Will a good integrated amp (e.g. Naim Nait 5i) improve audio for home theater? - AVS Forum | Home Theater Discussions And Reviews
 7Likes
  • 2 Post By BillP
  • 1 Post By MrBobb
  • 1 Post By gibson61
  • 1 Post By snkadh
  • 2 Post By jdcrox
post #1 of 18 Old 06-30-2020, 02:18 PM - Thread Starter
d3wu's Avatar
Hi all,
I have a budget AV receiver (Marantz SR6200, very old!) that provides decent audio for home theater but not great.
I also have a Naim Nait 5i integrated amplifier lying around not being used. It has a home theater bypass option, and I'm thinking of having it power my front left & right speakers in my 5.1 setup, using the Nait 5i (instead of the Marantz which would continue to power the centre and rears - I don't use a sub since small 10 feet x 10 feet room).
Would this result in better overall 5.1 sound quality? My guess is YES (at least for the front left and right speakers since those speakers would be powered by a dedicated integrated amp, and a good quality one at that (Naim).
Thanks for any help from the AVS forum gurus!
Darren
d3wu is offline
post #2 of 18 Old 06-30-2020, 03:46 PM
BillP's Avatar
Quoted: 806 Post(s)
Liked: 695
You don't say what speakers you have, but it is more likely that upgrading your speakers will improve audio more than adding an amp. Speakers determine audio quality much more than any piece of electronics.
eljaycanuck and spyboy like this.
Sony A9G, Oppo 205, Parasound JC2, Parasound A21, Sonus Faber Olympica IIIs
BillP is online now
post #3 of 18 Old 06-30-2020, 04:43 PM
MrBobb's Avatar
Quoted: 313 Post(s)
Liked: 141
Is easy enough to plug the box in, why not just try it out, doesn't cost anything.
eljaycanuck likes this.
MrBobb is online now
post #4 of 18 Old 06-30-2020, 04:49 PM
eljaycanuck's Avatar
Quoted: 2170 Post(s)
Liked: 3160
Originally Posted by d3wu
... I have a budget AV receiver (Marantz SR6200, very old!) that provides decent audio for home theater but not great.
I also have a Naim Nait 5i integrated amplifier lying around not being used. It has a home theater bypass option, and I'm thinking of having it power my front left & right speakers in my 5.1 setup ...
Would this result in better overall 5.1 sound quality? ...
Not sure why simply moving the mains to the Naim would improve the sound quality but - as has already been pointed out - since it costs nothing to try it out you might as well try it out.
eljaycanuck is offline
post #5 of 18 Old 06-30-2020, 07:09 PM - Thread Starter
d3wu's Avatar
Thanks for the advice everyone!
The Naim is actually sitting at my brother's place in another city, so not too easy to just try out, so was hoping for a "theoretical" answer
To me, the mains should sound better if directly driven by the Naim amp vs. the Marantz receiver...but I'm just not sure if running the Naim through the Marantz would lessen the sound quality.
(P.S. my speakers are the most high-end piece in my setup, so it won't be the weakest link)
d3wu is offline
post #6 of 18 Old 07-01-2020, 04:54 AM
BillP's Avatar
Quoted: 806 Post(s)
Liked: 695
And what exactly are they? As stated above, the best way to change or upgrade audio quality is by changing speakers, not amps. Maybe they are great, maybe not. Or maybe just not a great match with your AVR. Or maybe it's just your sub that is the weak link, or your center. If you really want our help, you need to state all your equipment, or any "help" will not be all that helpful.
BillP is online now
post #7 of 18 Old 07-01-2020, 04:59 AM
Quoted: 192 Post(s)
Liked: 296
The naim is a nice amp/ For a stereo only rig it would be better than the marantz . In 5.1 using the naim should provide more head room which is always good. I would do it.
d3wu likes this.
gibson61 is offline
post #8 of 18 Old 07-01-2020, 08:34 AM - Thread Starter
d3wu's Avatar
Understood, sorry for being vague.
The fronts are B&W 705 S2 and center channel is the matching B&W HTM72. Rears are some old B&W DM303's. No sub as it's a small room (10 feet x 10 feet).
The source is a pretty high end Pioneer Blu Ray player (Pioneer UDP-LX500) and I'm a big concert film guy so like to listen to concerts in 5.1 (no sub)
I do also listen to TONS of music videos on YouTube (I know, not a strong audio source, but I just can't resists the sheer convenience and the appeal of having video alongside the audio). When I do this, I set the receiver to 2-channel sound.
