1542
The C9 just got a firmware update the full enables LPCM 5.1 and 7.1 so there's no more eARC problems. The 2017 Denons do have eARC issues however.
dfa973 likes this.
avernar is offline
post #73 of 1671 Old 06-04-2020, 12:43 PM
oniiz's Avatar
Quoted: 181 Post(s)
Liked: 56
Originally Posted by avernar View Post
The C9 just got a firmware update the full enables LPCM 5.1 and 7.1 so there's no more eARC problems. The 2018 Denons do have eARC issues however.
I believe it's the 2017 Denon X4400H/X6400H models that are affected, 2018 models are meant to be fine.
oniiz is offline
post #74 of 1671 Old 06-04-2020, 12:45 PM
avernar's Avatar
Liked: 1542
Typo. Fixed.
Yes, the 2017's have issues. The 2018's and 2019's work fine.
avernar is offline
post #75 of 1671 Old 06-04-2020, 12:49 PM
Kurtz9's Avatar
Quoted: 224 Post(s)
Liked: 102
So basically I should keep eyes open for a refurb X3500 or something cheap to replace my 3300 is what it sounds like since the 3700 won't really get me anything
Kurtz9 is offline
post #76 of 1671 Old 06-04-2020, 01:01 PM - Thread Starter
jdsmoothie's Avatar
Liked: 13841
Correct.
1ea - HDMI 2.1 input
2ea - HDMI 2.1 main zone monitor outputs
post #77 of 1671 Old 06-04-2020, 01:04 PM
Quoted: 72 Post(s)
Liked: 0
we are in the same boat. Im starting a new HT system from scratch, i have already bought the 2 front speakers (Klipsch 8000) and the only thing i really want to know if denon 4500 earc will work without issues with lg oled c9 or cX.
Blade 77 is offline
post #78 of 1671 Old 06-04-2020, 01:07 PM
Quoted: 72 Post(s)
Liked: 0
does this means c9 or cx earc will work with denon 4500?
Blade 77 is offline
post #79 of 1671 Old 06-04-2020, 01:15 PM
avernar's Avatar
Liked: 1542
There should not be any issues with the C9 as I've run it with both an X3500H before and an X6500H now. The CX can't do any form of DTS.
avernar is offline
post #80 of 1671 Old 06-04-2020, 01:18 PM
Quoted: 242 Post(s)
Liked: 90
I've been waiting to upgrade my x4300h which doesn't have eARC so these models are a worthwhile upgrade to me. I've also been wanting to try the Dolby Atmos Height Virtualization because I'm not able to set up the discrete speakers in my living room. The one HDMI 2.1 port is fine in the near term. Technically I don't need that feature at all because I don't really expect it to make much of a difference for the next gen of consoles, and for my PC I've been running the video to the TV directly and the audio to the AVR using a displayport to hdmi adapter.
family_guy is online now
post #81 of 1671 Old 06-04-2020, 01:23 PM
I'm That Guy, don't be me
Baff's Avatar
Quoted: 324 Post(s)
Liked: 370
3600/3700 add 2 more channels over the 3500.
LG 65" C9; Denon AVR-S750H
5.1.2: Emotiva Airmotiv C2, T-Zero (x2), E1 (x4); HSU VTF-2
Baff is offline
post #82 of 1671 Old 06-04-2020, 01:25 PM
Quoted: 29 Post(s)
Correct.
Perfect, thanks!
post #83 of 1671 Old 06-04-2020, 01:30 PM
bboncorr1's Avatar
Quoted: 48 Post(s)
Liked: 31
I have been debating for months on the 3600 or 4500. Finally today I decided to pull the trigger. Something happened with him he Amazon order and it didn’t go through. While waiting on Amazon customer service I came across the Denon release date. I couldn’t make sure it was canceled fast enough. 4700 comes out on my Birthday to boot (well 14th). I’ll take it as divine intervention.
mustangtexas likes this.
Pioneer 5010FD, Samsung 55hu8550, Panny 42PZ85U, Denon 4308, B&W 600's, HSU VTF-3 MK3, harmony 1000, PS4, Xbox One, Sony BDP S350, TiVo Roamio multi room setup
bboncorr1 is offline
post #84 of 1671 Old 06-04-2020, 01:31 PM
Quoted: 29 Post(s)
For anyone curious I have a 2019 Denon S750H which I got for $200 a few months ago. It has eARC and HDMI 2.1 functionality and I’ve had no issues using eARC from an LG B9 on any of the internal apps and getting DTS and Dolby Atmos with no issues. I’ve ran my Xbox one into my TV and gotten Dolby Atmos out to the receiver as well.
post #85 of 1671 Old 06-04-2020, 01:33 PM
bryantc's Avatar
Quoted: 789 Post(s)
Liked: 756
- Added via future firmware update:
- Screen saver - moving DENON icon as well as moving MUTE icon (December 2020)
Wow finally. This is probably the most practical new feature.
avernar and PoshFrosh like this.
Media: LG 88" 8K OLED Z9 / Denon AVR-X8500H 7.1.4 / Oppo UDP-203 / Nvidia SHIELD (2017) / Apple TV 4K / Sony 4K FMP-X10 / Gaming PC (Threadripper 1950X / 2x GeForce GTX 1080 Ti SLI) / PlayStation 4 Pro with PS VR / PlayStation (original)
Family: Sony 85" 4K XBR-85X900F / Denon AVR-X3400H 5.1 / Nvidia SHIELD (2017) / Apple TV 4K / C64 Mini - Game: LG 77" 4K OLED C8 / Denon AVR-X3400H 5.1 / Nvidia SHIELD (2017) / Apple TV 4K
bryantc is offline
post #86 of 1671 Old 06-04-2020, 01:36 PM
Quoted: 72 Post(s)
Liked: 0
indeed!
Blade 77 is offline
post #87 of 1671 Old 06-04-2020, 01:37 PM
bad1550's Avatar
Quoted: 119 Post(s)
Liked: 52
I have an x8500, and in custom amp assign you can pick and choose what channels you want disconnected. So for example you can choose to set L/R/C channels to none and the amps will be disconnected. The manual doesn’️t do a very good job at explaining this but I have used it and this can be done.
I have the x8500h and my fronts are running through Emotiva amp.
Do I need to disconnect in amp settings or does it just recognize the Emotiva?
bad1550 is offline
post #88 of 1671 Old 06-04-2020, 01:39 PM
Quoted: 72 Post(s)
Liked: 0
thats good to know, i hope that c9 will be ok with a refurbished denon 4500 then!
Blade 77 is offline
post #89 of 1671 Old 06-04-2020, 01:47 PM
Jon AA's Avatar
Quoted: 186 Post(s)
Liked: 217
Something I noticed for the 6700 for those who like Auro3D--it has the upgraded implementation of Auro which includes channel expansion and "Movie Mode." Only the 8500 in the D&M lineup had these features before.
Jon AA is offline
post #90 of 1671 Old 06-04-2020, 02:07 PM
Archaea's Avatar
Quoted: 4327 Post(s)
Liked: 4167
From the Audioholics Denon Press Event today:
They said the other 8 inputs will support QFT and VRR -- so that's good news!
See here:
Archaea's 9.8.4 Home Theater Room
208, 1" tweeters | 52, 5" woofers | 8, 18" subwoofers
Archaea is online now
4700h , hdmi diagnostic mode
