D-Sonic custom Audio amps - Page 59 - AVS Forum | Home Theater Discussions And Reviews
 150Likes
post #1741 of 1989 Old 01-01-2018, 01:55 PM
ScottieBoysName's Avatar
Quoted: 1325 Post(s)
Liked: 483
Originally Posted by TL5 View Post
I thought an outlet could only supply 1800 watts total, can someone explain how all that power is delivered?
Good question! First time I’m hearing this.
Sent from my iPhone using Tapatalk Pro
ScottieBoysName is online now
post #1742 of 1989 Old 01-01-2018, 02:58 PM
Marc Alexander's Avatar
Quoted: 5543 Post(s)
Liked: 5133
Hopefully this article can help you understand how AC outlet power translates to amplification power.
http://www.rocketroberts.com/techart/powerart_a.htm
Marc Alexander is online now
post #1743 of 1989 Old 01-01-2018, 04:25 PM
Jonas2's Avatar
Quoted: 2839 Post(s)
Liked: 1813
That is true of a 15AMP breaker, and I wouldn't push that wattage constantly. But, you gotta figure that power is not what is being delivered, but if it was, yeah it'd smoke the breaker, not to mention the majority of speakers! You'd likely know you're damaging the speakers before turning them into piles of ash, fortunately. That amount of power in a module offers tremendous reserves of juice that are there for dynamic peaks when they occur. Granted, to demand that much power, I don't know how likely that is in a typical home theater application?
Originally Posted by ScottieBoysName View Post
Good estimate! It was right around there. Maybe $4400 or so.
That's some serious amplifier.....
7.2.4 System: Display: Sony XBR-65X930D; Processing: Anthem AVM60
Mains:
Paradigm Prestige 85F and 55C; Side / Rear Surrounds: Totem Acoustic Tribe III / Tribe I; Amplification: D-Sonic M3a-2800-7 (7ch. x 400w)
ATMOS:
Definitive Technology DI8R; Amplification: Class D Audio SDS-470C (4ch. x 300w)
Subwoofers:
2 x SVS-SB13Ultras; Media: Oppo UDP-203, Pioneer CLD-59
Jonas2 is offline
post #1744 of 1989 Old 01-01-2018, 06:21 PM
Liked: 483
My theater room will be split up on two 20amp breakers, so I hope that’ll be ok!
post #1745 of 1989 Old 01-01-2018, 06:55 PM
Jonas2's Avatar
Liked: 1813
Well, to give you some idea - with my pre-pro, Atmos amp, UHD player, cooling fans, cable TV box, and 65" LED TV all churning away, it barely makes 2 amps, usually lower. The only time it goes above that is when I power on the system (Atmos amp) and it'll spike to about 5 amps for a fraction of a second, then settles back down. Idling is 0.5A with everything in stand by - so not a real concern about those items drawing too much power. These are on their own shared 15AMP breaker (shared with a few other outlets in the same room).
I do not know how much my D-Sonic draws as it is plugged into its own 20AMP outlet and I've never tested it, but it ain't getting anywhere NEAR that. My two subs are also on their own 20AMP outlet. Playing at the volume levels I can tolerate (which is not reference, but it's loud!) - no issues thus far! I should plug the D-Sonic into the back of my Panamax and see what that does to the Ammeter.
I think you will be more than O.K. with the 2 x 20 amp breakers.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1746 of 1989 Old 01-01-2018, 09:58 PM
Liked: 483
Ok whew! Good to know.
Sidenote - You’re always really helpful with your responses. I appreciate that. Hats off to you!
post #1747 of 1989 Old 01-02-2018, 12:30 AM
Quoted: 438 Post(s)
Liked: 192
There is an option to have two power cords powering a single amplifier. I would assume anything over the 1500x2 800x1 4x400 would need to use two power cords.
Sent from my SM-G955U1 using Tapatalk
Pre-Pro: Yamaha CX-A5100, Amp: D-Sonic M3-5400-7, Subs: 3 JTR Orbit Shifter LFU's, LCR: DIYSG F-15 Sentinels, Surrounds: Tannoy 802's, 4k player: Panasonic UB-900, 4k Gaming PC
David Varner is offline
post #1748 of 1989 Old 01-02-2018, 12:39 AM
Liked: 5133
I think dual power cords are optional.
post #1749 of 1989 Old 01-02-2018, 01:09 AM
Quoted: 438 Post(s)
Liked: 192
Yes they are but a few previous posters were talking about 1500x3 400x4/800x4 or all 1500w modules. At some point you would need the second power cord. The option for the second power cord also leads me to belive Dennis can do a full 1500w x7 m3a.