Thanks again for any help!
d3wu is offline
post #9 of 18 Old 07-01-2020, 08:40 AM
BillP's Avatar
Quoted: 806 Post(s)
Liked: 695
Thanks for the info. Obviously using the Naim is free, other than the nuisance of getting it from another city, so you may as well give it a try. But IMO, you will improve your home theater experience more (your original query) by adding a sub. Less important for music, but more important (IMO) for movies.
BillP is online now
post #10 of 18 Old 07-01-2020, 09:13 AM - Thread Starter
d3wu's Avatar
Thanks. The music concerts are my big priority though and I've got more than enough bass though in my small room.
I think I will obtain the Naim - theoretically, sounds like it will help, so now time to put that test in practice
Btw, noticed you have an A9G. I'm a proud owner myself (55"). Super impressed with everything about that TV (except for the slight tilt/angle) - might be the best piece of electronics that I've ever bought!
d3wu is offline
post #11 of 18 Old 07-02-2020, 04:55 AM
snkadh's Avatar
Liked: 2
May I know how do you play music videos youtube? Is it from your
1. TV-> AVR (Via optical/HDMI ARC) or
2. from TV->3.5mm out?
So for the first case you need to convert the digital signal to analogue. Since Naim do not take any digital signal, in that case a DAC will be needed to convert the digital from analogue.
In second case you can just replace the the Marantz. But it will be only stereo setup.
d3wu likes this.
snkadh is offline
post #12 of 18 Old 07-02-2020, 06:35 AM
Quoted: 190 Post(s)
Liked: 123
Integrating an integrated amp with an AVR is tricky. Any change in volume on the Naim will upset the balance with the other leakers. Since you don’t have a sub, it makes it much easier. However you will still need to fix the volume on the Naim.
Your options are, drive all sources through the Marantz, fix the volume on the Naim and essentially use it as an external power amp.
Or, some sources go through the Naim, so you use it as an integrated amp, and for 5.1 stuff, the Marantz goes through the Naim, but you have to carefully reset the Naim volume every time you switch to a Marantz source.
thebrieze01 is online now
post #13 of 18 Old 07-02-2020, 10:27 AM
jdcrox's Avatar
Quoted: 108 Post(s)
Liked: 130
The Naim has a home theater bypass, so when used as a power amp for the AVR you simply select that input, and the volume is set. If you use the Naim as an integrated, whatever volume you select on the Naim will be active. You do not need to reset the volume when going back to the Marantz.
sigpig and d3wu like this.
jdcrox is offline
post #14 of 18 Old 07-02-2020, 12:36 PM
Quoted: 190 Post(s)
Liked: 123
Aah.. missed the HT Bypass bit. Thanks
post #15 of 18 Old 07-03-2020, 06:34 AM - Thread Starter
d3wu's Avatar
It's the first case - TV to AVR using optical cable. Why do I need to convert the digital signal to analogue? I thought I would just use RCA cables from the AVR's pre outs to the Naim's AVR inputs?
d3wu is offline
post #16 of 18 Old 07-03-2020, 06:38 AM - Thread Starter
d3wu's Avatar
Thanks both. I will try this. In theory, since the Naim will drive the front mains (instead of the Marantz which will only drive the center and rears), I'm guessing the overall sound (no sub) will be better than if I just used the Marantz for all 5 speakers.
Although, I wonder if that will actually be the case since perhaps using one driver (the Marantz) to drive everything would result in a more balance/harmonized sound than using two separate drivers (even if the Naim is a much better piece of equipment)...
d3wu is offline
post #17 of 18 Old 07-03-2020, 07:15 AM
markmon1's Avatar
Quoted: 6808 Post(s)
Liked: 4932
My guess is it will basically sound the same either way.
JVC Control - my software for controlling JVC projector via IP control.
Smart Masking - See my automatic smart screen masking system.
JVC IR Codes - free online pronto code converter for JVC IR codes.
markmon1 is offline
post #18 of 18 Old 07-03-2020, 07:52 AM
Quoted: 190 Post(s)
Liked: 123
Audyssey should harmonize the main speakers along with the other speakers, so I wouldn’t worry about that. So long as you’re ok with not having a subwoofer for 2 channel, the plan works.
