Anthem MCA-50 vs Halo A31? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-30-2020, 05:56 PM - Thread Starter
Quoted: 22 Post(s)
Liked: 4
I have the option of purchasing a Anthem MCA-50 5-channel for or a Parasound Halo A31 3-channel.
I plan on using the amp I purchase to power my front 3 channels (left right and center). The remaining (surrounds) will be powered by another amp I already own. I have a Marantz 8802a processor and The fronts are canton reference 7.2 DC’s (with marching center).
I can afford both amps. I am willing to splurge on the Parasound over the Anthem but only if it makes a difference in sound.
I don’t care for aesthetics, or bragging rights, the units will be hidden. Warranty etc aren’t important, these are used units, they are flawless. I know one is a 3 channel the other is 5, but that isn’t a deciding factor for my needs.
What do you recommend?
nafzal is offline
post #2 of 5 Old 06-30-2020, 06:13 PM
Super Moderator
teachsac's Avatar
Quoted: 1446 Post(s)
Liked: 2528
Moved to receivers.
Please use the report post button to alert staff to problematic posts. Never quote or respond to them yourself.
Panasonic DP-UB820 -> Yamaha CX-A5100 -> Sony XBR-75X940C; Mediabridge 6' and 15' HDMI cables.
teachsac is offline
post #3 of 5 Old 06-30-2020, 07:45 PM
Quoted: 40 Post(s)
Amps largely don’t make a difference in sound as long as both are generally decent quality and driven within stated limits. However, the Parasound has about 2 watts of Class A bias into 8 ohms before it goes into Class A/B operation. Two watts is pretty loud, and some people believe that Class A sound makes a difference (whether because of harmonics, lower distortion, etc.). So it is likely that they sound identical, but if they do sound different, it’s probably the Class A bias. You may want to look into things like warranty and noise floor of both models as well.
GrailWarCFB is online now
post #4 of 5 Old 07-01-2020, 07:54 AM
Jonas2's Avatar
Quoted: 3344 Post(s)
Liked: 2209
The cheaper one. Very unlikely you'll hear any difference.
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #5 of 5 Old 07-01-2020, 10:00 AM
b curry's Avatar
Quoted: 1297 Post(s)
Liked: 835
Both good amplifiers.
I would go with the Anthem. It has a better S/N ratio by several dB and slightly better THD. It's also designed and built in North America, Canada.
Parasound is designed in the US and built in Taiwan.
b curry is offline