Then the real questions remains would you even need the second power cord. 1500w x 7= 10.5k watts. I thinks so. I'm sure Dennis could do a 230v model as well.
post #1750 of 1989 Old 01-02-2018, 01:16 AM
Liked: 5133
I believe the current power supplies already support a wide range of voltages including 230VAC.
post #1751 of 1989 Old 01-02-2018, 01:27 AM
Quoted: 438 Post(s)
Liked: 192
I think you are correct
post #1752 of 1989 Old 01-02-2018, 07:29 AM
theblackangus's Avatar
Quoted: 514 Post(s)
Liked: 281
The second power cord could be for commercial applications that require high availability.
theblackangus is online now
post #1753 of 1989 Old 01-02-2018, 07:33 AM
Liked: 5133
Yes, this is my understanding.
I went with 3 monoblocks for my front LCR. I plan to end up with a 5 x 400W and a 7 x 400W eventually. I have Earthquake Cinenova Grandes at the moment. Baby steps.
post #1754 of 1989 Old 01-02-2018, 09:10 AM
Jonas2's Avatar
Liked: 1813
They do, I actually checked with Dennis, they are full range from 100V to 240V (and it's indicated on the amps too, but I couldn't actually look at mine at the time). Mine might end up overseas at some point, glad they are full range power supplies.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1755 of 1989 Old 01-04-2018, 08:13 AM
Liked: 483
I asked Dennis about this as I was curious myself. The 1500x3/400x4 amp does not require an additional power chord.
post #1756 of 1989 Old 02-21-2018, 04:05 PM
Liked: 483
Any other DSonic buyers or updates?
post #1757 of 1989 Old 02-21-2018, 04:10 PM
Quoted: 438 Post(s)
Liked: 192
Still jamming with my m3a 5400 7. Everytime I turn it on i smile.
post #1758 of 1989 Old 02-21-2018, 07:10 PM
Jonas2's Avatar
Liked: 1813
Same here!
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1759 of 1989 Old 02-21-2018, 07:40 PM
shs1234's Avatar
Quoted: 226 Post(s)
Liked: 180
I have the 4000 800x3 and 400x4
Great amp. Replaced my Theta Digital Dreadnaught II and the D-Sonic uses a whole lot less juice and makes a whole lot less heat, but still sounds great.
Jonas2 likes this.
SONY VPL-VW385ES, Da-Lite 92" 0.9 HD progressive 16x9 screen, Apple TV 4K, HDFury Integral 2, Oppo UDP 203, Panasonic DP-UB820, Anthem AVM 60, D-Sonic 4000 (800x3, 400x4) for bed layer, 2 Crown XLS 1002 (225x4) for Atmos; Speakers: Polk LSiM 705s, 703 front, 4 702F/X surround, 4 Polk TL3 (Atmos), Dual Velodyne DD15 Subwoofers.
shs1234 is offline
post #1760 of 1989 Old 02-21-2018, 08:12 PM
Liked: 5133
That is high praise!
I now have 3 M3a-600Ms and a M3a-2000-5.
post #1761 of 1989 Old 02-21-2018, 08:17 PM
Jonas2's Avatar
Liked: 1813
I want to put together a nice little stereo only system, mostly just so I can but another D-Sonic amp.....!
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1762 of 1989 Old 02-22-2018, 07:54 AM
Quoted: 438 Post(s)
Liked: 192
Hehe...same plans kinda. I bought a used pre/pro an onkyo pr-sc886. I needed XLR outs. I'm going to put a small 3.1 system upstairs TV/2ch listening. I also bought those new Dayton AMT towers. I never heard a ribbon tweeter kinda curious. Just started browsing for another amp. I might see if my inuke nu4-6000 can handle the job for now. I have an 4cft 18" PSI sealed sub coming out of my truck. With all intentions of re-purposing it when Sterno Integrity comes finally delivers on my pre-ordered 2X 12" BK MKV subs. Slim and will go right under the rear seats.
Jonas2 likes this.
post #1763 of 1989 Old 02-22-2018, 08:20 AM
OsoSolitario's Avatar
Quoted: 106 Post(s)
Liked: 68
Just received a M3a-2800-7.
