Rotel Owner's Thread - Page 68 - AVS Forum | Home Theater Discussions And Reviews
 316Likes
post #2011 of 2014 Old 06-11-2020, 11:51 AM
jrandamy's Avatar
Quoted: 17 Post(s)
Originally Posted by ereed View Post
I have the slightly newer RSP-1068 and you need to connect to a tv or monitor to be able to get into all the deep settings. Yeah, just make sure your tv/monitor has component video at least or whatever the rsp-1066 uses for monitor out.
I was afraid of that. Looks like I will have to use my existing Denon receiver as the preamp. I have no video display devices that will accept an S-Video or Composite video signal.
J.R.
jrandamy is offline
post #2012 of 2014 Old 06-11-2020, 01:54 PM
ereed's Avatar
Quoted: 2468 Post(s)
Liked: 1770
J.R.
I believe they make component to hdmi converter/switcher if I'm not wrong.
Theater room: Sony 45es | 120" screen | Panasonic BDT500 | Rotel RMB-1077 | Outlaw Audio 976 | Klipsch RP-280F/RP-450C/RP-160M | Funk Audio 18.0L (2), 21.0LX (2 coming soon) | MiniDSP 2x4HD | Crowson Tech MAs | Surgex XR 315 | CyberPower UPS | GIK room treatments
TV Room: Panny 60 inch | Rotel RMB-1075 | Rotel RSP-1068 | Axiom Audio M60/VP150/QS8 |
ereed is offline
post #2013 of 2014 Old 06-29-2020, 11:38 AM
Liked: 0
Hello,
I have a technical question concerning how to wire a RC 1590 to a RB 1590, would you use RCA or XLR? The two devices are very close in my configuration, 40 cms.
I read here on ht guide (thread : 43084) (I'm a newb I cannot post links apparently) that the preamp is not fully balanced meaning it does unnecessary conversion of the signal when using XLR connection between the I/Os. Do I understand correctly?
This means XLR on this combo would have an interest only if you have a set up where your preamp and power amp are far away from each other and XLR cables will help with that by cancelling interferences.
Other than that, you'll have better fidelity with RCA since it does not do unnecessary conversion to the signal.
This was not obvious because using the XLR should be better since it supposed to have better figures voltage/impedance wise.
Am I correct? What is the best way to go? I'm curious about that.
David Ganem is offline
post #2014 of 2014 Old 06-30-2020, 07:48 AM
tanman's Avatar
Quoted: 499 Post(s)
Liked: 377
XLR are used for long runs. Last I recall over 10 meters or so or also running near power cables. You are so very close I would stick with RCA.
tanman is offline
Rotel , Rotel Rsp 976 Surround Sound Preamplifier Processor , Rotel Rsx 1550 Home Theater Receiver , Rotel Rsx 1562