I have a M3-1200-3 (3x400w) yet, but when purchasing the 7 channel power amp, Dennis advised me to change the input circuit board with the new M3a version, because (he said) it gave a clear sound improvement. He sent the new circuit board with the same M3a-2800-7 package.
I need to reinstall all again. I was very happy with the older version.. so I'll give my thoughts about the new input board as soon as possible.
OsoSolitario is offline
post #1764 of 1989 Old 02-22-2018, 09:52 AM
Jonas2's Avatar
Liked: 1813
Yeah, you know the school of thought that all amps sound the same (high quality, solid-state, etc....), and I'm pretty much in that camp, BUT - without any way of empirically testing pre-modifications to post-modifcations - I am at least perceiving a wider sound stage than before the modifications. Could be expectation bias, don't know. One thing is for sure, nothing got lost or left out it in the upgrade! The amp is sounding fantastic with my system. I continually enjoy how un-hot the amp is driving 7 channels for hours upon hours.
OsoSolitario likes this.
Mains:
ATMOS:
Subwoofers:
Jonas2 is offline
post #1765 of 1989 Old 02-22-2018, 11:06 AM
Liked: 5133
Generally, I've found that most amps do sound the same within a linear range (see T-amp comparison tests). However the output is a function {f(c)} of the amplifier and the speaker employed. The speaker is a complex impedance/load.
Most speakers can handle 4x their RMS rating peak (+6dB). Having +6dB of clean headroom allows you to maximize what the speaker is capable of. If you have a highly-sensitive speaker (compression drivers) this could equal insane levels that you would never want to reach. You need to use your best judgment regarding your listening preferences. Max reference output for soundtracks is 105dB. Many don't need more than [or even] that indoors (an extra 3-6dB headroom never hurts).
https://www.crownaudio.com/how-much-amplifier-power
The latest generation of class D amplifiers brings impedance agnostics. Now difficult loads can be driven easily. Class D is now approaching class A performance with better than class B efficiency.
post #1766 of 1989 Old 02-22-2018, 11:16 AM
Quoted: 438 Post(s)
Liked: 192
Your opinion will will be the 3rd one here from someone that has heard both the m3 and m3a. I will be very interested to hear your impressions.
post #1767 of 1989 Old 02-22-2018, 11:48 AM
Quoted: 106 Post(s)
Liked: 68
As the circuit board update was not too expensive I decided go for it.
I have a Pioneer SC87 (european version) an Oppo 105 and JBL Array speakers (1400's mains and 880 center). LCR powered with the M3-1200-3, surround speakers powered by the Pioneer itself. I always found that ensemble a bit too transparent, not harsh at all but just a bit cruel with so so recordings. In the other hand nice recordings sound absolutely awesome (same with films). Dennis said here this new input circuit board was more relaxed.
I know well my M3-1200-3. The power module will be the same, only the input circuit board changes so I hope to hear any change or improvement... for better
M3a-2800-7 will be for Atmos upgrade, I need find a new processor yet (Anthem AV60 maybe...) but not until next Christmas or so....
post #1768 of 1989 Old 02-23-2018, 10:30 PM
Quoted: 438 Post(s)
Liked: 192
Keep an eye out for Yamaha's new pre-pro. I have the 5100 and it was released in 2015 new one mabey comming possibly this year.
post #1769 of 1989 Old 02-24-2018, 12:17 PM
Liked: 483
I’m waiting for that. I’m going to be in the market for a pre/pro shortly.
post #1770 of 1989 Old 02-26-2018, 08:40 PM
Quoted: 29 Post(s)
Liked: 7
Potential Customer
Hey all,
I am about to pull the trigger on a D-Sonic M3a-1200S to power my magnepan 1.7i's. Currently only giving them 200 into 4 ohms so this should help satiate their hunger! Quick question before I do... I have yet to change my wall outlet will this amp be able to run properly without blowing the circuit breaker every minute? I am renting this place so I am not sure if I am even allowed to mess with the outlets and I know next to northing about being an electrician.
Laptop -> iFi iSilencer 3.0 -> Wireworld Silver Starlight USB 1m -> iFi iPurifier2 -> PS Audio Nuwave DSD -> Audio Sensibility Statement SE XLR -> Pass Labs Xp-12 -> Audio Sensibility Statement SE XLR -> Pass Labs xa30.8 -> Wireworld Equinox 7 speaker cable -> Tannoy Precision 6.2 LE Other Equipment: Wireworld Aurora 7 power cables, Wireworld Electra 7 for Audioquest Niagara 1000
ostrey93 is offline
